Old 07-12-2008, 12:30 PM   #2311
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
Originally Posted by LOW ET View Post
anyone have this car in stock? parts in stock?
darkside motor sports carries them. www.darksidems.com
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 07-12-2008, 03:48 PM   #2312
Phoenix82's Avatar
Default S400 DIFF INFO
Hey guys, i would gather that the rear diff works in the front? or are they differant?
Is there anybody the carpet chassis?, and if so are you using the stiff top plates ir the soft onroad plates?
Nick
Phoenix82 is offline   Reply With Quote
Old 07-12-2008, 09:50 PM   #2313
Hey guys, anyone got a gun base carpet setup for stock/foam 17.5 Brushless. Fairly low/mid level grip and tight track.
Appreciate the help!
commander is offline   Reply With Quote
Old 07-14-2008, 01:48 AM   #2314
also a gear ratio for 17.5 brushless. Anyone help? 64p?
Old 07-14-2008, 07:33 AM   #2315
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
you want to be in the mid 3's ( 3.5 to 3.6 fdr)
Old 07-14-2008, 07:59 AM   #2316
Randy Caster's Avatar
Trader Rating: 46 (100%+)
With foam tires or rubber tires? Foam he might need to go a little higher yet...
Old 07-14-2008, 02:39 PM   #2317
scoyle's Avatar
Hi guys, haven't been racing recently as I was away on holidays. Will be back this coming weekend at the Irish championship here in Ireland.
While I wasn't racing I was on the Internet and ordered myself an Airtronics M11 transmitter to replace my Futaba 3PK - do any of you guys run one? I have set the car up, checked the sub trim, end points and set the speedo. Do you use any of the other setting on the radio?
scoyle is offline   Reply With Quote
Old 07-15-2008, 04:43 AM   #2318
man that is some crazy gearing isnt it? Im trying to get down to mid 3's but its like running an 87 (64p) spur, the smallest serpent goes to a 52 (64p) pinion, the largest pinion they go to...
Is this correct? Just seems really really odd these sizes. How about comparable to 48 pitch?
Not trying to argue guys, appreciate the help, just confirming I guess
Old 07-15-2008, 04:50 AM   #2319
UK.hardcore's Avatar
Hotbodies Cyclone 18T pullies on the layshaft change the IR to 1.95/1 instead of 2.1875/1 stock, you need longer belts but i dont know wich exactly. TRF belts i think.
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 07-15-2008, 05:40 AM   #2320
isnt there serpent 18 tooth option pulleys?
Old 07-15-2008, 05:43 AM   #2321
your right its the 415 belts with 1 extra tooth that fit the 18 tooth pulleys. Just found it. Geez good luck me finding that by the weekend!
Old 07-15-2008, 06:21 AM   #2322
you reckon you could use the HB Cyclone slightly longer belts for the 18tooth pulleys?
Old 07-15-2008, 06:43 AM   #2323
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
commander, i dun think v can use cyclone Belting...
cyclone pulley is 39t + center pulley is 18t
s400 pulley is 35t + center pulley 18t = will extra 2 teeth
Give the best while u can !
kschu is offline   Reply With Quote
Old 07-15-2008, 08:15 AM   #2324
RPage's Avatar
Use the 415 MRE belts with 18T pulleys
RPage is offline   Reply With Quote
Old 07-15-2008, 08:38 AM   #2325
Super Moderator
Marcos.J's Avatar
thats what alot of guys are running with the 17.5's
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
