Help! One-way
Old 05-30-2007, 04:26 AM
H I
H I's Avatar
Trader Rating: 18 (100%+)
Help! One-way
My one-way on RDX started to free spin. Just on left hand side (3 wheel drive)
Iíve tried flush out one-way bearing with motor cleaner then used one drop of bearing oil. It came back good for about 1 lap then lost drive again.
Is there any way to fix this or do I have to buy new one-way?
H I is offline
Old 05-30-2007, 04:54 AM
Default One Way
You may need to get a new one way, as the bearing seems to be worn. It's unlikely but it could be the outdrive itself, try switching around the front outdrives and see if it's still slipping on the same side.
_pilot_ is offline
Old 05-30-2007, 06:20 AM
Oneway bearing needs plenty of oil, a dry oneway bearing will die in no time. Even a new oneway bearing will slip if there is no oil. Try some oneway oil from x-ray or serpent, add 4-5 drops per bearing.
B-day is offline
Old 05-30-2007, 06:44 AM
VooDooPH's Avatar
dont use oil... use one-way grease.
VooDooPH is offline
Old 05-30-2007, 07:44 AM
H I
H I's Avatar
Thanks for reply. I've switched out drive but same side is still slipping so it must be bearing it self.
VooDooPH what's oneway grease? Is it same as diff grease? Who sell them?
H I is offline
Old 05-30-2007, 06:41 PM
VooDooPH's Avatar
this is what i use...
http://shopping.rcmodel.hk/product_i...60b6ae10df76ee
i think HPI also has em...
VooDooPH is offline
Old 05-31-2007, 01:56 AM
H I
H I's Avatar
Thanks.
H I is offline
