Old 09-08-2007, 11:03 PM   #406
colonrc's Avatar
Originally Posted by Budman View Post
Does anyone know what Lipo will fit in the s400?
orion 3200 no mod needed.
Serpent U.S.A , Maxy's Pro Racing Fuel , Murnan Modified Motors,Nexus Racing,Mike Desing,Member of GO-R/C
colonrc is offline   Reply With Quote
Old 09-08-2007, 11:17 PM   #407
Budman's Avatar
Trader Rating: 22 (100%+)
Thanks Eddie, Are you going to make it to the race on the 16th?
I have some of the s400's in stock and a lot of parts on order so if anyone down your way need something send them my way.
Cooper Motorsports, Team Trinity, T-Rex Racing, GFRP, MSA, VBC Racing, Track Attack, Tekin and Frost-bite Graphics
Budman is offline   Reply With Quote
Old 09-08-2007, 11:28 PM   #408
colonrc's Avatar
Yes!!! I am glad you now have serpent products in stock
Old 09-09-2007, 12:16 AM   #409
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
how much for the S400 kit?
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 09-09-2007, 09:27 AM   #410
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Originally Posted by teammidget lilB View Post
Hey guys I was able to hit the track today with my S400 the car was awesome out of the box. It just needed to be fine tuned so what I changed was:
-40 wt oil
-30% rebound front and rear
-1.3mm of uptravel (chassis to floor)
-and I went added a 1mm ship to the inner ball cup of the camber link to flatten all the links out.
Right n ow I am on my way to a differnt track and tomorrow I will try:
-35 wt oil
-2* of rear tow
-and some different droop settings
I will let you guys know the outcome and how the car was if anybody has any suggestions or things they have tried post them so we can get the car perfected....After today I found that the S400 is durable and handles very well grad I got one of these cars it has huge patential!!!!!
Bryan
hey lilb your serpent looked great today!! should be real good next week at Kraceway
Old 09-09-2007, 12:30 PM   #411
RC MARKET's Avatar
Today HK IB Race S400 oversea driver was Win
used 2mm 5 cell main chassis
RC MARKET is offline   Reply With Quote
Old 09-09-2007, 03:08 PM   #412
yyhayyim's Avatar
Trader Rating: 26 (100%+)
-40 wt oil
-35 wt oil
-2* of rear tow
Bryan
Tested mine today, also...I used the box set up w/ 30WT oil all around, and used shocks #4 hole in rear, and #3 up front. The car was great! Faster and easier to drive than my Mi3(it took me a few track days to finally get a good set up for the Mi3)...the car was vey stable and was quik in and out of corners...not bad at all for the first time out w/ the car...
yyhayyim is offline   Reply With Quote
Old 09-09-2007, 07:23 PM   #413
Trader Rating: 14 (94%+)
WERE IN THE BOOK IS THE GEAR CHART I CANT FIND IT
j manikis is offline   Reply With Quote
Old 09-09-2007, 11:53 PM   #414
nikoskar's Avatar
There ias no Gear Chart in the books
nikoskar is offline   Reply With Quote
Old 09-10-2007, 01:25 AM   #415
He guys!
The inner ratio of the S400 is 2,1875....
I've tested some for Vegas and foam and right now I am using
30wt Serpent oil, with the new Serpent orange springs rear and
blue fronts...
Also I have changed the rear toe in to one degree, which was faster
on foams, as well I raised the rear roll centre by 1mm.
I used the hardest rollbar at front, rear without rollbar.
Car feels cool!
Greetz,
Markus
Speedtech RC Germany-Home of MobGums tyres
--------12scale addicted---------
Mr. Blonde is offline   Reply With Quote
Old 09-10-2007, 09:50 AM   #416
BLKNOTCH's Avatar
Send a message via MSN to BLKNOTCH
Do any of you know anything about the release of the Carpet edition? I am going to be racing here in Montreal Canada and there is nothing here yet. I did se they stated there was going to be a Carpet Model with a thicker chassis and different springs. I am also thinking a front diff would be in order.
Any Ideas??
Sean
BLKNOTCH is offline   Reply With Quote
Old 09-10-2007, 10:26 AM   #417
He Sean!
Yes, thats how it is planed....
Carpet version with thicker chassis, diff and different springs...
But to be honest, I do not know the release date.
And sure, this car will be sent to canadian hobby shops as well.
Greetz,
Markus
Old 09-10-2007, 10:39 AM   #418
yyhayyim's Avatar
You can get them for about $410-$420...its got all you need- even complete set of caster blocks- 2, 4, 6 deg...vey nice!
Old 09-10-2007, 10:52 AM   #419
yyhayyim's Avatar
What's the spring rate on the S400 orange and yellow springs?
Old 09-10-2007, 11:50 AM   #420
Super Moderator
Marcos.J's Avatar
-40 wt oil
-35 wt oil
-2* of rear tow
Bryan
try this set up lilb ! ( i ran 3.5 brushless but it should be good in stock and 19t)
front
4 degrees caster
.5 degree toe out
4.5 mm ride height
6.0 mm droop (droop gauge)
1.5 degree camber
1.5mm shims under both front and rear pivot blocks
3.0mm shim under inner camber link (long camber link)
30wt shock oil
shock lenght 66.5mm
2 hole piston
20% rebound
Tamiya Yellow spring
shock mount 3rd hole from the top
outter bottom shock mount
red sway bar
rear
3.0 degrees toe in
6.0 mm droop ( droop gauge)
1.5 degree camber
1.5 mm shim under both front and rear pivot blocks
no shim under camber link on rear hub(mount in middle hole)
1.5 mm shim under inner cambelink
30wt shock oil
shock lenght 66.5mm
2 hole piston
20% rebound
middle bottom shock mount
yellow sway bar
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
