Old 05-27-2007, 01:44 AM   #1
Default few questions
ok,
i just need some answers to a few questions.
1- im running an fk05 and when meshing the pinion and spur gears it binds to an extent, you can hear the two meshing whilst racing, almost like a grinding noise when racing. now ive tried different meshes and that is not the problem however im running 84 tooth spur and 20 tooth pinion, it was suggested to me that this gear ratio is way out, what are your recommendations?
2- are there any tips or tricks to get a nice speed from 540 silver can motors? not really modding the motor or anything, more just the way the car is set up.
thanks in advance
koolkidd is offline   Reply With Quote
Old 05-27-2007, 02:11 AM   #2
rcstunt101's Avatar
Trader Rating: 16 (100%+)
You wouldnt have un matching pinion pitches would u? It sounds like u could be running a 48P pinion and a 64p spur or vise versa.
Associated TC5R
Associated B4
Yokomo B-max4
LRP, Intellect, Futaba
rcstunt101 is offline   Reply With Quote
Old 05-27-2007, 02:29 AM   #3
possibly, im only knew to electric rc cars, so sorry if its a stupid question but whats the pitches?
Old 05-27-2007, 02:47 AM   #4
rcstunt101's Avatar
Correct me if im wrong but i think its the angle or material the pinions and spur are made from (Pretty sure its the angle) Anyway, if they arent matching it makes a grinding noise and doesnt mesh properly. Theres no real way to tell way pitch they are as it usually isnt writen on them. If u have a local hobby shop nearby go see them, they should be able to tell if they are not matching/or supply a pinion that does.
Associated TC5R
Associated B4
Yokomo B-max4
Old 05-27-2007, 02:55 AM   #5
ah k, i get it so there are different pinion types that fit the corresponding spur types (different pitches?).
well i wont worry about finding one to match the current, ill try find the best pinion and spur teeth numbers and pickup ones that will run seamlessly. so i spose the other question is what ratio should i run?
Old 05-27-2007, 03:02 AM   #6
rcstunt101's Avatar
What type of motor are u running? is it just a normal silver can ?
http://www.rcracing.com/Gear_Ratio_Program_1100.cfm
that is a great program that lets u put in ur spur and pinion and internal ratio depending on ur car and it will tell u ur gear ratio. I have never run silver can but im sure someone on here can tell u a sutible ratio. From there try a few combinations to make that ratio. U can also measure ur rollout but entering ur wheel diameter.
Associated TC5R
Associated B4
Yokomo B-max4
Old 05-27-2007, 03:02 AM   #7
ford_racing's Avatar
Send a message via MSN to ford_racing
The pitch is how many teeth there are per inch.
for silvercan try starting out at about a 40mm rollout
www.gearchart.com will be able to help you out
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 05-27-2007, 03:10 AM   #8
rcstunt101's Avatar
Yeah thats it, not angle.
Associated TC5R
Associated B4
Yokomo B-max4
Old 05-27-2007, 03:58 AM   #9
hmm so what would be the best ratio to be running? or what tooth numbered spur and pinions?
Old 05-27-2007, 05:08 AM   #10
Professor's Avatar
Default ratio
hi koolkid
your running at gosford or mingara arnt you ? for either of these tracks on the fk05 use either a 81 or 84 tooth spur gear & between 30 to 36 pinion gear whichever will give you between 40 to 45 rollout,these bieng 48 pitch as they seem to be more readily available than 64 pitch ones
hope this helps
prof
Professor is offline   Reply With Quote
Old 05-27-2007, 05:17 AM   #11
how can i find the pitch of a spur gear? as the one im currently running is 84 tooth and i want to get a pinion that wont cause this binding its causing.
Old 05-27-2007, 05:43 AM   #12
Koolkid,
If you race at Gosford next Sunday 3/6/07, come and see me I will give you some XRay pinion gears to go with the 84 Tooth spur you are using. These are 48 pitch gears. A simple way of telling the difference is the gaps between the teeth on the 48 pitch gears are wider apart than on the 64 pitch gears.
Anyway if you are racing next Sunday both Warwick (war11x) and I can help you out with the gearing. As the prof said earlier a good rollout for 540 at Gosford is around the 40 - 42mm.
Steve
benny is offline   Reply With Quote
hyper7 shock questions and other questions buds302 Nitro Off-Road 1 06-11-2008 12:03 AM
B4: Kit vs RTR, Questions. BelialX13 Rookie Zone 15 02-14-2008 04:57 PM
kanai diff questions and other questions famous182 Electric Off-Road 2 02-25-2006 02:19 PM
TNX QUESTIONS chrometwanks Monster Trucks 2 02-03-2006 06:02 PM
TB questions nekmiyevo2 Electric On-Road 7 08-11-2005 09:37 AM
