Old 01-11-2009, 05:01 PM   #2701
Shagnasties's Avatar
Default gaering etc
Heya, hoping some one can help me out. New to electric so no idea.
Car has never been run.( unless you count VERY short course drifting on the kitchen floor)
What is the best spur/ pinion combo for an FDR of 4.0 or just above? ( i mean number of teeth/ pitch not brand )
Im running a Lrp Vector 17.5 brushless, lrp sphere tc with a track power 3600 30c lipo.
I have a gear diff in back and spool in front, i have a mid shaft one way and a one way front diff ( neither fitted to car), are either of these worth fitting for stock class?
What effect does the mid shaft one way have?
Ive also fitted front aluminium c-hubs, are they worth having on the car or should i stick with plastic?
cheers
You dont "snuggle" with MAX POWER, you strap yourself in and feel the "G's" !!!!
Shagnasties is offline   Reply With Quote
Old 01-11-2009, 05:25 PM   #2702
yyhayyim's Avatar
Trader Rating: 26 (100%+)
cheers
Hey Shags,
1) if you're running on asphalt, run spool upfront with rear diff.
2) If running on carpet, many people use the one way on carpet upfront, although many prefer a front spool as well.
3) Use the stock center pulley.
4) For 4.0 FDR use 93 Spur with 50-51 tooth pinion.
5) For 17.5 racing the aluminum C-hubs are not needed. Stick with the plastic ones.
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 01-12-2009, 12:33 AM   #2703
Default gearing
Thanks for the reply, couple more questions
If i go to 48 pitch spur/ pinion, does the number of teeth on the spur/pinion remain the same? if not what 48 pitch spur/pinion do i usw to get the above posted FDR?
Also, does any one use the rear anti roll bar?
cheers
Old 01-12-2009, 12:54 AM   #2704
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
cheers
I always use the front n rear anti roll bar
the 48pitch and 64pitch teeth is different....but i'm not sure how to calculate it....
Give the best while u can !
kschu is offline   Reply With Quote
Old 01-12-2009, 06:10 AM   #2705
jayjayy's Avatar
Send a message via ICQ to jayjayy Send a message via MSN to jayjayy
FYI, KSCHU is our top driver in our area. He always tries new setups and some sort of "secret tuning" and always stays ahead of the rest of the pack in our place. His setup works...
48 and 64 pitch. Some info that I know of...
Durability = 48P really tough
Quietness = 64P
Smoothness = 64P
Ratio = 64P will gives you finer ratio difference compared to 48P
Calculations of ratio is still the same.
Is anyone having durability problems with the center 16T pulley? I mean it wears out quite fast as compared to other brands. I am think the annodized coating wears out too fast IMO. My local top drive kschu is using 16T pulleys from HB and the wear rate outlast Serpent's at least 2x and works like a dime.
Chu is it right? is it right?? huh huh??
jayjayy is offline   Reply With Quote
Old 01-12-2009, 06:38 AM   #2706
sandrixx's Avatar
Default 16t pulley
Quietness = 64P
Smoothness = 64P
yeeep! I've also notice my 16t pulley wears out fast even if we are only racin 11.5BL's. what more if usin' a faster motor?..anyway,, do you have the part number from HB for the 16tpulley?..much thanksx
Team DogBone-Cobra/Serpent
Team F.R.E.A.K.S/SOLIDSNAKE_Saudi Arabia
Stay Serpent...
sandrixx is offline   Reply With Quote
Old 01-12-2009, 08:29 AM   #2707
suntok2's Avatar
Send a message via ICQ to suntok2 Send a message via AIM to suntok2 Send a message via Yahoo to suntok2
Originally Posted by Mr Granone View Post
Well I checked MMR and it does seem they have them. However they are $800 per the online store. WTF $800? That would be the most expensive RC TC on the planet to date. I can order one from EU cheaper then that even if I pay VAT. Anyone know a source in the US that is not out of their minds?
500 US$ ship dood to door(dogboneind.com)
suntok2 is offline   Reply With Quote
Old 01-12-2009, 09:15 AM   #2708
You can also use the 3-Racing pulleys designed for the HB. They outlast the Serpent pulleys as well (I ran mod with them).
partno: 3R-CY-17PU Aluminium Pulley For Hot Bodies Cyclone
The pulleys itself are made of Delrin or some other type of plastic that seems similar. The set comes with 16t, 17t and 18t pulleys, so you can play a little with your internal ratio as well).
Govert is offline   Reply With Quote
Old 01-12-2009, 05:57 PM   #2709
kschu's Avatar
i'm not top driver leh........already lose to u last race...
HB 16t pulley - HB-70725
i also using 3racing center pulley and its last longer than serpent center pulley...and cheaper price too...
fyi, tamiya 16t center pulley also can fit into s400. (ta-51060)
Old 01-13-2009, 12:21 AM   #2710
sandrixx's Avatar
Default oki! suntok,,,,,,,,,passoook!!
Snake Bros, thanks for the quick reply re the 16t pulley. I will try to order for backup reasons.
FYI, you can order Serpent parts and kit from Suntok2(dogboneind.com) Very good reputation with very low prices. I got my kit and parts from him,,,No problem.
Stay Serpent...
Old 01-13-2009, 06:22 AM   #2711
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
As a distributor the online store is msrp they are clearancing out some of the snake kits try emailing them a request on a s400 kit.
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 01-13-2009, 07:16 AM   #2712
Default s400 gearing
any one tell me what the FDR on a 35 t pinion and a 69 tooth spur are please? both 48 pitch, some one said the calc for 64 and 48 pitch are different.
cheers
Old 01-13-2009, 07:58 AM   #2713
sandrixx's Avatar
Default spur/pinion*2.18
cheers
4.2fdr
Sssssssssssssssssssssssssssssssssssssssssss.......
Stay Serpent...
Old 01-13-2009, 04:14 PM   #2714
Default gearing
Thanks for the reply, what is the calculation you used please?
cheers
Old 01-13-2009, 05:01 PM   #2715
cheers
www.gearchart.com
Choose gearchart creator, pick your car, spur and pinion and your FDR will be calculated.
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
