computer power supply >
Old 05-28-2007, 03:18 PM
  #16
Swamp Rat's Avatar
You need a load across the 5v output. this controls the 12v side
I use a 10 ohm / 10w wire round resistors.
You can use a 20watt 6volt lamp as well
Try
http://web2.murraystate.edu/andy.bat...OWERSUPPLY.HTM
Sparky
Swamp Rat is offline
Old 05-28-2007, 03:31 PM
  #17
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Big B
What charger are you trying to use, some like the ICE require a minimum amount of amps I think the ICE needs at least 19amps.
I run two ICE chargers on one N-power 10A power supply and I charge two LiPo packs at 5A at once and I've never had a moment's problem.
You don't need any more of a power supply than what you're going to charge at...you don't need a 20A power supply to charge at 10A.
Turbo Joe is offline
Old 05-28-2007, 03:34 PM
  #18
LogiK's Avatar
Trader Rating: 11 (92%+)
Theres our problem ^_^, We forgot the Resistor LOL, our otherone had it, we desoldered all otherwires, oh well new psu
thanks
LogiK is offline
Old 05-28-2007, 03:39 PM
  #19
which two wires does the resistor need to solder to?
koolkidd is offline
Old 05-28-2007, 04:02 PM
  #20
Big B's Avatar
Your right, the Manual says to use 12v 15 amp PS to get maximum output.
Big B is offline
Old 05-28-2007, 04:33 PM
  #21
Turbo Joe's Avatar
I want to see some 4200s charged at 15A...from a distance...LOL
Old 05-28-2007, 04:50 PM
  #22
Swamp Rat's Avatar
The 5v + (red) and 0V black
Old 05-28-2007, 06:34 PM
  #23
Big B's Avatar
Probably look something like this
Big B is offline
Old 05-28-2007, 07:16 PM
  #24
Evilstealth's Avatar
LOL!!!! My mate knew this guy that charged hes battries at 10AMPS!!! and the battrey bars glew RED!
Evilstealth is offline
Old 05-28-2007, 09:14 PM
  #25
JamesnMeyer's Avatar
The resistor is needed on older power supplies. I have two Antec PS I converted and neither need the resistor. I tried some cheaper PS but the voltage dropped below 12v when using more than one charger. Not a problem on the good units.
JamesnMeyer is offline
Old 05-28-2007, 09:26 PM
  #26
Big B's Avatar
Damn he's lucky they didn't blow, that could have caused some real damage. Did any of the solder come apart? Were the batts ever useable again?
Big B is offline
Old 05-28-2007, 11:45 PM
  #27
yea, i think its the resistor i need. ill solder it in now and see what i can come up with.
update- soldered in the resistor now i just need to have the charger inserted before i switch it on, it runs fine otherwise. thanks for the help.
koolkidd is offline
Old 06-10-2007, 07:15 AM
  #28
used my computer power supply yesterday for a 1500 lap oval enduro....
ran 3 chargers all day with an occasional 4th charger to another pit....ran the 3 all day constantly 1 tc -1030,1 ice, and 1 indy...ran flawlessly from 11 am till 6:30 pm only real cost involved was the 8 or 9 dollars i had invested in the parts for the distribution box.
ROOKIE2 is offline
Old 06-10-2007, 07:28 AM
  #29
Mr. Shookie's Avatar
I am sorry but this has been covered about thirty times.....
After you spent the money to convert your PC power supply you could have a nice small sized PS that is designed for yoru rc needs...
Here are two links..
20Amp regulated
http://www.buyreliant.com/psupplies/psv200.htm
And for $5.00 more a 30amp regulated.
http://www.buyreliant.com/psupplies/psv300.htm
both under $60.00
I have the 20amp one over two years and still perfect.
Hope that helps those who like a great deal and great gear.
-Shookie <><
Mr. Shookie is offline
Old 06-10-2007, 09:53 AM
  #30
9 dollars for a power supply that puts out 12.9 volts @29 amps...with a 5 volt and 3 volt outputs...hard for me to beat that!
ROOKIE2 is offline
