Old 06-13-2008, 02:31 PM   #2206
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
ygpm
Jon Kerr is offline   Reply With Quote
Old 06-13-2008, 02:32 PM   #2207
Jon Kerr's Avatar
never mind that PM, I missed your second post.
Old 06-13-2008, 02:42 PM   #2208
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally Posted by scoyle View Post
It's the calm before the storm Randy - I race this Saturday and will be back with more questions...
I probably wont be on here a whole lot in the next 10 or so days, I leave on Tuesday and neither of my cars are done so I've got a busy wrenching weekend ahead..
Old 06-15-2008, 12:58 AM   #2209
scoyle's Avatar
Originally Posted by Randy Caster View Post
Mid corner steering is probably the hardest to find, but I have a couple ideas.
First off, by using the UK upper deck you would need to alter your setup to get it to work. It looks like it would flex a lot, compared to the stock one which flexes very little. If your chassis flexes too much, you will scrub speed in the corners. I would try back to back runs with the UK deck and the standard top deck, as I honestly think you will get some of your cornerspeed back by stiffening up the chassis.
Other things to try would be a longer front camber link, I could see your current link getting into the corner very well, but dumping over too much throughout the turn.
Try your swaybars in the outside holes on the arms.
Try .5mm anti-squat in your rear end, this will definately help the car rotate, for some, it is too much though.
One simple thing to play with would be camber adjustments, start off by using less rear camber before you use more front camber.
Give those changes a shot, I've got plenty more for you if they don't work.
Had a great race at the weekend and tried a few of these ideas - tried the back to back runs with the top deck but still liked the feel of the UK top deck although I did add the two stiffeners to stiffen it up a bit. I had 1mm shims under the rear to raise the roll center and replaced one of them with a 0.6mm shim to give ant-squat - don't know why but did not like this change. Did the camber change going to 1 degree on the rear and 1.5 degress on the front as well as putting all the ARBs to the outside holes and lengthened the front turnbuckle. Car felt good and the changes made a difference... but...
When trying to hold more speed to go into the corner instead of slowing down as much I have understeer - I'm not trying to break the laws of physics honest but at the point when I let of the throttle at a good speed it just does not go into the corner as well (slower speeds I have lots of steering).
Any ideas? I am thinking of building my car to Randys Reedy setup for the next race to see how that feels.
scoyle is offline   Reply With Quote
Old 06-15-2008, 01:14 AM   #2210
RC MARKET's Avatar
New suspension arm & 4 deg suspension mount was release .
but why not have gear diff ?
www.rcmarket.com.hk
RC MARKET is offline   Reply With Quote
Old 06-15-2008, 07:33 AM   #2211
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
guys, may i know if i wan use 18t center pulley, wat belt can i use ??? since i got 18t pulley extra n thinking wanna try it...
thanks
Give the best while u can !
kschu is offline   Reply With Quote
Old 06-15-2008, 02:18 PM   #2212
scoyle - Give my setup a shot, I think it will help. One major thing though is make sure you run the entire setup not 95% of it, it's all the small things that make the difference.
Old 06-15-2008, 02:18 PM   #2213
thanks
To run the 18 tooth pulley you probably would just need a belt with 1 more tooth on it, I haven't really searched for them but I cant imagine them being too hard to find.
Old 06-16-2008, 02:12 AM   #2214
kschu's Avatar
my car picture...
i notice d center pulley very fast wear out....wat u guys think bout it ? i currently using cyclone 16t pulley which i think last longer than the s400 pulley...
Serpent to 1/10th EP Touring Kit S400-dscn0014.jpg
Old 06-16-2008, 02:34 AM   #2215
RC MARKET's Avatar
TRF415 Marc belts !!
Old 06-16-2008, 03:00 AM   #2216
kschu's Avatar
guys, i jus notice tat billy easton car during warm up race got abit different.. d servo mount like tamiya trf415.
Serpent to 1/10th EP Touring Kit S400-billy.jpg
Old 06-16-2008, 10:11 AM   #2217
yyhayyim's Avatar
Trader Rating: 26 (100%+)
I'm hoping Serpent USA has the new S400 kits which include the gear diff clearing customs within the next couple of days
yyhayyim is offline   Reply With Quote
Old 06-16-2008, 10:12 AM   #2218
yyhayyim's Avatar
have you tried Xray 34t pulleys on the S400?
Old 06-16-2008, 10:16 AM   #2219
yyhayyim's Avatar
Hi Randy...would you care to comment on the feeling of the S400 gear diff vs ball diff you've run in the past?
When you get a chance I'd be cool to get your perspective on the feel of the car in and out of corners with the gear diff as opposec to a rear ball diff.
Old 06-16-2008, 12:38 PM   #2220
my car picture...
I'm not sure why you're wearing out pulleys, I looked at my origional kit's pulleys and they show no wear at all... Go back to the stock ones with the new belts and you should be fine.
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
