Old 10-22-2007, 07:32 PM   #721
Trader Rating: 114 (100%+)
Foam setup anyone?
Jeff Cuffs? anyone???
Chris Furman is offline   Reply With Quote
Old 10-22-2007, 08:14 PM   #722
ill post what i ran at the iic tomorrow
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 10-22-2007, 08:17 PM   #723
Yes please.. want to run Foam on it this Friday and test the car.
Old 10-22-2007, 08:26 PM   #724
KAHUNA's Avatar
Cool
Originally Posted by Kwikvdub View Post
NP!
Kwik here you go . . . .
Serpent S400 1/10th Electric Touring Car.
190mm wide electric.
Serpent designed to highest standards.
2 belt system.
Pre-assembled alloy body quality shock absorbers.
3 sets of front caster C hubs.
Aluminium rear uprights as standard.
Aluminium motor mounts and diff housings.
Alloy rear diff and spool at front.
U/js all round.
2.5mm chassis and stiff top deck.
Front and rear roll bars in the kit.
Front axle
The car comes supplied with a front spool which has been made from hard anodised aluminium while its shape has been optimised to ensure that the part is as light as possible without compromising strength. The drive is provided through the attached pulley into the lightened steel drive cups, which are held in place using steel pins.
Serpent enters the competitive electric touring car market with the S400, which like all our previous cars, has been designed to win straight out of the box. Featuring an ultra low centre of gravity, optimized weight distribution, high performance geometry and top quality materials throughout, the S400 should see you in the winnerís circle in no time. In fact everything associated with this car is of the highest quality, from the packaging and supplied manuals, right through to the product and race support.
Rear end
The rear end of the Serpent S400 has been designed for high performance and ease of maintenance. The rear bearing blocks have been designed in 2 pieces which allows the topside to be simply removed with 4 screws, giving you easy access to the differential for maintenance or adjustment. All the parts have been machined from aluminium and have anodized in gun metal grey.
Rear suspension
The rear end of the S400 features strong 1-piece lower wishbones and aluminium uprights. As with all the wishbones on the car, the lower wishbones can be used on both the left and right sides, minimizing the number of spare parts needed to bring to the track. The rear upright features a pivot pin mounting point on the bottom and three upper camber link mounting holes for fine-tuning camber rise.
Rear Differential
The kit version of the S400 comes supplied with a lightweight and smooth rear ball differential. The diff halves are made from hard anodised aluminium which is lightweight yet extremely strong, while the use of high quality balls and steel plates ensure a long lasting and smooth diff action.
Drive train
The S400 drive train utilizes a 2-belt system with rear ball differential and front spool, while 4 CVD (constant velocity drives) transfer the power to the wheels. The motor, which is mounted to an aluminium plate, powers the main spur gear and hard anodised aluminium pulleys.
Front suspension
Similar to the rear suspension in configuration, the front suspension sports a lower composite wishbone while the upper camber adjustment is handled using a track rod which is solid, lightweight and can easily handle impacts.
Front C-hub system
A standard system on all high-end touring cars, the S400 features a front C-hub system, which is a lighter alternative to a pivot ball steering system. The car comes standard with a 4-degree caster block but is also supplied with a pair of 2 and 6-degree blocks.
Servo Saver
The servo saver on the S400 features 4 steering rod mounting points to allow the user to easily adjust the cars Ackerman. The servo saver system itself features a nut for adjusting the spring tension of the saver.
Chassis
The chassis plate has been machined from a plate of 2.5mm thick carbon fibre, which creates a perfect platform for the cars electronics as well as stiff structure, especially when combined with the equally rigid 2.5mm thick carbon fibre top deck. All holes in the base of the chassis have been countersunk while on the top of the plate, the area around the motor has been milled down to allow it to sit as low as possible. The plate features cooling holes below the motor and speed controller.
Anti-roll bars
The S400 is supplied with colour coded anti-roll bars front and rear that are held in place using a 2 piece anti-roll bar mount. The anti-roll bars are available in a number of thicknesses and are connected to the wishbones using short adjustable track rods. Stiffness is quickly and easily adjustable by changing the linkage mounting points on the lower wishbones or alternatively by changing the position of the ball joint pivot point on the roll bar itself.
RCC Shock absorbers
The RCC shock absorbers are the smoothest and easiest to build shocks ever designed. Machined from aluminium and unique in that the shock bodies only open on the bottom half, they are really simple to assemble. The result is an ultra-smooth and air-free shock absorber thanks to the self-bleeding system incorporated into the design. The shocks are supplied with 4 different shock pistons.
