TT01R build, help confirm parts, I am a newb >
Old 05-27-2007, 10:09 PM
mhx
I tried doing as much research/search as possible so bare with me. Been reading the forum for the past 4hrs. I found towerhobbies.com very use full to finding all my parts:
These things I am sure of(should be fine):
1. Tamiya Racing Car TT-01R Chassis Kit
2. HPI Lotus Elise 2000 Body 190mm
3. Novak XRS Reversible Sport ESC
This part I am not sure if I need anything else. Do i need any of those radio crystals or is this everything?
4. Futaba 2PH 2-Channel AM/1 S3003 Servo 79
5. Sanyo AA Alkaline Battery (8)
Now for the battery? I figured the 4200 would hold the longest charge and last longer. Please confirm or should i order 2 3000's so I always have a full battery ready?
6. DuraTrax 6-Cell 7.2V DTX4200 NiMH Stick Standard
Does this charge come with all the plugs? I cant seem to find any pics of the cords so it makes me think its missing something? Will I be able to charge the battery above without needing anything?
7. DuraTrax Piranha AC/DC Digital Peak Charger NiCd/NiMH
Am I missing anything? What can you guys recommend? I plan to mess around on the road/streets drifting around.
Thanks,
Ryan
mhx is offline
Old 05-27-2007, 11:20 PM
Frost's Avatar
Trader Rating: 56 (98%+)
when u buy the radio, check that it should come with a pair of crystal (for receiver & transmitter).
4200 batts are good. Most stick packs comes with white Tamiya plug. But later, u will want to change to Deans plugs.
Frost is offline
Old 05-27-2007, 11:28 PM
mhx
it comes with crystals just confirmed... just been reading lots and didnt see it
http://www2.towerhobbies.com/cgi-bin...I=LXASX279&P=M
What about battery brand? Whats the best value for the longest charge?
What battery life can i expect on a 4200? how many mins?
mhx is offline
Old 05-28-2007, 12:00 AM
i would get a futaba 2pl insted of the 2ph its a computer am or fm radio and has 10 model memory and has alot more features than the 2ph
http://www2.towerhobbies.com/cgi-bin...=LXENN0**&P=ML
C_Suzuki is offline
Old 05-28-2007, 12:03 AM
yeah u shud get the 2pl.. and get the fm version.. its alot better than AM.
dorick is offline
Old 05-28-2007, 08:45 AM
mhx
will i get more range out of FM vs AM? 75mhz is fine?
mhx is offline
Old 05-28-2007, 09:27 AM
mhx
well i made some changes..
New radio:
2PL FM R153F 1 S3003 75 79
https://www2.towerhobbies.com/cgi-bi...I=LXNHS279&P=0
Different brand battery:
SMC IB4200 6-Cell 4200mAh NiMH Stick Pack
seems to be a better brand from readings, plus there cheaper by 5$
and a better charger
DuraTrax IntelliPeak AC/DC Pulse Charger
mhx is offline
Old 05-28-2007, 12:31 PM
I'm glad you switched batteries.
Make sure that the charger you picked can charge more than 3.5A on AC!
Yub, yub, cmdr! is offline
Old 05-28-2007, 12:53 PM
mhx
what do i need to switch to lipo batteries? whats a good battery to get?
mhx is offline
