Old 02-02-2008, 09:04 PM   #1156
DaveW's Avatar
...yeah, you find them parts, you let me know too...
DaveW is offline   Reply With Quote
Old 02-02-2008, 11:42 PM   #1157
RocketRacer's Avatar
Originally Posted by spurgear View Post
Ran my car on saturday first time. Ran it in an outlaw race with other cars. I was dissappointed with the performance. I ran the stock setup with 37 shore 26mm foams all around. Car was the slowest from the start. Also with the front spool the car didnt want to turn. It was like rocking during the turns. The back would also give way when i tried to turn in the sharp turns.
Howzit Spur,
the 1st problem of oversteer (back stepping out) during cornering is definitely cause by you running 26mm tyres all round. with foams on asphalt, you have to run wider rears. usually 26mm Front and 30mm rear, or you could run 24mm front 28mm rear. if you have the wheels touching the steering arms or rear shocks, then runn spacerson the wheels hexes or run thicker wheel hexes. bear in mind that bu doing this you will be altering th etrack width and maybe you could uses different width suspension holders to maintain track width.
things to remember when running a spool:
1. On Power steering is increased
2. off power steering decreased
3. the car is very sensitive to tyre diameter and with foams this becomes critical and can affect the handling drastically.
with the mamba 7700, you need to gear it according to the track and according to the motor temps after a full run. 200 degress F is tha absolute maximum it should run at. 180F will be alot safer.
hope this helps
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 02-02-2008, 11:42 PM   #1158
double post
RocketRacer
Old 02-03-2008, 10:16 AM   #1159
Geezatec's Avatar
Default Parts For S400
Other than Serpent USA for parts for the S400. Where in the USA can I get parts readily available for Online orders of parts?
Thanks!! Snake S400 owners!!
Geezatec is offline   Reply With Quote
Old 02-03-2008, 05:56 PM   #1160
LOW ET's Avatar
Trader Rating: 97 (100%+)
now that lipo's are legal, will serpent come out with a rear bulkhead to fit lipo batteries so people don't have to grind on anything?
LOW ET is offline   Reply With Quote
Old 02-03-2008, 06:39 PM   #1161
Geezatec's Avatar
MaxAmps 5000HV 7.4v w/o grinding the bulkheads. 7.4v lipo's legal with ROAR. MaxAmps 5000 height is 18mm compared 24mm with NiMhs. With shrink wrap only. But with ROAR specs lipo's has to be plastic covered. Still has enough room to fit w/o grinding. Remember ROAr just legalized lipo's 2s @ 7.4v only, I believe.
Old 02-03-2008, 08:31 PM   #1162
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
http://molzermoweryracing.com/dealer.html
Any of our dealers can get you parts, most S400 parts are in stock, from c hubs to gear diffs, to the new Alloy C-Hubs.
Or have your local hobby shop call us and we can get the parts to them right away.
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 02-04-2008, 11:05 AM   #1163
Geezatec's Avatar
Looked @ Molzermowery and Emailed my LHS to see what they're stocking of parts and availability. looking for local service and how long they deliver, at least 5 day turnaround or less. UPS in same State or city is usually next day.
Old 02-04-2008, 02:48 PM   #1164
XACDesigns's Avatar
Trader Rating: 15 (100%+)
Send a message via MSN to XACDesigns
Ran the car in 27t rubber at the snowbirds. I had the yokomo one-way in the front and the car's steering was awesome! I had a problem with the driver though I kept turning a bit too early and a tap at the right angle would snap the front CVDs. I only took 2 spares with me and ended up breaking 5 of them. I am going to try the tamiya ones up front with the tamiya axles as well.
Many thanks for all the help from the Serpent drivers and Tim Potter!!! They are definitely awesome and helped me out when I needed it the most!
XACDesigns is offline   Reply With Quote
Old 02-04-2008, 02:59 PM   #1165
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Was nice chatting with you...
If you run alumimum axels, run them in the rear... With a spool or 1 way, it will twist aluminum pretty quick...
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 02-04-2008, 05:18 PM   #1166
jammincrtjames's Avatar
I want to place an order for some parts, but I don't see the gear diff or the alloy c-hubs on the site based on the Serpent part number. Should I just call in my order?
NEXUS RACING www.nexusracing.com | FANTOM RACING www.fantomracing.com
ORCA www.orcarc.com | TURTLE TRAX / www.turtletraxraceway.com
"If you're not first...you're last!"
jammincrtjames is offline   Reply With Quote
Old 02-04-2008, 07:34 PM   #1167
mild seven's Avatar
Trader Rating: 63 (100%+)
Send a message via MSN to mild seven
hey
just wondering where do u guys order ur s400 parts from? cant seem to find them on any online shop yet, most places they are on back order.
thanks
mild seven is offline   Reply With Quote
Old 02-04-2008, 11:37 PM   #1168
Geezatec's Avatar
Checked through Molzermowery Dealers, LHS 5 miles away. And this LHS telling me that Serpent parts they have is on EBay!!!
Many Parts houses for Serpent S400 are on order, I'll have to wait!! Where I got the S400, parts are yet available for us serpent users.
Old 02-05-2008, 04:15 AM   #1169
ammdrew's Avatar
? they must not be interessted in helping you. Most parts are available. very few are not. Your best bet is a dealer that is close. I do understand that does not always work as well as planned though.
Old 02-05-2008, 05:27 AM   #1170
XACDesigns's Avatar
Tim, Do they make a non-aluminum axle that will fit and hold up better than the serpent ones?
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
