Old 10-16-2007, 04:33 AM   #646
Holmenkollen's Avatar
A heavier but correct left-to-right balanced car (weightwise) will outperfom a lighter but not left-to-right balanced car at any given day.
Itīs easy to get a car down to around 1380g but very difficult to get it balanced right with 5-cells imo.
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 10-16-2007, 04:45 AM   #647
TryHard's Avatar
Originally Posted by TryHard View Post
Tamiya ones for the 415 do.. Nathan Parker shoudl be able to confirm this (I believe the screw hole spacing is the same). Nathan asked me the other week about them, and I mentioned the brackets look very similar to the 415 ones... guess what, they are
IIRC, the 3.0 is very similar to a Tamiya 1D, and the 2.0 close to the 1B, and the 0.0 is the same as the 1XB. As a 1.0 bracket use the 1X.
This means you can use the brackets to vary toe, and track width....
the whole range of blocks go (widest to narrowest)
1E, 1D, 1C, 1B, 1A, 1X, 1XA, 1XB, 1XC, 1XD
with 0.5deg toe between each block.
In response to the previous question, for 2.5deg try 1C/0.0 or 3.0/1XA, and for 2deg try 1B/0.0 or 3.0/1X for 2deg.
N.B. Changing the rear block will narrow the rear of the car, changing the front will widen it.
HiH
Ed
Held a S400 yesterday for the first time, so thought I'd measure up the serpent blocks vs the Tamiya ones.... I have to admit, got it slightly wrong...
Seems like a Tamiya 1C is very simialr to the 3.0, the 1D is certainly wider... shoudl mean that...
Tamiya 1E = Serpent 4.0
1D = 3.5
1C = 3.0
1B = 2.5
1A = 2.0
1X = 1.5
1XA = 1.0
1XB = 0.5
1XC = 0.0
1XD = -0.5
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 10-16-2007, 10:54 AM   #648
RC MARKET's Avatar
1D = 3.5
1C = 3.0
1B = 2.5
1A = 2.0
1X = 1.5
1XA = 1.0
1XB = 0.5
1XC = 0.0
1XD = -0.5
HiH
Ed
yes i'm tested 1C = Serpent 3.0 deg ,
but if use Tamiya mount , serpent STD 2mm washer need change to around 1.75mm .
RC MARKET is offline   Reply With Quote
Old 10-16-2007, 01:12 PM   #649
Gergely's Avatar
I'm also running with Tamiya blocks in the rear. I don't think you really need the 1.75mm washers, you can adjust the play when the tightening the blocks to the chassis
Gergely is offline   Reply With Quote
Old 10-16-2007, 01:14 PM   #650
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
I have also tried the Tamiya blocks, seem to be fine with the stock spacers.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 10-16-2007, 03:37 PM   #651
Nathan Parker's Avatar
Straight fit no problems at all
Nathan Parker is offline   Reply With Quote
Old 10-16-2007, 04:38 PM   #652
RC MARKET's Avatar
Old 10-16-2007, 05:46 PM   #653
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Anyone try other hinge pins on the car? Maybe Losi Type R's Titanium nitride or HB Cyclone WCE TiNitride hinge pins?
yyhayyim is offline   Reply With Quote
Old 10-17-2007, 05:37 AM   #654
steveonamission's Avatar
Hi guys..
Been thinking of coming to the darkside and give the Serpent a shot.
Is there anything extra i need for getting it going well indoors on carpet (mainley carpetwars)
Any setups lying about
Cheers
Steve
steveonamission is offline   Reply With Quote
Old 10-17-2007, 05:40 AM   #655
Originally Posted by steveonamission View Post
Hi guys..
Cheers
Steve
Hi Steve
Car can be run out of the box just great
If you head over to racechat you will find my set up from carpet wars last weekend and John Painters who raced 19T
Any questions just ask
Old 10-17-2007, 06:27 AM   #656
Hi anyone know if Xray springs fit the Serpent RRC shocks?
Also what about the Xray shocks fitting? Reading some pages somewhere on the Serpent I did not get the impression the RRCs are quickly adjustable like the Xrays, could be wrong of course. It mentioned 4 differnet shock pistons but not sure what these do.
yellowshark is offline   Reply With Quote
Old 10-17-2007, 06:32 AM   #657
The Serpent comes with 4 different pistons 1 2 3 and 4 holes
Xray you can use adjustables and use fixed pistons
Not sure on the springs or fitment though
Old 10-17-2007, 07:39 AM   #658
TimPotter's Avatar
All of the Xray springs fit, but most of them you cannot get your ride height down below 5.5 to 6mm. Have used Schumacher, some Associated, Tamiya, Yokomo and HPI springs.
Old 10-17-2007, 07:42 AM   #659
All of the Xray springs fit, but most of them you cannot get your ride heigth down below 5.5 to 6mm. Have used Schumacher, some Associated, Tamiya, Yokomo and HPI springs.
Using the Long Tamyia springs you will also have problems with ride height
Old 10-17-2007, 10:52 AM   #660
Trader Rating: 19 (100%+)
Send a message via AIM to teammidget lilB
Heres a pic of my car with the lipo. The car ran very well and I added weight to in inside of the battery to fix the balance.
Bryan
Serpent to 1/10th EP Touring Kit S400-car.jpg   Serpent to 1/10th EP Touring Kit S400-car1.jpg   Serpent to 1/10th EP Touring Kit S400-car2.jpg   Serpent to 1/10th EP Touring Kit S400-car3.jpg
Bryan "Lil B" Ford
U.S. Army @ Camp Humphreys, South Korea
teammidget lilB is offline   Reply With Quote
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
