Old 05-27-2007, 04:59 PM   #1
bikedoctor's Avatar
Red face HELP with materials for parking lot tracks.
A small group of us in Shreveport meet in a parking lot and race around cones.
What do you guys use that is easy set up (25-30min) for track corners and straights. Wood, PVC ??? Transponders are not used.
Thanks.
bikedoctor is offline   Reply With Quote
Old 05-27-2007, 07:53 PM   #2
bvoltz's Avatar
Trader Rating: 44 (100%+)
Thanks.
Over here in Jackson we use PVC, 2" inside, 4" outside. But we have heated and bend the pipe for corners.... We run 1 a month at the local Bass Pro.... Next race is June 9... Come over for some run and racing...
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 05-27-2007, 11:34 PM   #3
tpczx6's Avatar
bikedoctor
make sure to have a good outside wall wood,4in pvc for the infield check
with the fire deparment for old hoses they might want to get rid of most will give out old ones with holes use plowdiscs for corners and you will be set.also make the trip to Jackson soon as they have a great race program going.
RcAmerica--Xray---Hudy----KO PROPO USA---ORCA---GRAVITY RC
Motiv------Apexrc----- AVID
SWEEP Racing USA
Mike's Hobbyshop in Dallas (RIP)
Nor-Cal Hobbies [The Race Place]
tpczx6 is offline   Reply With Quote
Old 05-28-2007, 03:02 AM   #4
Send a message via MSN to kúv!n
Over here in the UK at my local track we use hose or thick tubing about 2 or 3 inches thick.
kúv!n is offline   Reply With Quote
Old 05-28-2007, 11:26 AM   #5
bikedoctor's Avatar
bvoltz. What is your set up time and can you post some picks of the track. I didnt see any on the website.
Old 05-28-2007, 04:32 PM   #6
bvoltz's Avatar
Setup time is all depended on the layout, two of us can put it up in 2 hours, with help faster... We change the layout every time to make fare for the people coming in from out of town.... Plus it makes you get better learning to drive and setups much faster....
Here are some pictures:
http://picasaweb.google.com/ellainec...31079519619810
http://picasaweb.google.com/ellainec...31517606284098
http://picasaweb.google.com/ellainec...33733809409298
The rest of the pictures are here: http://picasaweb.google.com/ellainec...ries2007May507
Old 05-28-2007, 04:55 PM   #7
See if you can get old fire hose from the FD.
jiml is offline   Reply With Quote
Old 05-28-2007, 05:04 PM   #8
racingboy14's Avatar
Trader Rating: 25 (96%+)
I would say wood for the outside but 2 inch pvc for the inside walls.
racingboy14 is offline   Reply With Quote
Old 05-29-2007, 04:27 PM   #9
bikedoctor's Avatar
Wow, very nice for 2 hours of work. I like the suspended timing loop.
Old 05-29-2007, 06:48 PM   #10
bvoltz's Avatar
We are moving to a tapped down loop... They hit the scoring bridge no matter where you put it... 22awg wire will work fine, I have flat tape that we tried and it worked great, it is a bit pricy at 15.00 per race day.... 22awg should be a lot less cost...
Old 05-29-2007, 07:15 PM   #11
geeunit1014's Avatar
our club has been there done that with the taped down loop.. the suspended one works better, you dont have to worry about peoples body dragging the ground and cutting the loop, it makes life easier.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 05-29-2007, 07:37 PM   #12
bvoltz's Avatar
I hear ya, but these guys hit this bridge, no matter the location, I have thought about putting inside Bass Pro , but they would hit there also
Old 05-29-2007, 07:54 PM   #13
tpczx6's Avatar
did you run some 1/12th scale over it also?
as for the bridge you need to put some post up above about 4 feet and run a wire to hold the middle up It keeps it from saging
SWEEP Racing USA
Old 05-29-2007, 11:03 PM   #14
chicagokenji's Avatar
We use noodles I got from the dollar store at a buck a piece:
http://www.nepoolstore.com/images/NT...e_captions.jpg
and 3/4 inch 10 foot lengths of PVC pipes.
the pipes slip into the noodles, and I use small sandbags to hold them down where needed. duct tape where needed to hold noodles to pipe where they get hit alot.
a 80x50 track can be setup in about 1/2 hour
Use a rolling garbage can to store the sandbags and wheel it around to drop or pickup sandbags.
Cheap, and efficient.
Won't work to keep vehicles from striking spectators though. A car can jump the outside edges...but that's not an issue for us.
chicagokenji is offline   Reply With Quote
Old 05-30-2007, 07:55 AM   #15
bvoltz's Avatar
What works very well keeping the cars from hitting the scoring loop, is 25 lbs dumbells.... I place them 2 to 3 feet in front of the bridge poles and they do not hit the bridge... But it sure can tear up a car... so I'm looking for something else now....
Temporary Parking Lot Tracks genesisG4 Nitro On-Road 9 03-31-2008 06:27 PM
Best materials to get? milen Electric On-Road 10 11-27-2005 11:33 PM
Materials used in RC Cars. Dragon Nitro On-Road 4 06-20-2005 12:28 AM
Parking Lot Track materials Jasonchi Racing Forum 3 08-14-2003 01:00 AM
Set up for Parking Lot Tracks using Rubber Tires No Gas Nitro On-Road 7 07-27-2002 01:26 AM
