Old 03-19-2008, 12:50 PM   #1411
TeamButter's Avatar
Send a message via AIM to TeamButter
Originally Posted by razzor View Post
How do you run under or overdrive ???
By tyres sizes ?? or ??
Rubber tires is done via front pulley change. You usually have to find an aftermarket pulley or adapt one to work.
Foam tires can be done like gas cars with different size tires as you had mentioned.
Butter
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 03-19-2008, 12:55 PM   #1412
XACDesigns's Avatar
Trader Rating: 15 (100%+)
Send a message via MSN to XACDesigns
ammdrew, thanks for posting hobbyplex's number. I called and got a rear gear differential...
XACDesigns is offline   Reply With Quote
Old 03-19-2008, 11:42 PM   #1413
Randy Caster's Avatar
Trader Rating: 46 (100%+)
To overdrive the car it's actually very simple. You will need a Tamiya 36 tooth diff pulley (from the 415 with every other tooth cut off) and a Schumacher Mi3 rear belt to get the tension normal.
The Tamiya pulley does use 10 diff balls rather than 8, so you'll need a couple extras.
Old 03-20-2008, 12:31 AM   #1414
razzor's Avatar
Would you use this pulley up front or rear ???
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 03-20-2008, 01:07 AM   #1415
TeamButter's Avatar
razzor- You would use that pulley in the rear for overdrive. I have used a larger pulley in the front for underdrive. I am not sure if Randy dremels his pulleys to remove every other tooth like I used to with the Xray, but you can buy a Tamiya pulley that has the 36 tooth diameter but only has 18 teeth.
Old 03-20-2008, 02:11 AM   #1416
razzor's Avatar
interesting guys, thanks.
Would you worry about what % of overdrive you run ???
Overdrive is popular for gas onroad but didnt expect much use in electric onroad.
Under what conditions or for what reasons would over drive be favoured ?
Casterracing ZX1.5R
Old 03-20-2008, 09:31 AM   #1417
Actually you would need to run that pulley in the rear to achieve overdrive. I'm not sure if their spool pulley is the same mounting diameter as ours, but you could make one fit for underdrive.
Old 03-20-2008, 09:33 AM   #1418
One more thing, honestly it seems like 95% of the people who have tried my overdrive setups will overheat their tires because they are very aggressive. It's helped me to crank out some fast laptimes at certain tracks, but if your not careful you'll end up going slower overall if you overheat the tires early enough in the run.
Old 03-20-2008, 10:42 AM   #1419
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Overheating tires in warmer weather is where the issues came up for those trying to immitate the overdrive master, Randy Caster.
Maybe not using front tire warmers, and slightly changing front settings to reduce front bite/traction will help, in hot weather.
Butter: Maybe front overdrive will be a good thing to try Wednesday nights at MDI with the good traction and cooler temps.
yyhayyim is offline   Reply With Quote
Old 03-20-2008, 12:03 PM   #1420
Actually I've heard of it happening on carpet as well, but I ran it at the IIC with no problems...
Old 03-20-2008, 10:53 PM   #1421
Moderator
pc9840's Avatar
Send a message via ICQ to pc9840 Send a message via AIM to pc9840 Send a message via Yahoo to pc9840
SER401112-Rear Solid Axle Spool
When would you run a spool in the rear? Maybe I am missing something.
[email protected] <><
"The minimum wouldn't be the minimum if the minimum wasn't good enough"
pc9840 is offline   Reply With Quote
Old 03-20-2008, 11:09 PM   #1422
TeamButter's Avatar
I can't imagine a situation where that would be beneficial on an electric sedan....
Old 03-20-2008, 11:30 PM   #1423
Suspended
Trader Rating: 28 (100%+)
Drifting. Seriously.
racenut123 is offline   Reply With Quote
Old 03-20-2008, 11:48 PM   #1424
And drag racing!!!
Old 03-21-2008, 02:40 AM   #1425
razzor's Avatar
Drifting definately.
spool in the rear with oneway up front.
Casterracing ZX1.5R
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
