Old 10-11-2007, 09:49 AM   #586
Just a question...why are some considering replacing the orignal diff?
I think the only weak point on the original was the steel balls. I replaced them with the serpent ceramic ones and have had no problems with the diff running brushless motors.
Just curious??
Craig
Ya gotta love it!
Losi 8ight T ...on the way!!
Airtronics
LRP Electronics
C.Fox is offline   Reply With Quote
Old 10-11-2007, 10:08 AM   #587
jo90's Avatar
RW spur gears fit, but need you to drill 2 holes, but you could always run with just the 2 screws
Took mine out on tarmac for the first time on Sunday. Very stable, very fast, just still a little bit of learning for me to do to get it up on the pace. the car reacted well to changes made and also was very tough in any knocks it had.
Cannot fault the car
Sponsored by SerpentUK, ModelTech & MTroniks
S400 / MTroniks IP6 / Team Brood / KO Propo = Loads of fun
jo90 is offline   Reply With Quote
Old 10-11-2007, 11:25 AM   #588
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Just curious??
Craig
There's really no need to use other diffs over the serpent diff...however, I do know for fact that the Yokomo BD diffs are really, really good. They are composite diffs, so are much lighter than the aluminum diffs, and that equals less weight, less rotational mass, quicker acceleration, etc...That's the edge I'm looking for...I practice alot against Yokomo BD's, and can attest to the diff's durability. Just CA glue the diff rings to the diff outdrives, lube, assemble, and tighten all the way and then loosen 1/2 turn and you can litterally run that diff for months w/ mod motors w/o having to change a thing. They are cheaper to replace and rebuild and needed, also...
yyhayyim is offline   Reply With Quote
Old 10-11-2007, 11:27 AM   #589
THeGame's Avatar
Send a message via AIM to THeGame
You can use the Yok BD diff internals and out drives but not the pulley. You would have to use the 415pulley they are 36 teeth the stock s400s are 35 teeth. If you want to use the 36 Pulley up front you will have to file the servo saver down a bit so it doesn’t hit the Pulley. And you do have to shim the front diff so it doesn’t move. I don’t know why the front and rear diff are not going to be the same..
Team Gravity Rc - G's R/C Raceway and Hobbies - Waldorf RC - TheTrack
THeGame is offline   Reply With Quote
Old 10-11-2007, 11:31 AM   #590
yyhayyim's Avatar
Originally Posted by THeGame View Post
You can use the Yok BD diff internals and out drives but not the pulley. You would have to use the 415 pulley they are 46 teeth the stock s400s are 45 teeth. If you want to use the 46 Pulley up front you will have to file the servo saver down a bit so it doest hit the Pulley. And you do have to shim the front diff so it doesn’t move. I don’t know why the front and rear diff are not going to be the same..
You mean 35 tooth pulleys for the S400 , and tamiya 36 teeth pulleys?
would you please provide some part numbers for those tamiya pulleys?
Old 10-11-2007, 12:36 PM   #591
RC MARKET's Avatar
TA04 is 35T Pulley !
RC MARKET is offline   Reply With Quote
Old 10-11-2007, 12:50 PM   #592
THeGame's Avatar
sorry it is 35, I dont know what the part number but they are tamiya black pulleys 36 teeth.
Old 10-11-2007, 01:48 PM   #593
TryHard's Avatar
Black Tamiya pulleys are 35t, the only one that are 36t are the machine white delrin ones.
Ed
| THard.co.uk | Xray | MuchMore |
Old 10-11-2007, 02:24 PM   #594
yyhayyim's Avatar
Ed
Thanks for the help...one more thing on the tamiya pulleys: the white tamiya 36T pulleys- there's one on tower that says its 36t but its actually 18t for less friction, etc...
http://www3.towerhobbies.com/cgi-bin...?&I=LXNUH0&P=7
Will this work? Anyone test and see if this type of pulley actually frees up the car? If we were to use this on the Serpent S400, for internal ratio calculations, we look at it as a 36T or 18T?
Old 10-11-2007, 02:48 PM   #595
yyhayyim's Avatar
To make this a bit more intersting...
horizon hobbies has a 35T diff pulley for the TA05 #TAM51212, and another 35t diff pulley for the TRF 415, part#TAM51055 ...are these the same pulley or which is the one to try on the S400?
Has any one checked in Xray 34T Diff pulleys will work on the S400? I sure hope so...
Old 10-11-2007, 07:36 PM   #596
mac853's Avatar
(#TAM51212) of ta05 it's 36T not like 35T (#TAM51055) of MSX, don't confuse!
mac853 is offline   Reply With Quote
Old 10-11-2007, 07:51 PM   #597
is any one checking to see if the pulleys are the right pitch.
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 10-11-2007, 08:19 PM   #598
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
99.9999% sure that they are all 3MR pitch
Old 10-11-2007, 08:31 PM   #599
yyhayyim's Avatar
You rolling w/ Serpents, too? You know your waiting 4 the Team Majic E4
Old 10-11-2007, 08:38 PM   #600
Super Moderator
Marcos.J's Avatar
serpent is on the shelf looking at his twin brother no E4, well not for a while
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
