Old 07-02-2008, 05:44 PM   #2281
Originally Posted by kschu View Post
hi guys, i need a urgent comment about vortex race 2008 motor... is it reli no punch and top end ???
i'm considering 3.5r n 4.0r....i hope some1 can enlighten me here..
thanks
Just tested the Orion Vortex 2008 4.5t motor. I have to say I'm a little bit disappointed, because you are right about the punch and rpm. Punch is OK, but could be better and it has less rpm than a Speed Passion.
I compared the motor with a Speed Passion 4.5t which a friend of mine drove, and he had more punch and top end (same ratio).
On the other hand, the motor gave me a lot of 'feel'. Really easy to dose the throttle and very easy to drive. Suitable for low bite tracks and/or technical tracks. I was amazed by the fact it really lets the car roll for miles.....very smooth.
To be honest, I would go for a Speed Passion or something comparable.
Govert is offline   Reply With Quote
Old 07-02-2008, 06:41 PM   #2282
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
randy, wat is d reconmended shock length tat suitable for s400 ???
since u using trf shock, do u use the spring retainer tat come with the shock or the retainer that come with the s400 shock ???
i just bought a trf hard black shock...i'm nt sure which retainer should i use..
thanks!
Give the best while u can !
kschu is offline   Reply With Quote
Old 07-03-2008, 12:35 AM   #2283
Randy Caster's Avatar
Trader Rating: 46 (100%+)
thanks!
I use AE shock ends and spring retainers. Cut the shock end down 2mm.
Where did you find the black shocks? They haven't made it to the USA yet.
Old 07-03-2008, 01:12 AM   #2284
kschu's Avatar
randy, i order it online from Hong kong Hobby shop at USD50.
check it out at http://shopping.rcmodel.hk
Old 07-03-2008, 11:15 AM   #2285
Cool, thanks! I didn't realize they had so many black anodized parts available..
Old 07-03-2008, 11:30 AM   #2286
Francis M.'s Avatar
What do you use to cut the ends down with, Exacto???
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 07-03-2008, 11:58 AM   #2287
Yep.
Old 07-03-2008, 08:47 PM   #2288
kschu's Avatar
how come this thread so quiet?? no race coming up ??
my local track will have a HPI challenge 2008 stock race on this sunday...
there will be 4 serpent racers joinin d race and competing with HB racers......
i notice if we remove the rear 2 pc screw that holding d plate for Spur pulley will make d car more flex and easier to drive in low traction track...i'm not sure if it's just my feeling or it's reli work....so just gv it a try and let me know....
hehe
Old 07-03-2008, 09:44 PM   #2289
Geezatec's Avatar
hehe
Hmmm dont know about loosening screws on the center shaft. Won't it wear out the bosses for the bearing or cause a wobble???
Try putting 'O' rings under the top plate between the plate & bulk head. One or two o-rings with two screws, it soften it up.
Geezatec is offline   Reply With Quote
Old 07-03-2008, 09:49 PM   #2290
There are still the other 4 3x6mm holding the rear plate on so nothing will wear out. I lost those 2 screws so I just took them off of both cars but I didn't notice any difference in handling from removing them...
Old 07-04-2008, 02:12 AM   #2291
kschu's Avatar
randy, wat tyre cleaner u usually use to clean up ur tyre ? any new thing u did to ur chassis ???
Old 07-04-2008, 06:37 AM   #2292
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
WD-40 works great
Old 07-04-2008, 06:43 AM   #2293
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Que hay de nuevo Alfoso?
yyhayyim is offline   Reply With Quote
Old 07-04-2008, 03:06 PM   #2294
I rarely clean my tires but motor spray takes most of the sauce off from the previous run if I do clean them.
Old 07-04-2008, 03:39 PM   #2295
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Originally Posted by Marcos.J View Post
WD-40 works great
+1 WD-40 is a solvent, so it actually helps with traction as well. After a run I wipe the tires down with wd-40, throw them onto my tire warmers, then 25min before the race, bake 1 of my tire compounds in, then wipe off, and bake another 1 in that I use that keeps the tires from being too sticky and having all the dust stick to my tires from asphalt racing.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
