Old 12-29-2007, 06:28 AM   #1021
spurgear's Avatar
Send a message via MSN to spurgear
Originally Posted by spurgear View Post
Quick question. Why did the S400 kit come with a 64P spurgrear? And what will be a basic starting point for the matching 64P pinion? The motor will be a mamba max 7700 powered with a 3200 team orion lipo. The straightaway will be approx 100 feet long. Thanks
anyone?
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 12-29-2007, 09:23 AM   #1022
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Maybe because 64p is more popular overall, and has finer gearing adjustments.
I have no clue what equivilent a mamba max is to the novak brushless motor, so I cannot help you.
anyone?
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 12-29-2007, 11:23 AM   #1023
Trader Rating: 20 (100%+)
Originally Posted by TimPotter
and yes Ryan, I do remember.. I am not racing the birds this year, but I will be up there on Saturday to check the racing out... BTW, I thought you moved out of Florida, because the bunch of us from the south were getting faster.
Now thats funny. I moved because there was no local competition. I moved because of alot of reasons that had nothing to do with racing. Why are you not racing at the birds?
R.Fenstermacher is offline   Reply With Quote
Old 12-29-2007, 12:16 PM   #1024
spurgear's Avatar
What specs do u need?
East Civic 200mm
Old 12-29-2007, 02:35 PM   #1025
the MM 7700 with 7.4 lipo produces about 57000 rpm
the novak 5.5 with 7.4 lipo produces about 50300 rpm
the movak 4.5 with 7.4 lipo produces about 60700 rpm
so the MM 7700 would be about a 5 turn in comparison
Steven
Casino Kid is offline   Reply With Quote
Old 12-29-2007, 04:12 PM   #1026
TimPotter's Avatar
With what was posted, I would guess maybe about a 9.0 FDR with Rubber tires...
YYAYHIM runs the mamba stuff, maybe he has some suggestions.
Old 12-29-2007, 04:13 PM   #1027
TimPotter's Avatar
I know I know.... Not racing, because after 6 years in row, well it is time to take a break, and.... I will tell you when I see you there...
Old 01-01-2008, 06:51 PM   #1028
terryh's Avatar
I know this topic has been discussed before but I have a nasty wobble on my spur! I have checked and double checked that the grub screws connecting the spurgear holder and the pullies to the centre shaft are centrally aligned on the 'flats' yet it still wobbles, anyone have any suggestions as to what the problem might be?
I have even checked that the centre shaft is straight prior to assembly. If i fit just the bearings and the spurgear holder and locate it in postion and spin it, you can see that the spur holder is slightly out and does not rotate true, could it be that the spurgear holder itself is slightly out, this problem is driving me nuts...................
hope someone has an answer
terryh is offline   Reply With Quote
Old 01-02-2008, 01:00 PM   #1029
Racer Z's Avatar
Try using a little 300 grit sand paper and lightly sand the holder and spur gear on both sides. There may be some imperfections that may not be seen by the naked eye. If it still wobbles try changing the gear.
RC AMERICA, HUDY, XRAY, Nexus Racing, Desoto Racing, 301 Raceway(RIP). XRAY T4/NT1 coming for that #1 spot!! AKA-Melvin Aulston
Racer Z is offline   Reply With Quote
Old 01-02-2008, 01:20 PM   #1030
razzor's Avatar
My buddy had the same problem.
We checked the id of the spur adaptor and saw it was bigger than the shaft so when tightened up it was offset causing the spur to wobble and have a high spot.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 01-02-2008, 04:31 PM   #1031
I found exactly the same problem. Initially I thought it was the spur gear at fault but eventually, 3 stripped spurs later, realised the adaptor wasn't central on the layshaft.
Out of interest how have you cured it?
I ended up putting a grub screw either side and slowly tightened each in turn until very near perfect, but the weekend will tell.
Oddly the car is good at home but then I guess my carpet is far less grippy.
shawnh is offline   Reply With Quote
Old 01-02-2008, 05:15 PM   #1032
terryh's Avatar
To the best of my knowledge, no one has cured it! I have been advised as follows:
1. Use 2 grubscrews on the spurgear holder, try and get some new one's, not Serpent, and longer if possible. Set the one first which is on the opposite side to the 'flat' on the shaft and then the one onto the flat of the shaft. If your very carefull you can hopefully centrally align the holder. Also, make sure that the grub screw dosnt have a sharp point, file it flat.
2. If your using 64dp, dump the Serpent spur and use a 102t tamiya spur, far superior.
3. Keep your fingers and toes crossed and say a prayer
Old 01-03-2008, 12:15 PM   #1033
RC MARKET's Avatar
RC MARKET is offline   Reply With Quote
Old 01-03-2008, 12:26 PM   #1034
Trader Rating: 29 (100%+)
Im suprised that serpent hasnt done anything to fix that problem, the car has been out long enough now......
Mdoc is offline   Reply With Quote
Old 01-03-2008, 12:42 PM   #1035
yyhayyim's Avatar
Trader Rating: 26 (100%+)
True...the MM esc and 7700 motor can be as fast as a 3.5 motor as long as you have the right settings on your ESC and 7.4v Lipo.
Set your ESC to Med start power, and medium motor timing, and start with a 10.0 FDR. Take it for a run and see if its as fast as the other motors and, and check motor temps(try to stay below 180F).
I have run my 7700 with high start power and high timing with 9.30 FDR and its fast and ran at 177F after 6 minutes in 85F weather BUt please start out with the above suggested FDR of 9.75-10.0 and go from there, with medium start power and medium timing on ESC.
yyhayyim is offline   Reply With Quote
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
