Charger
Old 05-28-2007, 11:56 PM
Evilstealth's Avatar
Default Charger
I have heard that there is a charger that charges each cell individualy as well as equalizes them and discharges them (it does everything you need).
Does anyone know if this exists?
Adam
Evilstealth is offline
Old 05-29-2007, 12:25 AM
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Spintec ICC Charger...
http://shopping.rcmodel.hk/product_i...oducts_id=8384
VooDooPH is offline
Old 05-29-2007, 12:36 AM
I heard that Team Orion or one of them made one is this true??
Old 05-29-2007, 01:29 AM
R/C Tech Elite Member
nexxus's Avatar
Trader Rating: 315 (100%+)
Spintec ICC, I HAD one, cons were:
Difficult to line up to points
No motor break in
Grub screw that holds the lever in place comes loose easy
If a battery vents (as the IB cells occasionally do) it goes straight into the charger, not onto a desk as with an external charger, so bye bye charger.
I went back to the ICE
nexxus is offline
Old 05-29-2007, 02:05 AM
Default ICC
I second that, I had one that was nothing but a problem. Everything from trouble making connections, set screw on the lever loosening, cold solder joints where the tab meets the board, it was essentially a fancy paper weight. A couple other guys at my local track bought them and had the same problems, my advice is don't waste your money on a Spintec, I don't know if this is your first charger or if you already have one but I would suggest you look at the Duratrax ICE, Orion Advantage (hope I got the name right, anyways it's by orion), MuchMore CellMaster, LRP Pulsar and the new Checkpoint, these are all great chargers and varying prices.
_pilot_ is offline
