Old 06-21-2010, 01:07 AM   #3211
venom54's Avatar
Originally Posted by wstuart View Post
Sweet! - just ordered your upper bulkheads
Thanks for the order. This will be sent out Tuesday AM. I'll email you a customs number for reference.
Cheers
Ren
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 06-21-2010, 01:22 AM   #3212
ericbeenorcal's Avatar
Default S400 2010???
wassup Will Stuart! thanx for the 2 diff breh, i still got my S400
driftin sideways...
Also REN----- r the Knuckles sold in pairs? if i buy i do i just get 1? or set?
Tnx, will order em soon
BocaBearingdePeppo
ericbeenorcal is offline   Reply With Quote
Old 06-21-2010, 04:34 AM   #3213
KweetNiet's Avatar
Nice Ive been dremmeling out a pair of outdrives to use with blades - ill let you guys know how they work.
I've been driving with an prototype Serpent spool which uses blades (3mm) but the wear on them is HUGE. After a few runs you see the wear starting and replacing them will be essential, already ruined one of the 2 prototype's I have due to too late replacement.
Instead of dremeling out the current ones, you can use the one way outdrives. These are blade ready, but now you have to drill out the spool (once) to fit te outdrives and drill a hole for the pin. These one-way outdrives are still on the market and even Serpent 720 ones can be used.
Originally Posted by venom54 View Post
I have local machinist looking at making these out of hardened steel but to suit the blades. Which will be made out of Delrin. Captive though so no movement similar to Titanium Racing spools.
Any suggestions in relation to final make up greatly appreciated.
Titanium Racing is no longer, so I would not recommend these, as the spares are as good to get as Serpent originals . I'll see
if I can post some pictures of the prototype tonight.
These upper bearing caps are available from us, made by Jet Hobby and are better than the SERPENT ones and stronger. These have been available for over a year
Jet racing has been producing S400 parts but they don't list them anymore on there website. So might this be ending??
16T's can also be used from Tamiya, there are aluminium ones from the TRF415 of u can use plastic ones with an adapter.
KweetNiet is offline   Reply With Quote
Old 06-21-2010, 04:58 AM   #3214
venom54's Avatar
driftin sideways...
Knuckles are sold as pairs. Same as C Hubs.
Cheers
Ren
Old 06-21-2010, 05:03 AM   #3215
venom54's Avatar
Even though Jet do not list these S400 parts on their web site they are still in stock to procure as i have done in the past. As recent as 1 month ago.
Cheers
Ren
Old 06-21-2010, 10:57 AM   #3216
Default knuckles
tnx ren! will order em this week!
any aluminum arms?
how bout ball diff or one-way for s400 fronts?
can i use rear ball diff for my front? what do i need?
TNX YAAL!
BocaBearingdePeppo
Old 06-21-2010, 06:18 PM   #3217
venom54's Avatar
any aluminum arms?
TNX YAAL!
Hi,
I only use a spool for the front, the last delivery out of Titanium. One way or diff on the front did not work for me.
Sorry no alloy arms for the S400 but i still have 2 pairs of front arms.
Cheers
Ren
Old 06-21-2010, 10:35 PM   #3218
Default s400
tnx REN
i will also pik up the last 2 arms from ya
BocaBearingdePeppo
Old 06-21-2010, 10:52 PM   #3219
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
any aluminum arms?
TNX YAAL!
They can be hard to get ahold of - but ive been using a gear diff in the front with alot of success. I race on medium to low traction parking lots so I put 40 weight shock oil in the rear gear diff with 2 gears out and I put 50,000 weight diff oil in the front diff with 2 gears out also. It gives really nice off power steering with plenty of rip out of the corners.
I think that the new tamiya "spec R" gear diff will work in the serpent - youll just have to use about 3-4mm worth of shims - which is actually less shims than I have to use on my titanium racing spool. If my serpent gear diffs ever take a dive I will definently be trying the spec R's.
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 06-21-2010, 11:49 PM   #3220
venom54's Avatar
Default RAB Hobbies web site down
Hi Guys,
For any one looking at placing any S400 orders soon, our site has been down due to server issues.
Hopefully up at the end of the day.
Just visit often for progress updates.
Cheers
Ren
BACK ON LINE AS OF 6.40pm AUSTEST
Old 06-22-2010, 10:04 AM   #3221
Default specR
Tnx Will!
i will def try the spec R diffs minus 2 gears on for my fronts - rear is locked for drifting but its nice to know that tamiya specR will work, i dont mind the shims at all.....
This saturday Norcal Drift Point Series kickstarts the season at FPR(Fast Pace Racing) in San Jose and will be held throughout different venues n tracks throughout northern cali and will end the series at FPR as well... Yaal can check out race results and pictures --Hyperdrift.Com:snea ky:
"if ur not bashin ur not livin"
"if ur not winnin, u def need more practice"
Serpent to 1/10th EP Touring Kit S400-awsop10.jpg
BocaBearingdePeppo
Old 06-22-2010, 10:27 AM   #3222
M-Technic's Avatar
Trader Rating: 15 (100%+)
The Spec R gear diff has plastic gears versus the metal gears of the Serpent diff. I wouldn't advise that you remove any of the gears from the Spec R.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 06-23-2010, 10:30 AM   #3223
fly_wheel's Avatar
can the spec r gear diff use the ori 35t diff pulley at rear?
There are more in racing than winning.
fly_wheel is offline   Reply With Quote
Old 06-23-2010, 11:22 AM   #3224
M-Technic's Avatar
The pulley is not removable, it's a molded part of the Spec R diff, so no...
Old 06-24-2010, 10:52 PM   #3225
fly_wheel's Avatar
wstuart: have u got ur upper deck from exotek yet..?
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
