Old 04-16-2003, 10:32 AM   #1
jedi's Avatar
Default Motor Cleaner Substitue
Hi! What's a good substitue for motor cleaner? My local hobby shop ran out and they don't have any arriving anytime soon. Maybe there's a substitue available in a hardware or auto parts store? Any help would be greatly appreciated.
jedi is offline   Reply With Quote
Old 04-16-2003, 10:36 AM   #2
You can Auto Brake cleaner
Ralf is offline   Reply With Quote
Old 04-16-2003, 10:56 AM   #3
CGR
CGR's Avatar
brake and carb cleaner are similar but much more harsh. Be careful with it as that stuff melts lots of plastics.
CGR is offline   Reply With Quote
Old 04-16-2003, 11:47 AM   #4
Lab-driver's Avatar
Denatured Alcohol works well too.
Lab-driver is offline   Reply With Quote
Old 04-16-2003, 03:00 PM   #5
brake cleaner is methylated spirits (well in the UK and most of euorpe anyway).
engine degreaser is what motor cleaner is with some lubricants added, if you mix 3 parts degreaser with 1 part wd40, you've got motor spray.
sanj
schumacher is offline   Reply With Quote
Old 04-16-2003, 08:35 PM   #6
Send a message via ICQ to uppy
General Motors Vehicle Care brake parts cleaner works very well although I'm not sure if it's available all over. its not as strong as say STP brake cleaner or gunk brake cleaner which will eat most plastics in no time. this stuff is pretty tame but does a good job with cleaning. just remember to relubricate bushings/bearings after you're done
uppy is offline   Reply With Quote
Old 04-16-2003, 09:28 PM   #7
Johnny J's Avatar
I use an electronic cleaner. It evaporates very quickly and is very cold but it works great
Johnny J is offline   Reply With Quote
Old 04-16-2003, 10:30 PM   #8
Speedie's Avatar
If you just want somthing to use Napa sells electric motor cleaner. So do most other auto parts stores. I use denatured alcohol in a refillable spray can I found at Harbor Freight Tools. It works great and leaves behind no residue. Never spray any sort of lubricant into your motor you want it clean not flypaper for track debris.
Speedie is offline   Reply With Quote
Old 04-17-2003, 09:44 AM   #9
jedi's Avatar
Default Refllable Spray Can
Speedie, do you know where I can order the spray can online? And by the way, does it give strong enough pressure? Thanks.
Old 04-17-2003, 10:57 AM   #10
CGR
CGR's Avatar
http://www.harborfreight.com/cpi/cta...unction=Search
Item 1102
Old 04-17-2003, 11:49 AM   #11
tufferwilde's Avatar
Thank you CGR... You are a plethora of human knowledge
Wilde
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 04-17-2003, 12:02 PM   #12
rcdougie's Avatar
Isn't denatured alcohol rough on anodized parts??
rcdougie is offline   Reply With Quote
Old 04-17-2003, 12:56 PM   #13
CGR
CGR's Avatar
I am also a plethora of useless knowledge.
http://new.wavlist.com/movies/037/tta-plethora.wav
Old 04-20-2003, 08:16 PM   #14
Speed Demon's Avatar
maybe I'm off topic...
how can we make our stockers run faster????
I saw a guy putting a ceramic grease on the shaft of the arm instead of using a bushing oil... his stock run fast..
what do you guys think?
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 04-23-2003, 05:44 AM   #15
if the parts don't have proper anodizing on them then it will pull the coating off but other than that they should be okay.
the problem with bushing oil is at high rpm the hydrostatic forces push the oil out, when the motor goes back to zero rpm the capillary action pulls the oil back in. any sort of grease is very poor at low rpm mainly cos its not runny enough but it won't escape like an oil at high rpm.
sanj
Motor Cleaner Evilstealth Electric On-Road 23 11-16-2007 09:53 AM
Motor Cleaner /Brake cleaner PRO 2 RACER Australian Racing 9 10-10-2006 04:44 AM
Ka Boom as a motor cleaner Ducati-Rider Electric On-Road 0 03-20-2006 03:53 PM
motor cleaner anthony390 Electric On-Road 43 02-05-2006 05:50 PM
Brake dust cleaner or Nitro Cleaner? TurboLancer Electric Off-Road 10 12-04-2004 05:47 AM
