Old 07-20-2008, 08:51 AM   #2371
UK.hardcore's Avatar
The bars are different, rear is narrower at the center (where it goes on the bulks), longer at the ends and bent in a different angle.
My 5 cell deck is 107mm wide.
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 07-20-2008, 09:02 AM   #2372
ark
UK.hardcore thanks heaps.
Can anyone suggest anything thats needed (parts etc) straight after building the kit?
ark is offline   Reply With Quote
Old 07-20-2008, 11:11 AM   #2373
Randy Caster's Avatar
Trader Rating: 46 (100%+)
That is the first time I've seen that TFRacing top deck. Looks like it's probably not a bad option for the people who have been wanting to run the large lipo packs in this car. Serpent will have their new parts out before long, but I that topdeck should be fine until then...
Old 07-20-2008, 06:49 PM   #2374
Well guys, ran the car on the weekend for the first time on carpet.
Went ok, considering 1st run of the car and motor dramas in the first two rounds I ended up 10th overall, winning the 1st B Final but had to leave for the second.
Will post setup for you guys to pick apart as I feel there were a couple of things lacking with the setup. Mainly mid corner speed. It felt as though the car was bogging down and scrubbing off speed entering the corner therefore affecting the mid corner pace. Track was tight with 2 tight hairpins. Any input would be great to develop the car on the national scene in Oz.
Ill post the setup in a minute or two
commander is offline   Reply With Quote
Old 07-20-2008, 06:55 PM   #2375
tallyrc's Avatar
anybody running the front diff on asphalt with any luck?
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 07-20-2008, 07:00 PM   #2376
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
hardly anyone runs a front diff on asphalt , it will push on power
Old 07-20-2008, 07:51 PM   #2377
heres the setup sheet.... apolgies for the cutoff parts, could not find a setup sheet with a small enough file size to post!
Feel free to give any input possible.
Trying to get my hands on a gear diff for the rear and front ball diff but unfortunately cant find one anywhere!
Old 07-20-2008, 11:35 PM   #2378
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Another win for Team Serpent in local race.
www.redrc.net
Give the best while u can !
kschu is offline   Reply With Quote
Old 07-21-2008, 08:04 AM   #2379
I thought that was you. Congrats on the good finish!
Old 07-21-2008, 08:14 AM   #2380
kschu's Avatar
Jason's car was doing very very well tat day until i cant even chase him....
i'm jus out of my luck to get d 2nd position which i jus lose 0.01sec to the HB driver....his car flip and pass d transponder line which is faster 0.01sec than me!!! ....
well, tat a race..
i tried yokomo BD/SD rear delrin diff cup on my s400. it's fit nicely but need to use back d yokomo diff ring, spring, screw and thrust bearing....i havent get chance to try it out yet...i will review after i run it this weekend...
Old 07-22-2008, 11:21 PM   #2381
kschu's Avatar
hi, may i know how u guys balance left and right weight after you switch to lipo battery???
Old 07-23-2008, 12:41 AM   #2382
My racing buddy puts lead on his S400.
he has Orion 3600 and needs about 230 grams.
Old 07-23-2008, 01:48 AM   #2383
kschu's Avatar
bro, mind showing some pictures to give me some idea to put the Lead...
thanks
Old 07-23-2008, 04:02 AM   #2384
No pics here.
You can take full-size car wheelbalance weight and stick them to the side on the lipo, or on top.
Or you can put some weights on the chassis in front or behind of the lipo.
Old 07-23-2008, 06:12 AM   #2385
scoyle's Avatar
If you check out my web site at;
http://rcracingni.co.uk/wordpress/?p=393#more-393
you can see a review of some excellent weights that you can get to bring your Lipo car up to weight.
scoyle is offline   Reply With Quote
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
