Old 08-07-2007, 04:48 AM   #226
colonrc's Avatar
Originally Posted by KAHUNA View Post
? What is the biggest spur that the S400 will take ?
thx . .
I have 100t(64p)on mine I havent tried anything bigger.
Serpent U.S.A , Maxy's Pro Racing Fuel , Murnan Modified Motors,Nexus Racing,Mike Desing,Member of GO-R/C
colonrc is offline   Reply With Quote
Old 08-07-2007, 11:45 AM   #227
It really depends on the class you run as to what spur you can use. If you run stock it will probably max out at 96-100 since you have to run such big pinions (35-40) to get the final drive needed. If you run mod than you can probably run a 106-108 becuase you would use a 20 to 25 pinion.... I am obviously talking about 64 pitch gears...
rangulo is offline   Reply With Quote
Old 08-07-2007, 11:55 AM   #228
I wanted to give you guys a few tips on building the cars when you get them so they will run really good on rubber tires.
Take the top deck of the car and file it a little on the ends so there is a little gap between the carbon and the aluminum bulk head. This gives the car a little more flexibility so it runs real good. I ran it with a .5 mm spacer under the hinge pin holders (front and rear)to raise the roll center position to free the car up in the corners. Also I ran the car with 30 in the front and 25 weight in the rear with 3 hole pistons. I also ran the car as long as it would go to make the S400 have good smooth transitions on the track. I ran the car with yellow fronts and white rear springs and sometime the orange ones. Droop-I set it to 4 in the front and 4 in the rear measured on the arm under the outside hinge pins. I ran no sway bars in stock and in 19t and Mod I ran it with the med one in the front and the soft one in the rear...
Old 08-07-2007, 08:05 PM   #229
THeGame's Avatar
Send a message via AIM to THeGame
Default Cleveland
Rangulo so what carpet races are you hitting this year ?
Team Gravity Rc - G's R/C Raceway and Hobbies - Waldorf RC - TheTrack
THeGame is offline   Reply With Quote
Old 08-08-2007, 08:00 AM   #230
I dont think I am going to the any!
Old 08-08-2007, 08:00 AM   #231
Old 08-09-2007, 09:01 AM   #232
Suspended
Trader Rating: 28 (100%+)
Originally Posted by ottoman View Post
420 euro... thats around $570
$419.99 at my Local shop{california} when they get here.
racenut123 is offline   Reply With Quote
Old 08-09-2007, 09:06 AM   #233
Hi, this post is very informative; however I would like some specific information. If someone can help me then please send me a private message. Best Regards,
[url=http://www.wholesalepages.co.uk]UK Wholesale Suppliers[/url] [url=http://www.aidandtrade.com]UK Dropshipping[/url]
[url=http://www.francewholesalers.com]France Dropship Suppliers[/url] [url=http://www.zameen.com]Property Pakistan[/url]
sharrychrist is offline   Reply With Quote
Old 08-09-2007, 09:25 AM   #234
Joep's Avatar
Here (http://www.serpent.com/product/400001/) is all the information which is currently available.
Joep is offline   Reply With Quote
Old 08-09-2007, 09:56 AM   #235
rc-zombies's Avatar
Originally Posted by redsand View Post
IMHO, orange is much better than gun metal.
orange looks good.... reminds me the Alex racing R2 special edition orange car I formerly had...
hope to get one... getting tired of my purple cars...
I just downloaded the manual and setup guide...
very clean and simple.
Old 08-09-2007, 11:40 AM   #236
Joep's Avatar
The current kits will not be orange
Maybe later.....
Old 08-11-2007, 04:05 AM   #237
Does anyone from the guys that build and drove one, If you'll need some special tools to build this kit? For instance, special tools for building the diff, the suspension, drive-train or anything else...
This shop offers a special serpent tool setup kit and I'm wondering if I really need one.
Govert is offline   Reply With Quote
Old 08-11-2007, 06:39 AM   #238
the only tool that helps alot is serpents shock tool, it tightens the plastic cap onto the body. u dont need it but it helps if you are changing oil alot.
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 08-13-2007, 10:13 AM   #239
thanks jeff, for your quick response
Old 08-13-2007, 10:17 AM   #240
I cant wait to hit the carpet again! Should be a Blast!
Jeremy Cupps
Sponsors are
Mugen Seiki, NovaRossi Engines, Enneti Tires, Byrons racing fuel, Airtronics, XceedRC, Mikes HobbyShop Porter Texas, Global Hobby Distributors, Avid Bearings, Paint by Smiley, and my wallet!
J-MAN is offline   Reply With Quote
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
