which brushless system? >
Old 05-31-2007, 10:10 AM
  #16
KE4PJO's Avatar
"Orange" is your bet bet. I've run Novak stuff forever, every once in a while gone to other stuff. and always went back to Novak. And so you know, I'm not getting anything for saying this.
KE4PJO is offline
Old 05-31-2007, 10:23 AM
  #17
Charlie's Avatar
Hey Guys,
This is interesting to me of course. From my experience with our systems the 13.5 stuff never even gets close to getting the ESC hot enough to thermal, or even think of thermalling.
The motor is another story, gearing it up will make the motor hot and the Novak System is the only one that has Motor Temperature Protection. The LRP and the rest only have thermal protection on the ESC itself.
If you're using the 13.5 motors with The Sintered Rotors there is no real concern over the rotor overheating, you can remove the temperature protection of the motor by simply removing the Blue Wire from the Sensor harness. This will stop the motor from activating the Motor Temperature Protection. The ESC's are generally never past "warm" so there is no reason to suspect the ESC.
You can always email our tech department directly, please share this with your local racers.
[email protected]
[email protected]
949-833-8873
www.teamnovak.com
Thanks Guys!
Charlie
Charlie is offline
Old 05-31-2007, 10:32 AM
  #18
bxpitbull's Avatar
Anytime I read about somebody thermalling a Novak product, I automatically ask about their gear ratio. It leads me to believe that people are gearing their cars as if it has a brushed set-up and we know what happens after that......
bxpitbull is offline
Old 05-31-2007, 10:38 AM
  #19
Isn't Orion and Team Checkpoint coming out with new brushless systems soon?
How did those systems compare to the Novak and LRP at the Reedy Race?
sf85 is offline
Old 05-31-2007, 10:39 AM
  #20
Tech Legend
Wild Cherry's Avatar
The Orange one is good , but you`ll gona get beat by the Blue one...
You decide which one is best for you ....
Wild Cherry is offline
Old 05-31-2007, 10:47 AM
  #21
I think Orion and Checkpoint make only BL motors, not BL ESC, You can't call them systems.
B-day is offline
Old 05-31-2007, 10:51 AM
  #22
R/C Tech Elite Member
JayL's Avatar
I run the new Novak GTB SS and the new 10.5 SS in my tamiya MRE ( no air duct), with a 5.1 ratio and 90 degree outside temp 110 degree track temp and after five minute races, my motor is between 100-126 degrees every time.....
oh yeah, no fan on the esc
JayL is offline
Old 05-31-2007, 11:27 AM
  #23
My bad. I guess what I meant to ask is how did the Orion and Checkpoint motors compare to the Novak and LRP at the Reedy race?
sf85 is offline
Old 05-31-2007, 11:41 AM
  #24
Sorry, misunderstanding.
I remember someone said GM, Orion & Checkpoint all come from the same suppler. Correct me if I'm wrong.
Marc won with Checkpoint, Craig 2nd with Novak, Jeho 3rd with LRP in invitational. I mean, they are all very good motors.
B-day is offline
Old 05-31-2007, 11:59 AM
  #25
olhipster1's Avatar
Trader Rating: 100 (100%+)
Default GTB
Beware of the blue...Customer service sucks. big time.
olhipster1 is offline
Old 05-31-2007, 12:18 PM
  #26
Trader Rating: 38 (100%+)
The track I race at we are rolling out at around 45MM with the 10.5. Way more then a 19T. It flies. But definately gets hot. The Novaks will shut down but the LRP wont. I will have to have people try removing the wire.
or8ital is offline
Old 05-31-2007, 12:31 PM
  #27
Elboogie's Avatar
I am going to switch to brushless after the IIC and I am not experienced with brushless systems motors etc, so I wanted to find out some answers.
What exactly does it mean when you say that they "thermalled?" I am assuming that it has to do with something overheating
I saw a PDF for the Novak GTB instructions and it states that when you are running the 10.5 that you should gear the motor, at the most, 2 teeth above what you may run on brushed motors. Is this the norm or are people thermalliing because they are geared to the hilt?
Thanks for the info guys.
Elboogie is offline
Old 05-31-2007, 12:40 PM
  #28
Yes shutting down due to overheating protection.
You know racers. We push everything to the limit. Most people add tons of teeth to what they would run a 19T at (at least where I race). I would say those instructions say that for two different reasons. First they were probably done before the sintered rotors. And secondly to keep you from damaging the ESC and returning it for support.
or8ital is offline
Old 05-31-2007, 02:06 PM
  #29
bxpitbull's Avatar
Or8ital, you have confirmed what I have thought. People pushing the envelope, thermaling and then wondering why. I know I cant say the same for Lrp. I ran within the parameters in their instructions and had nothing but PRAH-blums! They gave me fits to honor the warranty and by the time I got the new speedo, it was in and out of my hands before I could get any fingerprints on the pack.
Old 05-31-2007, 02:10 PM
  #30
syndr0me's Avatar
Trader Rating: 32 (100%+)
45mm for a 10.5?! In a sedan?
syndr0me is offline
