Old 01-22-2008, 08:46 AM   #1111
XACDesigns's Avatar
Trader Rating: 15 (100%+)
Send a message via MSN to XACDesigns
as long as it's not rubbing and it's taped in real good...run it
XACDesigns is offline   Reply With Quote
Old 01-22-2008, 10:57 AM   #1112
RC MARKET's Avatar
parts discount now !
RC MARKET is offline   Reply With Quote
Old 01-22-2008, 12:35 PM   #1113
trickd122's Avatar
Default Hard case lipo battery fit
Shouldn't it be the responsibility of the said battery manufactures to design and build packs that fit current rc cars and not the cars being re-designed/modified to have packs fit?
trickd122 is offline   Reply With Quote
Old 01-22-2008, 02:24 PM   #1114
spurgear's Avatar
Send a message via MSN to spurgear
What do u use to tape it? Also im having some fitment issues with the equipment im using. Can the receiver be mounted safely on top of the steering servo?
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 01-22-2008, 03:46 PM   #1115
terryh's Avatar
Originally Posted by jammincrtjames View Post
Which will give the most steering...2 or 6 degree?
2 degrees will give you more steering at corner entry but less mid and corner exit. 6 degrees will give you less steering at corner entry but more mid and corner exit.
I run mainly rubber on carpet and love the 2 degree hubs with 1mm kick-up
terryh is offline   Reply With Quote
Old 01-22-2008, 03:52 PM   #1116
terryh's Avatar
Use battery strapping tape, you should be able to get it from any HS. It's okay to fit the receiver on top of the steering servo.
Also, I saw your pictures of where you have dremmeled out your bulkhead and I think you may have taken out a bit to much, I'll try and take a picture of mine tomorrow and show you how little material I needed to remove to get my Orion 3200 in, I also have the battery fitted the other way round with the connectors towards the front of the car. Never had a problem with it this way, even after taking a very heavy side hit against the battery.
HTH
Old 01-22-2008, 06:00 PM   #1117
DaveW's Avatar
Um, isnt that backwards?
2 deg caster blocks with 1mm of kickup will give you 3 degrees of caster (approximately)...
DaveW is offline   Reply With Quote
Old 01-22-2008, 07:10 PM   #1118
Trader Rating: 20 (100%+)
Originally Posted by DaveW View Post
Sorry for the n00b question, but i know nothing of this car... yet. Would a rear ball diff fit the front? Are they the same? Thanx again.
Yes it will fit the front with spacers, they are not the same sze.
R.Fenstermacher is offline   Reply With Quote
Old 01-22-2008, 07:56 PM   #1119
spurgear's Avatar
HTH
I will try to look for this tape. If u have a link for it please post. Well i installed the electronics. What size pinion u use? In all this hard hits everyone is getting. Is the chassis damaged? Carbon split? I didnt apply the CA to the chassis as suggested in the manual. Also i only applied thread lock to the screws they suggested. Do u set the steering throw to all the arm permits?
East Civic 200mm
Old 01-23-2008, 12:15 PM   #1120
Send a message via ICQ to Cartman
http://www.rcracechat.com/vb/showthread.php?t=37516
Cartman is offline   Reply With Quote
Old 01-23-2008, 01:15 PM   #1121
terryh's Avatar
This is just one example of battery strapping tape http://www.speedtechrc.com/store/ebp...id=386&id=7181 like I said, you should be able to get it from any hobby.model shop, I think Serpent even do there own version.
Pinion size is dependant upon the motor and track size/layout.
I have sealed all the edges of my carbon chassis parts, and rounded off the edges. It's essential that you do this as it will prevent the chassis splitting. i did once pretty much destroy a car in an impact but in all honesty, I have taken some hard hits recently with no damage
Put some threadlock on the adjusting screw of the servo saver as well.
I set the steering to the max the arms permit at 100% on my transmitter and then adjust dual rate from there.
Old 01-23-2008, 01:16 PM   #1122
terryh's Avatar
No
Old 01-23-2008, 01:35 PM   #1123
jammincrtjames's Avatar
I need an alternative to the Serpent thrust bearing in the diff. Any suggestions.
NEXUS RACING www.nexusracing.com | FANTOM RACING www.fantomracing.com
ORCA www.orcarc.com | TURTLE TRAX / www.turtletraxraceway.com
"If you're not first...you're last!"
jammincrtjames is offline   Reply With Quote
Old 01-23-2008, 02:44 PM   #1124
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Tamiya thrust bearing is the best i've used. Article number: 9949300
Tommy Bergfeldt is offline   Reply With Quote
Old 01-23-2008, 02:57 PM   #1125
BigTrucks's Avatar
Jammin you can retain the stock thrust bearing plates ( washers ) , and use Assosiated thrust balls, and use the stock Diff bolt. Just use the kit grease (black) , then assemble as normal. I ran this for 2 weeks and had no problems, and the diff was smooth as silk. I hope this helps.
Ike Peacock
Team Driver For
Team Epic , Team Catch Me
BigTrucks is offline   Reply With Quote
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
