Old 03-10-2008, 02:44 PM   #1306
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Randy,
I did not try any lighter fluid ( running 5k ). My opinion was the dall diff allowed for less wheelspin due to the lower traction. When the traction was little bit better, the car got off the corner better with the gear diff.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 03-10-2008, 02:59 PM   #1307
TeamButter's Avatar
Send a message via AIM to TeamButter
Randy- the Gear diff has no slip when compared to the ball diff. I went to the ball diff when it felt like the rear end of the car was washing out and it certainly made a big difference. The gear diff works better in high bite or at least medium bite when you aren't struggling for bite and you can afford to have the car launch of the corner with no slip.
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 03-10-2008, 03:07 PM   #1308
XACDesigns's Avatar
Trader Rating: 15 (100%+)
Send a message via MSN to XACDesigns
yeah Butter, I agree about the traction coming up like crazy! I couldn't believe that. I got used to the car not having much then the main had a lot more!
I also noticed my front wheels moving around a lot when I was coming through the sweeper on the 3rd qualifier. When I got done marshalling I took the car over to the pits and my servo saver nut was loose. Put some threadlock on it and tightened it up and my steering improved dramatically....go figure
XACDesigns is offline   Reply With Quote
Old 03-10-2008, 03:23 PM   #1309
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by Steve Weiss View Post
Randy Caster,
Congrats on the new ride... how come I had to come onto the internet and find out two days later instead of being told in the hallway or the kitchen or something?
haha, honestly, when was the last day I saw you?? Our work schedules are like the exact opposite times right now.
Old 03-10-2008, 03:25 PM   #1310
TeamButter's Avatar
Yeah I had that happen and Tim had told me to put some thread lock on it....problem solved!!
Randy and Weiss share living space? Oh boy....hey Randy has Steve let you use his Atlatl? LMAO!!
Old 03-10-2008, 03:28 PM   #1311
Originally Posted by TimPotter View Post
Randy,
I guess I've never run a gear diff in a TC, so I don't really know how the feel will be. I figured it would always be better to have more straightline acceleration but I can see where the slip of a ball diff would help on the track conditions you guys raced on..
Old 03-10-2008, 03:30 PM   #1312
It's the Numan, Weiss, Caster house.. I don't think I've heard the Atlatl story??
Old 03-10-2008, 03:49 PM   #1313
TimPotter's Avatar
Wow, sounds like you guys are married....
Old 03-10-2008, 04:37 PM   #1314
TeamButter's Avatar
One of many you haven't heard i'm sure!! LOL!!! Give me call later on my cell..
Old 03-10-2008, 09:51 PM   #1315
Just got back home, gonna head to the jacuzzi for a while, but I'll hit you up tomorrow rather than calling at 1am your time, lol.
Old 03-10-2008, 09:55 PM   #1316
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
hi guys, u guys race use ib4600 battery ????
any complain for this battery so far ??
Give the best while u can !
kschu is offline   Reply With Quote
Old 03-10-2008, 11:26 PM   #1317
zacabrandy's Avatar
I finally had a look at this car on the weekend.
Looks nice and it certainly appeared to be working quite nicely for its owner, however my big concern is it is apparently quite brittle from all reports.
Belts, dog bones and CV's seem to be far too easy to break. The 400 running on the weekend dropped or snapped a pin that holds the cv together and apparently the rear belts are breaking all over the place.
Are these concerns being addressed as I really do like the over all design of this car.
Also what is the wrenching like on this car, is it easy to change spurs, diffs and pinions etc, say like the Mi3? and with the 17.5 brushless motors requiring 50-60mm roll out will this car accommodate the spur/pinion combinations that would be required?
Aaron
zacabrandy is offline   Reply With Quote
Old 03-11-2008, 07:57 AM   #1318
TimPotter's Avatar
Aaron,
From talking with Paolo, the things the team drivers have discussed with him are being addressed in Holland. As far as the belts are concerned, this seems to be directly related to the Gear Diffs in high traction situations, turning your brakes down, and running the belt tight helps a bunch (again they are working on a solution for this too).
The car is relatively easy to wrench on, spur gear changes are not the same as the Mi3, but are the same as the current crop of cars that are configured similar. I can say I have run my FDR down to about 4.5, and there was room for more....
Old 03-11-2008, 08:11 AM   #1319
Orion 4200SHO Great runtime, serious punch, and most importantly no bad cells...
Old 03-11-2008, 12:01 PM   #1320
TeamButter's Avatar
Aaron,
adding to what Tim posted. The issues you have pointed out have been addressed and improvements have been made on both materials and design. The CVD pins is an issue that happens to most cars using that design. A simple solution that I use is to file a flat spot on the pin and be sure to use thread lock. That will solve that problem. As for the belts, a new material has been used for the next batch of belts that seems to greatly help with this issue will be released soon.
It's a work in progress as this is Serpent's first attempt at an electric anything and the factory is really listening to our input so the improvements that have to be made to the car to make it better are already under way.
There should be a few new parts released end of April beginning of May that will be real nice!!
Butter
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
