Old 03-03-2008, 08:57 PM   #1261
corallyman's Avatar
Trader Rating: 99 (100%+)
Butter,
Thanks for posting the setup. What body did you use? Also on the shocks is that 1 hole open or 3 open? Finally that is 48 pitch on the gearing, correct?
Thanks,
Steve
corallyman is offline   Reply With Quote
Old 03-03-2008, 09:24 PM   #1262
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
I can answer for Butter... He ran a regular PF Mazda 6 and that is 64p gearing. 3 hole open if I recall from our discussions.
I ran almost the exact same setup, but went with Yellow springs all the way around. and litlle more droop in the rear.
Mike's car was phenomonal in the high bite. Like I have said in the past, our home track is very special, and when the traction is up... it is UP.... We have tires rip off the bead.... not just unglue, but the sidewall rips from the bead, leaving rubber on the bead...
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 03-03-2008, 10:38 PM   #1263
TeamButter's Avatar
Send a message via AIM to TeamButter
Thanks Tim.....
Corallyman- Tim is correct..it was three holes open...I never know exactly how to indicate the pistons..should I make the ones I used black or the ones I didn't use...LOL!!! I had the same problem with my Xray setup sheets!
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 03-03-2008, 11:30 PM   #1264
corallyman's Avatar
Thanks Tim and Mike, all is good.
The 3 open/3 closed is very confusing sometimes. I used to have that issue with the xray setups too when I ran that car. Thanks for the answers though. Is there a write-up on the series that you guys race in. Being up here in cold Washington our outdoor season hasn't started yet.
Thanks,
Steve
Old 03-04-2008, 08:09 AM   #1265
TeamButter's Avatar
Steve-Here is the write up on Serpent's site....
http://www.serpent.com/news/12442/S4...te-Series.html
and the site for the series is www.fseara.org
Not sure if you race with Peter (porno), Garrett,Peeler or Korey H, but if you do tell them Butter says "what up?"
Old 03-04-2008, 10:47 AM   #1266
Rogier's Avatar
Originally Posted by Geezatec View Post
Ordered one last week From www.molzermoweryracing.com. You are in Europe they will do International shipment. Or go to Serpant websight a go the North America. MMRacing websight go to shop and go to serpent parts. They have 'live' inventory, if they have it, will say Add to Cart.
Good luck! I when to MMRacing it is in stock!! part # 401110
Been on the site and mailed with Andrew... too bad... no more stock...
Anybody who has other suggestions to get the one way??
Rogier is offline   Reply With Quote
Old 03-04-2008, 01:25 PM   #1267
You could try Elite RC in the U.K, although you will need to phone them. I ordered one and it arrived today.
www.eliterc.co.uk
Remembering it's a u.k number for you; drop the 0 from the front and add 0044
shawnh is offline   Reply With Quote
Old 03-04-2008, 02:09 PM   #1268
corallyman's Avatar
Thanks for the links Mike, good reading. Yep, I race with all those guys and good friends with them all too. I was a Br00d guy for awhile. Peter and I even trained Garrett (Gert), we tought him everything that he "doesn't" know. Which is alot!!!!
Steve
Old 03-04-2008, 09:24 PM   #1269
TeamButter's Avatar
Steve
LOL!!! Sounds like fun...Garrett is probably the single largest consumer of Monster Energy drinks in North America....
Glad that you are running the car...you won't be dissapointed!
Butter
Old 03-04-2008, 11:50 PM   #1270
Geezatec's Avatar
new part#401104 1-way set mid shaft Would take the place of the 1-way axle assembly. Cheaper and does the same thing as a 1-way axle.
Geezatec is offline   Reply With Quote
Old 03-05-2008, 12:25 AM   #1271
UK.hardcore's Avatar
You dont get the exact same with the center one-way.
You do loose the front brakes tough.
UK.hardcore is offline   Reply With Quote
Old 03-05-2008, 01:57 AM   #1272
yeahjamal's Avatar
Send a message via Yahoo to yeahjamal Send a message via Skype™ to yeahjamal
hi there..
i am YJ frm malaysia..i am a proud S400 owner..(just got it 1 month ago)..
but i havent tries out the car yet..seems this thread can help me out on few of the tweaks..what is the best setting for a fast track curcuit? can any one help me
BEST REGARDS
YeahJamal..
__________________________________
Man can believe the impossible,
but can never believe the improbable
i am powered by :
S400 / ARD R2 / TopToys CG60 BL ESC / SP 11.5 t / Sanwa M8 DSM /
Sanwa #ERG-VR / LRP Pulsar 2
yeahjamal is offline   Reply With Quote
Old 03-05-2008, 06:03 AM   #1273
razzor's Avatar
Yj set the car up as per the setup in the manual.
It will be a good reference point for you to work from and in most cases is quite good.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 03-05-2008, 10:55 AM   #1274
XACDesigns's Avatar
Trader Rating: 15 (100%+)
Send a message via MSN to XACDesigns
Put the spool back in my S400 for running on asphalt this weekend in the FL state series...can't wait!
XACDesigns is offline   Reply With Quote
Old 03-05-2008, 11:15 AM   #1275
Geezatec's Avatar
Useing 1-way diff or 1-way mid shaft, you do loose 50% of braking. loose100% of frt braking. Braking is all at the rear wheels. Good on asphalt, carpet depends on driving style and aggressiveness.
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
