Old 09-20-2007, 01:44 PM   #481
CRASH's Avatar
Trader Rating: 26 (100%+)
What parts are needed to run this car carpet with foams? I presume right out of the box it would be very good for rubber tires on carpet?
Car looks very interesting.
Thanks,
CRASH is offline   Reply With Quote
Old 09-21-2007, 09:41 PM   #482
THeGame's Avatar
Send a message via AIM to THeGame
Thanks,
Out of the box all you need would be a Front Diff and some harder springs I'm running 33lbs Fronts and 19lbs Rears. Serpent USA should be getting parts inn on Wednesday so get your Hobby Shop to call them up so you guys can have spares parts..
Good Luck to all the Serpent drivers going to Vegas... CuffNizzels
Team Gravity Rc - G's R/C Raceway and Hobbies - Waldorf RC - TheTrack
THeGame is offline   Reply With Quote
Old 09-24-2007, 11:08 AM   #483
THeGame's Avatar
How did everyone do this weekend with there s400's?
Old 09-24-2007, 11:33 AM   #484
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Didnt really race, but worked on the setup a little more. Lilb and myself ran the car on HIGH bite asphalt, and as far as setups go, we have been much happier with shorter links on the car. I am really anxious for some tuning parts.
I have been using the Tamiya Roll center shims, under the suspension brackets, I highly suggest these, they come in .5 and 1mm
Has anyone run less toe in the rear, like 2.5 ?
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 09-24-2007, 11:44 AM   #485
TimPotter's Avatar
a little confused here.. but thats not hard to do...
What combination do I need with the Tamiya blocks to make the rear end the same track width, but with 2.5 of rear toe. If I read what your saying, I need to change the forward most rear block ? 1XA ?
thanks...
Originally Posted by TryHard View Post
Tamiya ones for the 415 do.. Nathan Parker shoudl be able to confirm this (I believe the screw hole spacing is the same). Nathan asked me the other week about them, and I mentioned the brackets look very similar to the 415 ones... guess what, they are
IIRC, the 3.0 is very similar to a Tamiya 1D, and the 2.0 close to the 1B, and the 0.0 is the same as the 1XB. As a 1.0 bracket use the 1X.
This means you can use the brackets to vary toe, and track width....
the whole range of blocks go (widest to narrowest)
1E, 1D, 1C, 1B, 1A, 1X, 1XA, 1XB, 1XC, 1XD
with 0.5deg toe between each block.
In response to the previous question, for 2.5deg try 1C/0.0 or 3.0/1XA, and for 2deg try 1B/0.0 or 3.0/1X for 2deg.
N.B. Changing the rear block will narrow the rear of the car, changing the front will widen it.
HiH
Ed
Old 09-24-2007, 12:33 PM   #486
THeGame's Avatar
I'm running Carpet/Foam using 2deg of rear toe with 1block in the front of the rear and the 3block in the back. I'm using one of Tamiya blocks up front to match up with the serpent 0deg block.
TimPotter are you using the spool ?
Old 09-24-2007, 01:23 PM   #487
TimPotter's Avatar
BTW,
Does anyone know when we will be getting the added benefit of Mr. Easton's asphalt knowledge ?
Old 09-24-2007, 01:23 PM   #488
TimPotter's Avatar
Yes, spool is the way to go 95% of time on our asphalt tracks down here.
Old 09-24-2007, 01:54 PM   #489
Trader Rating: 19 (100%+)
Send a message via AIM to teammidget lilB
Like potter said it was mainly practice on Saturday down at his track I ran my same set up as I posted before. One thing I have tried that I like is run 2* caster blocks with .5mm of anti squat I ran this set up in stock and mod it seemed to work really well.
Bryan
Bryan "Lil B" Ford
U.S. Army @ Camp Humphreys, South Korea
teammidget lilB is offline   Reply With Quote
Old 09-24-2007, 01:58 PM   #490
TryHard's Avatar
thanks...
Hi Tim,
Yup, thats correct.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 09-24-2007, 02:01 PM   #491
RC MARKET's Avatar
& can use BD rear diff
RC MARKET is offline   Reply With Quote
Old 09-24-2007, 04:11 PM   #492
yyhayyim's Avatar
You mean the Yokomo MR4TC BD rear diff?
yyhayyim is offline   Reply With Quote
Old 09-24-2007, 04:11 PM   #493
yyhayyim's Avatar
Bryan
LilB- When are you visiting Coral Springs track? Havent seen you down here, yet- come by sometime...we run every Sunday morning till about 4-5 PM. Hopefully Tim can make it soo, too...
So far the My S400 has worked great at our track...I plan to go up to MDI in a 2 weeks on Wednesday for testing at that track...its dialed at our track in CS and now I am just testing all kind of things to see what it can do...I hope those suspension blocks come in soon, as well as other option parts and spares...so far 40wt oil and AE 14.5lb silver springs all around has worked nicely, also. Car is more reactive but planted in rear than w/ 30wt and the stock springs. More tesing in a few days if the weather allows...
Old 09-24-2007, 04:15 PM   #494
yyhayyim's Avatar
Hey TIm- how's your spool wearing? After 9 runs, mine is like new, basically...good quality stuff here
About the rear diff thrust...will the Schumacher Mi3 thrust work?
What does your car weigh in at ready to run?
Old 09-24-2007, 04:28 PM   #495
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
shuie thrust bearing is too big
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