Another great benefit is that these shock absorbers come pre-assembled in the kit, so you need only add shock oil.
Shock towers
The Serpent S400 features 2.5mm thick carbon fibre shock towers on the front and rear of the car. Each tower sports numerous holes for adjustment of the shock absorber angle while the rear tower also acts as the mount for the rear body posts and the front tower accommodates a 3rd front body post.
CVDs
This car is supplied with a complete set of 4 high quality hard coated steel CVD shafts, which are a highly consistent, efficient and durable way to transfer all the power the ground.
Suspension brackets
For adjusting the cars toe-in and track-width, the S400 is equipped with separately mounted suspension brackets on both the front and rear of the car. Each bracket features an easily recognisable number that corresponds to the setting being used and due to the way they are mounted allows the user to easily and accurately adjust their cars settings.
Steering system
The Serpent S400 utilises a centrally mounted steering assembly that contains the servo saver and Ackermann adjustments. Controlled by a side-mounted laydown servo, the steering assembly is ball raced precision and due to its central position it is much lighter than more complex off set steering systems. The tension of the servo saver spring can be adjusted using the supplied adjustment nut.
Bumper
The front bumper has been made from a high impact absorbing foam material and is shaped to protect the entire front end of the car in the event of a crash. The bumper is held in place with a large stylish carbon plate that features the S400 logo cut out of it.
Belt tensioner
Secured to the cars top plate, this machined aluminium piece acts as the mount for the aerial as well as the cars ball raced belt tensioner.
Bearings
The S400 is supplied with high-quality lightweight bearings throughout, making the drive train very efficient and allowing it to run very smoothly.
Belts
The S400 features a 2-belt configuration with a long front and a short rear Kevlar reinforced belt that makes for a super smooth and free drive train.
Manuals & Decals
To allow you to build your car with the greatest of ease, Serpent supplies a full colour instruction manual and integrated reference guide section that contains all the exploded views and latest options. The S400 also comes supplied with a small setup book explaining how to adjust your car and a pair of decal sheets in colour and in chrome finish.
Team Scream Racing Middle River Hobbies GQ AMERICA Diggity Designs Castle Creations ✦TheRCShack✦ www.castlecreations.comwww.teamscreamracing.com www.diggitydesigns.comhttp://www.gqproduct.comMini www.middleriverhobbies.comTom Brown The Rev 7 XRAY ✦ M05 Surfs Up DudeMiddle River Hobbies
KAHUNA is offline   Reply With Quote
Old 10-23-2007, 01:11 PM   #725
Hey Jeff, How about that setup?
Old 10-23-2007, 03:19 PM   #726
what is the internal drive ratio on the S400?
Old 10-23-2007, 03:27 PM   #727
Nathan Parker's Avatar
2.187
www.gearchart.com
Nathan Parker is offline   Reply With Quote
Old 10-24-2007, 05:15 AM   #728
anyone rubber/carpet setup???
Anyone have the setup of Billy Easton in the iic? or other setup of Kastellaun race?
Ryo Saeba is offline   Reply With Quote
Old 10-24-2007, 06:57 AM   #729
Still waiting
Old 10-24-2007, 07:35 AM   #730
Still waiting
Easy there buddy, i forgot i have a real time job and i had to work late yesterday.... I'll get it up here when I get a chance...
Old 10-24-2007, 11:01 AM   #731
PDF was a liitle large will email it if requested
Old 10-24-2007, 04:40 PM   #732
jt6
jt6's Avatar
Send a message via ICQ to jt6 Send a message via AIM to jt6
I am considering getting this car and I have looked through this thread and haven't been able to determine what anyone is doing for carpet with foams for the front diff. Just some people posting suggestions. Is there a diff available from Serpent? If so who has it in stock?
jt6 is offline   Reply With Quote
Old 10-24-2007, 05:53 PM   #733
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Check: www.precisionrc.com
search for S400 and they have 4-5 pages of S400 parts
yyhayyim is offline   Reply With Quote
Old 10-24-2007, 06:12 PM   #734
jt6
jt6's Avatar
yeah, already looked there. Didn't see a diff. Anyone have any part #'s?
Can you just build up a rear diff for the front?
Old 10-24-2007, 06:41 PM   #735
Steve Bahnatka's Avatar
Send a message via AIM to Steve Bahnatka
No, The front/rear diffs are 2 different sizes.
SMC-/-JACO-/-PARMA-/-TEKIN-/-CRI
Steve Bahnatka is offline   Reply With Quote
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
