Old 06-25-2010, 12:58 PM   #3226
ericbeenorcal's Avatar
Default color?
Originally Posted by venom54 View Post
Hi Guys,
For any one looking at placing any S400 orders soon, our site has been down due to server issues.
Hopefully up at the end of the day.
Just visit often for progress updates.
Cheers
Ren
BACK ON LINE AS OF 6.40pm AUSTEST
sup ren, hey are the steering knuckles and caps from ur site all same colors are the stock ones?
BocaBearingdePeppo
ericbeenorcal is offline   Reply With Quote
Old 06-25-2010, 04:52 PM   #3227
venom54's Avatar
Hi Ya,
Similar but slightly darker. A pic below of my car for reference.
Hope these help.
Cheers
Ren
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 06-27-2010, 01:39 AM   #3228
Default sweetness
tnx ren car looks superb!
where n what diffs r u using for the d fronts? u sell em?
r those cvd's u sell from ur site?
BocaBearingdePeppo
Old 06-27-2010, 02:46 AM   #3229
venom54's Avatar
Hi ya,
Thanks for the comments.
The diffs are, front titanium Racing spool, rear is genuine Serpent gear diff. Can't get neither any more but the Spec-R Tamiya 416 gear diff with shims will fit but has a higher tooth count than Serpent 35 tooth count. The Tamiya spool front gear assembly i think will be the best option for a front spool from what I've been told of.
The unis are Spec-R which i sell as an option and have given good reliability so far.
Cheers
Ren
Old 07-01-2010, 02:07 AM   #3230
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
Hi ya,
Cheers
Ren
Wow - car looks nice - do you sell those metal sway bar holders - if so Ill take 2 sets. Oh and just got my upper bearing caps - they look great.
Heres a pic of the new exotek top decks - just got mine today.
http://i296.photobucket.com/albums/m...rt02/004-2.jpg
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 07-01-2010, 03:37 AM   #3231
venom54's Avatar
Deck looks good. I should have mine and stock by Tuesday next week. The sway bar holders i do have in stock and are on the site marked as listed below. Good to hear the bearing holders arrived.
S400-43F bar holder front set 3 in stock
S400-43R bar holder rear set 3 in stock
Same page the bearing holders were on.
Cheers
Ren
Old 07-01-2010, 07:40 AM   #3232
wstuart's Avatar
You guys catch this one on redrc.net
Serpent are also debuting their new touring car chassis, the S401. All new down the middle, the car retains its wishbones, uprights and steering blocks but thatís about it. A new super narrow chassis is the backbone of this car, with new blocks front and rear enclosing the 2 gear differentials. The motor mounting block is also new, mounted only to the chassis plate and the anti roll bars are mounted higher, pivoting at both extremes of the car. The car is in the final prototyping stages and is seen here not in its final guise.
Anyone have a pic???
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Old 07-01-2010, 10:25 AM   #3233
MikeR's Avatar
Trader Rating: 15 (100%+)
I'm not sure if it's the Serpent or an Xray??
http://events.redrc.net/event-galler...lds/?nggpage=3
Serpent to 1/10th EP Touring Kit S400-picture-3.jpg
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆TEKNO☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 07-01-2010, 08:09 PM   #3234
venom54's Avatar
If SERPENT keep most of the suspension parts same as the S400 then the JET HOBBY alloy c hubs and knuckles will still be an option. Yeh baby i don't have to update too much. Considering i have enough to build two other cars this will make good economical sense.
Very happy indeed.....
Cheers
Ren
Old 07-05-2010, 10:20 AM   #3235
Moelec's Avatar
Send a message via MSN to Moelec
Talking
Hi everybody! Do you know if spec-r gear diff for tamiya 416 fits my s400 correctly? because his pulley is 37T, will this cause any problem?
Thanks a lot!
CSO ONE '13
Hobbyking Xcar120 ESC
Hobbyking Xcar 10.5 Motor
Spektrum DX3S
Moelec is offline   Reply With Quote
Old 07-05-2010, 06:09 PM   #3236
venom54's Avatar
Thanks a lot!
With shims it will fit but the gearing will be wrong as you will have to change the front diff to compliment the rear. Other wise it will over drive the front wheels. Not a good situation.
You might have to check , but a Tamiya front spool might fit, again shimmed.
Cheers
Ren
Old 07-05-2010, 06:18 PM   #3237
JayBee's Avatar
Trader Rating: 31 (100%+)
Nice ride venom54....the S401 is my next car
But besides looking trick....does the S400 perform and does it respond well to set-up changes?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-05-2010, 06:43 PM   #3238
venom54's Avatar
Yes, to my driving and ability it performs very well. Responds good to changes, even minor such as droop by 1mm increments and other chassis set ups, but again it has been very forgiving, even for this monkey behind the wheel!
Can't complain as I've kept the car since November 2008.
Cheers
Ren.
Old 07-05-2010, 06:53 PM   #3239
Trader Rating: 20 (100%+)
Default This is a Long Shot
I would like to try a gear diff in my car. However I am running a MI4. I was wondering if anyone here knows if the Serp gear diff can be installed into the MI4? Just a long shot..
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 07-05-2010, 07:55 PM   #3240
SchuMi2's Avatar
Trader Rating: 34 (100%+)
S400 with Exotek top deck Fit and finish really good
Serpent to 1/10th EP Touring Kit S400-s400.jpg   Serpent to 1/10th EP Touring Kit S400-s401.jpg   Serpent to 1/10th EP Touring Kit S400-s403.jpg   Serpent to 1/10th EP Touring Kit S400-s404.jpg
SchuMi2 is offline   Reply With Quote
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
