Insane Speed Run car almost complete
#106
That's Great, them guy's know what they are doing. I really do hope your car get's to break a new world record this year. I think 200+mph is possible for that car. How's the body coming alone? Did you get to do any more testing since the last video clip of your first test drive? Or when will you do your next test run? Take Care...
The body is all done, but I am waiting to get the correct mounting hardware. I am using button head screws to mount the fiberglass body to the chassis. I am also waiting for a shipment of foam to come in so I can cutout the rear aerodynamic fairing/diffuser. Once the fairing is done, then I can attach the vertical stabilizers. Thats when all the aerodynamic components will be done and I can start doing some real high speed runs. I also have a Futaba 2.4ghz system on order and should be in next week.
#107
My friend, Matt Shumaker, is also working on an Insane Speed Run car. He has done a TON of testing (multiple 100+ mph runs in one day), and this morning he said this about these high speed cars:
Matt is at about 4.5 hp. I am using a Neu 2215 on 12s. If I pull 130 amps, I will be up at 5300 watts, or about 7 hp. I wonder if there is indeed too much power? I am not going to let this distract me from my testing. I may find a way to control all this power.
Oh, I just got in from some test running at 6AM before traffic built up on the road. I have come to a very interesting conclusion-------------- It is indeed possible to have too much horsepower. I am up to 4.54 HP (I keep squeazing a tiny bit more here and there) and the car just won't hook in the distance I have to work with. I ramp the car up to 85mph, then sqeeze the throttle and the tires smoke. They don't just spin, they SMOKE! I also ran off the road twice and rolled the car. One roll gave me over 18Gs of load! I torn off the chin spoiler on my body in one wreck. That is fine because I want to lengthen it for more nose downforce and I will make Lexan side dams that are larger than my CF dams for more rear downforce. These changes are needed for more traction and more straight line stability. I also need to get my high end gyro fixed. This gyro is not happy above 100 and my steering "Feel" goes completely away at that speed. My other gyro never felt vague as this one does at super high speed.
Anyway, this top speed thing is really alot harder than it looks. I know I have the horsepower and aerodynamics for EXTREMELY high speed, but I am overpowering my street and even my radio. My Eagle Tree is picking up alot of glitches even though they are not coming through my ESC and servo.
At any rate, the driveline held up, the power system held up, the chassis and all other components help up fine. I just need to get he power to the ground and regain my straight line tracking.
Oh, have been nervous to run the car on this street with so much power, weight and speed. That is a problem as well. I need a better place to run.
Matt
Matt
#108
Here are the clouds rolling in:
This is John's car checking out the running surface:
This past weekend was pretty much rained out. John and I did get to go out to the testing area (Best Buy parking lot). We got a couple runs in but after 5 min it started to pour. This weekend looks promising. Much better for testing.
I got my new Futaba 3PM 2.4ghz transmitter installed. I plugged everything in but now I am having problems with the throttle again. It doesn't sense neutral. I have to hold the brake to keep the car from rolling. I am trying to set it up so it doesn't do this. I also installed much stiffer side springs on the suspension. I was using the silver 8lb/in springs before, now I am using the copper 16lb/in springs. This drastically improved the way the car handles. With the added weight of the extra battery, the car would want to keep swaying back and forth and never go in a straight line. With the stiffer springs, this has almost disappeared.
#109
...we want video...........
#110
lol, this is the only video I got so far:
http://fastrc.blogspot.com/2007/06/v...run-of-x2.html
There will be more videos to come. Hold your horses.
#111
B4maz the stiffer the spring rate the more stable it will be( softer unstable ).
Also note driving the car without the body will make it drive awkard! I would bet it might feel just like a 1/12th scale 6cell mod pancar without the body !!
Crazy fast, but very unstable to drive because of no areo downforce.
Also to your friend with the TC3 the car might be suffering from the torque steer due to it being a shaft car. That is one of the reason's associated scrapped the drive shaft for belt. Once you start putting more power thru the drive train than what a 19t produce's the problem is amplified.
