Old 01-13-2009, 08:22 PM   #2716
Shagnasties's Avatar
Default gearing
so the calculation is exactly the same for 64 and 48 pitch?
You dont "snuggle" with MAX POWER, you strap yourself in and feel the "G's" !!!!
Shagnasties is offline   Reply With Quote
Old 01-13-2009, 09:17 PM   #2717
Same calculation:
Number of teeth on spur divided by number of teeth on pinion, multiplied by car's internal ratio (S400 = 2.187).
93T spur
__________ = 1.86
50T pinion
then multiply the 1.86 by car's internal drive ratio: 1.86 X 2.187= 4.06
Adis is offline   Reply With Quote
Old 01-13-2009, 09:58 PM   #2718
Thanks for the reply, got some 48 p gears that will give me the FDR im after.
Cheers for all the help, as you can tell im an electric tard, gas fumes have fried my brain,
Old 01-14-2009, 04:38 AM   #2719
StevenOlsen's Avatar
Default how to convert 64pd spurs and pinions into 48pd and the other way around
its very simple just take tha number of tooth and devide with the pd you have and X it with the wanted pd
100 tooth 64pd spur
64 = 1,5625 X 48 = 75 tooth 48pd spur
so if you are told to use 93 spur and 50 pinion in 64pd you get 69,75 spur and 37,5 pinion and then you use 60/70 tooth spur and 37/38 pinion
the wanted gear ratio is 4,0
69/37 = 4,079
69/38 = 3,972
70/37 = 4,138
70/38 = 4,029
hope it helps
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 01-14-2009, 06:26 AM   #2720
hi RCtech just made a 48pd gear chart
Steven Olsen
Old 01-14-2009, 01:36 PM   #2721
ds400's Avatar
Default S400
Hey guys,
did my first meeting with my new serpent. Keep the original setup from book and just made the belt looser cause I running a silvercan stock 540 motor.
4.0 gearing. Did 11, 5m 16
Was 2 seconds near my best track time [ done with my old xray]. Changed my tyres to 28 and gearing to 3.84 and did 11, 5m13. that was awesome!!!
Very quiet car and easy to drive...
Now Will work to make it faster..
Any tips from the pro????
ds400 is offline   Reply With Quote
Old 01-14-2009, 09:06 PM   #2722
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
mebi this tips can help you----------> here
Give the best while u can !
kschu is offline   Reply With Quote
Old 01-19-2009, 11:09 AM   #2723
OK, so I found a part number for the foam version of the s400. Anyone got information on it?
Mr Granone is offline   Reply With Quote
Old 01-19-2009, 11:32 AM   #2724
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
DO you guys think these new xray drive shafts
http://www.teamxray.com/teamxray/new...b39c15d16f600f
will fit the s400? - they seem pretty cool
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 01-19-2009, 01:27 PM   #2725
Talk about back to the future. These are are just like the old Losi drives you could upgrade to. I ran them on the XX4 for a bit but the wear on the parts was extreme. In the end I went back to the regular CVD.
Old 01-19-2009, 11:23 PM   #2726
kschu's Avatar
i dont think the xray driveshaft can be use on S400 as their length is 50mm-52mm .
S400 only can use 46mm and 48mm...
Old 01-21-2009, 10:56 AM   #2727
OK, I will ask again. Anyone know more about the S400 foam addition part number 400002? What changed? Is it just the standard S400 with the foam update kit? Does it have the new CVDs?
Old 01-23-2009, 07:38 PM   #2728
Josue24's Avatar
Talking Hi!!
Hi,
I'm looking for information about this kit (S400), just want to know if they will release it again.......
Josue "josh" Valentine
Serpent America
Josue24 is offline   Reply With Quote
Old 01-23-2009, 08:22 PM   #2729
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Yes, I believe Serpent is planning on giving full support. As you can see in www.SerpentAmerica.com, they already have almost all parts up there. And as Michael Salven mentioned in the interview, if everything goes good, we'll probably be seeing more.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 01-23-2009, 08:28 PM   #2730
M-Technic's Avatar
Trader Rating: 15 (100%+)
From what I have heard, the rest of the S400 parts will be in stock within 2-3 weeks. I believe this include complete kits.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
