Old 03-15-2008, 05:57 AM   #1351
XACDesigns's Avatar
Trader Rating: 15 (100%+)
Send a message via MSN to XACDesigns
Why so long to get your kit?
XACDesigns is offline   Reply With Quote
Old 03-15-2008, 10:48 AM   #1352
UK.hardcore's Avatar
They dont have the S400 in stock in Holland, as i live in Belgium it goes from Serpent strait to the store's.
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 03-15-2008, 04:51 PM   #1353
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I'm sure you could order it overseas and get it shipped there, I know lots of USA based shops will ship overseas.
Old 03-15-2008, 08:02 PM   #1354
where is the best place to buy a kit? (cheap)
flbugboy is offline   Reply With Quote
Old 03-15-2008, 08:53 PM   #1355
TeamButter's Avatar
Send a message via AIM to TeamButter
Come on John!!! Sell one of the 300 other cars you have and get a new one!!!
Let me see what MDI can do on a new one for you. I always wanted to be teammates with you...."RAFFLE TICKETS!!!!"
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 03-16-2008, 05:49 AM   #1356
XACDesigns's Avatar
Old 03-16-2008, 08:33 AM   #1357
Kschu sir, I am using IB 4600 5 cells on my s400. Got a 3.5 bl Novak velociti motor and my fdr was dialled to 8.9( if am using 6 cells/lipo orion 3600 race spec- fdr would be 10.10). The IB4600 is a lot more better than the 4200 in punch and runtime. For the last club race with 5 mins qualifying, the pack drained almost half as i have noted in my muchmore charger in between heats... Are you running the 4600IB already?
Doc Rhoby_1257
RRR Racing Team= [Kyosho V-One RRR WC Evo] [Novarossi] [Serpent] [Tamiya] [Airtronics M11 2.4 ghz] [Nosram] [LRP TC Spec]
[Mugen MBX5T Prospec] [X1XCR Pro Jammin Buggy] [ Hobao hyper 8.5 Prokit Buggy]
Rhoby 1257 is offline   Reply With Quote
Old 03-16-2008, 12:39 PM   #1358
Cool
Thanx Butter, but I just counted and I only have 289! Problem is only half of them are new and in the wrapper. Any help you could spare a poor old middle-aged racer like me is greatly appreciated. By the way I'm working on some new and improved "team" raffle tickets.
Old 03-16-2008, 04:45 PM   #1359
Trader Rating: 20 (100%+)
Originally Posted by TeamButter View Post
Ryan,
I have been running 4 gears in both 13.5 and 10.5. I do not think there is a measurable advantage to running just 2 gears. In modified you MUST run the 4 gears as the power from the motors can damage the diffs and/or cause them to not last long.
As for the wt fluid to use.....that is very track specific. The thinner stuff works better on low bite tracks and if traction gets really high (not very common on aspahlt) use heavier fluid. I would recommend not going heavier than 7-10k and probably 3-5k is a happy medium.
Good luck and hope this helps.
Butter
I got my gear diff at the Snowbirds from Hubert and it only has 2 gears, I don't have the other 2 to put back in. But he said that they only run 2 gears in there's and they run mod. I'm pretty sure that Billy only runs 2 in his also. Since I'm stuck with only 2 gears what fluid do you reccomend.
Ryan
TLR 22 3.0
TLR 22-4
Cooper Motorsports
R.Fenstermacher is offline   Reply With Quote
Old 03-16-2008, 06:50 PM   #1360
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
thanks bro rhoby for ur infos, i'm orderin 2 pack ib4600.. hopefully it's arrive b4 my race this coming friday...u r using orion lipo 3600 on d s400 ??? it's fit perfectly??
bro butter, y'day i tried 4 deg hub n rear i put 0.2mm spacer on d toe block...i able to clock 18.48sec/lap which it's break my previous record on stock 23t race 18.67sec/lap....but due to d tyre overheat (32r sorex) i unable to increase d total lap....this coming friday race i will be using 36r tyre...hopefully i able to achieve 17laps....
Give the best while u can !
kschu is offline   Reply With Quote
Old 03-17-2008, 05:05 PM   #1361
TeamButter's Avatar
Ryan
Ryan,
I assume you are running asphalt...if you are and the traction is decent start with 5000. If you are having problems with traction at that pont back down to 3000. The 2 vs. 4 gears certainly frees the diff up so a little thicker than normal is recommended.
Old 03-17-2008, 06:44 PM   #1362
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
Team Molzer Mowery Racing did very well at the 08 carpet nats.
Serpent driver Billy Easton put the S400 in the Show for Mod Sedan, with a high finishing spot of 2nd and a final of 6th.
MMR Drivers Jari and Mitch put the S400 in the big show for 13.5 rubber.
MMR Driver Tony had some less luck in quals but put on a convincing show dominating his main.
Setups will be up on Molzer Mowery's site as soon as everyone gets home and settled.
Drivers Mike, Allen and Conner also did a excellent job in there mains and many congrats for a excellent performance. We will all have to watch out as conner will soon be teaching all of us how to drive.
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 03-17-2008, 06:48 PM   #1363
TeamButter's Avatar
Congrats to Billy and all Serpent USA drivers that attended the nats. I hope to meet you at either the Reedy race or Asphalt nats.
Butter
Old 03-17-2008, 09:59 PM   #1364
Kschu bro, if you plan to use 3600 orion lipo race spec, you need to do some machine shop works... Go to a nearby machine shop to drill the motor mount bulkhead of the upper deck so that the rear upper portion of the orion lipo will fit in the battery slot.
I had already done that along with my friend Miguel here in Manila. He is using the orion 3600 lipo race spec without hassle while I am using IB 4600 but I had my orion also 3600 which I am planning to use when the father of Masami will visit us here in Manila this coming March 30...We race last weekend with promising performance of the s400...
So, your considering of using the lipo 3600 also?
Are you using gear diff or the ball diff? Right now were using the ball diff here though some guys were on gear diff already but haven't heard a comment about gear diff so far. My problem is that ball diff easily loosens up after race, in fact my friend Miguel needed to stop the run because his diff loosens up. Can you give us some tips about these?
Doc Rhoby_1257
Old 03-17-2008, 11:13 PM   #1365
TeamButter's Avatar
Hey guys here is my setup from the last F.S.E.A.R.A race here in Florida.
Butter
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
