Serpent to 1/10th EP Touring Kit S400
#1081
I race rubber tires with Racer Z he is running 3mm of droop front and rear, and sets his droop with the blocks. I am running 2mm droop in the front and 3 mm in the rear, I set mine with out the blocks.
What rubber tires are you running. I am running Jaco 24's and Jaco 28's, I have not tried them yet but Racer Z runs Sorex 24's and said they were better. Do you run a spool, diff or oneway up front.
#1082
I would increase downstop / decrease droop on carpet. I start with 5mm Front and Rear, measuring with Serpent #1466 and #1467 at the point where setup sheet shows. In the front it could be difficult to measure if you are using a tool with shorter steps. This case you can try to do under the front outer pivot pin fixing grubscrew in the C-hub.
#1083
#1084
hey guys, do any of you know if an '08 version will be released for the S400? much like its nitro counter-parts (720 '08) with bundled upgrades?
#1085
#1086
RevMaxx, there is no 08 version that im aware of. The nitro side develops differently to the electric side of things at Serpent I believe.
#1087
S-400
What are the "breakables" for this car?
#1088
The only things i've broken on "regular basis" so far is front CVD bones and rear belts.
The suspension plastics is pretty solid, but i would always have one of each just in case..
If running the spool up front you should also stock up on some outdrives, since they wear out after some time.
#1089
I've just switched from an xray 007 to athe S400, took it for a run at one of our outdoor tracks and have to say I'm very impressed with this car, even with very old batteries my times were beter than with the xray. I was so impressed I bought another one.
Happy racing to you all.
Paul
Paul
#1090
Why is it that knowbody has the 4 degree c-hubs? Also. Which will give the most steering...2 or 6 degree?
#1091
#1093
#1094
Paul
Paul