He also needs to go up on spring rates also, he has to much preload on the springs to get clearance. He also might have spring bind, which causes erratic handling.
Those tires he is using ( look like oval radials )need heat in them to work, thats why they are used on high bank oval tracks to reduce traction "rolling resistance " instead of making grip. They have a very stiff side wall and dont shred..
What he needs is a tire that well give more forward bite " acceleration traction". Foam tires may be the only thing that will (may up to ? speed) work. Thats what all the drag racers use, they don't use radial at all!!!
You might want to add some VHT to the surface for the length of your test track. I think they held the speed run on a drag strip with tons of VHT and rubber laid down from the full scale cars. Dirty parking lots dont help unless you blow it off and prepare it a little. The Vht helps to keep the sand from being a problem.
Just trying to help, your car and John S's car are really nice hotrods. Even though I am a hard core racer I really do enjoy reading these threads because this is what this hobby is about " tinkering " building some cool fast r/c cars.
I really find this and John's thread very infromative to read keep up the good work!
#113
#114
During my first couple of test runs, I had a lot of difficulty getting the car to track straight. It was tough to get on the throttle and get the car up to speed without the car getting very squirrelly. I decided to lengthen the chassis and make it out of carbon fiber instead of G10. The carbon fiber has much stiffer properties than the G10 and it seems like the chassis doesn't want to warp as it did with the G10. This lets the suspension do its job.
Here is the new stretched carbon fiber chassis next to the old G10 chassis. The new one is 50mm longer in the wheelbase.
#115
#116
#117
...I hope you have better luck w/ the GYRO than I had some 15+ years ago.
I tried one on a really slippery OVAL track with a car we were NOT allowed to run a wing or spoiler on. This thing was AWESOME in the corners at self correcting and keeping me from spinning...but MAN did it SUCK on the straights.
It would "HUNT" on the straights - making the car swerve back and forth quickly...like it was nervous.
Finding the PERFECT balance point was difficult with the chassis sitting so low. And finding the perfect mounting location almost needed to drop below the chassis (Which I had thought about raising the chassis high enough, and cutting it so the GYRO hung down through the chassis.) After 2 1/2 months - I gave up trying while I still had HAIR.
#118
#120
This is a crude test prototype of the body and wing. The body is made from fiberglass. The body attaches to the chassis with button head screws on the sides. The wing is an inverted NACA 9509 airfoil section. I made this wing in college for wind tunnel testing.
Here is a link to the video
The weather held out for John and I to do some testing. There are a couple changes I made since the first ground test. I made a longer chassis out of carbon fiber instead of G10. The G10 chassis was my prototype chassis. I used it to place my components and see if the layout was correct. I found that the car has too much over steer. I have been trying to remedy this problem with much stiffer springs in front. This did help a bit, but I found that carbon fiber has a much better resistance to a torsional load than G10. This means that the chassis bends less and the suspension can do its job more effectively.
The tests didn't prove as promising as I would have liked. I still cannot get my speed up above 30 mph. The steering is way too sensitive and it makes the car spin out. It feels like significant over steer. You can see this in the video. Right at the end my car wanders towards John and I almost hit him.
My new Futaba 3PM 2.4GHZ radio does not have nearly as much range as my very old Futaba 3PK PCM system. The 3PM gave me only about 400' of range. Very disappointing. I was hoping for much more.
After my disappointing testing on Saturday, I also didn't have a very good day today (Sunday). I was testing different front camber/caster settings to help remedy the over steer problem. I go and test a camber change, stop the car, make another camber adjustment, then I go to turn the car on and now my speed control will not arm my motor. I am not sure what the problem is at all. I tried to recalibrate the radio, I tried my old radio and I still cant get it to arm the motor. So at this point I am out of commission until I fix the speed control. Joe Ford, any suggestions?
