Old 05-27-2008, 12:12 PM   #2056
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Originally Posted by Jon Kerr View Post
Randy qualified well. 3rd in the A. I think he ended up in 5th or 6th overall.
good job, buddy.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 05-27-2008, 12:14 PM   #2057
Randy Caster's Avatar
Trader Rating: 46 (100%+)
For those interested in my Reedy Race setup, here it is.
I posted my origional setup which is fairly easy to drive, should be able to get around the track well for anyone. My Reedy setup is more aggressive and will be a bit harder to drive, but is capable of some fast laps.
Notes:
-5 cell chassis used, receiver mounted in front of
batteries.
-Upper deck was cut to allow more flex. (see pictures)
-Used 2 gears in rear diff.
-TRF shocks with stock Tamiya bladders with nothing
above.
-Tamiya pistons used.
-AE lower spring retainers, and shock ends with 2mm
cut.
-.5mm anti-squat.
-Front pivots raised .5mm + .5mm anti-dive.
-Steering limited 1mm on knuckle.
Reedy Updates:
-2* caster blocks.
-600wt front oil, 550wt rear oil
-Body position 34mm
-Ackerman still in back row but outside holes
-3* rear toe block
-Front swaybar mounted inner hole on arm
-Front arms forward
-Rear arms centered
-5mm ride height
-Droop 34.7mm
-Full throw on steering
-Camber 1.5* front, 1* rear
-Handout tire was a Sorex 36R premount on Speedmind wheel "SpeedRex 36"
Hope this helps!
Serpent to 1/10th EP Touring Kit S400-casterbcrsetup-1.jpg
Old 05-27-2008, 12:15 PM   #2058
Originally Posted by seaball View Post
good job, buddy.
Thanks Chris!
Old 05-27-2008, 06:45 PM   #2059
My buddy Carl Hyndman sent some awesome action shots of my car from the race, this one is my favorite. World class photographer!
Serpent to 1/10th EP Touring Kit S400-image.jpg
Old 05-27-2008, 08:09 PM   #2060
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
randy, i interested at d vortex race 3.0r ...but wouldnt its too much power for track in my place or will it drain too much power from d battery ???i'm using 5 cell...
Give the best while u can !
kschu is offline   Reply With Quote
Old 05-27-2008, 08:17 PM   #2061
kschu's Avatar
Originally Posted by Rhoby 1257 View Post
Kschu= The whistling sound of the high end brushed motors are built in especially the sp 3.5 turns due to the internal fan in the rotor. Are you using the speed passion 3.5? As far as i know, Only sp and orion have that whistling sound when they run...
Ralph Lorenzo used that one(sp 3.5turns) here in the Philippines with the Gran turismo esc. His car was amazingly fast with 24 laps in 5 mins main... He was the champ (A main) back to back both legs 2 and 3 of our Ride Series here...
So, you are running bl already? Great isn't it?
Saw your pics kschu...Congrats your really putting your s400 on the podium...
rhoby, long time didnt see u online in rctech...how ur s400 ?
i'm using sp3.5r after i lose my interest in Mod Brush motor....d comm and brush finish like no tomorow...money oso gone like nothing...
i'm using SP GT 1.1 now and very happy with d result...thinking wanna change to Vortex motor since randy also using it.....
Old 05-27-2008, 08:30 PM   #2062
I have been able to make runtime without any problems using a 3.0 turn with the 4200SHO batteries. Orion now has the 4600SHO batteries which make it even easier to make time.
Old 05-27-2008, 08:49 PM   #2063
kschu's Avatar
i'm using east power 4600 now....if like tat, i put vortex my next buying list....thanks bro..
Old 05-28-2008, 05:49 AM   #2064
UK.hardcore's Avatar
Now my Serpent S400 is build.
I need some more tuning parts tough.
If i where to change the rear susp. holder to 4.0 front and rear, what effect will it have because suspension arms are now further away from centerline?
Now i have 3.0 front and rear and use 1 or 2 hubs if desired, 0 also used, i drift so i dont need all the 3 and alike.
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 05-28-2008, 08:03 AM   #2065
4.0 on the rear will make the car wide which usually means stable, but when you take out all of the toe-in it is going to lose almost all the traction. I've never drifted and haven't seen anyone in this thread who does so far, you might want to ask those questions in a general drift thread...
Old 05-28-2008, 08:55 AM   #2066
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
I have run my spare car as a drifter.... the stock setup it pretty good...
Tighten the rear diff down, and adjust your camber to balance...
10.5 motor seems to be perfect balance of speed and power for drifting
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 05-28-2008, 10:36 AM   #2067
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Anyone using Tamiya TRF suspension brackets on their S400? I've heard that they work just fine and would like to try them since I cant get Serpent suspension brackets.
But the Tamiya TRF brackets are weird: 1X, 1B, 1D? What the hell is that?
Which ones do I need for my s400...I want to narrow my front end a bit by using
0 FR, and 2 FF
and in the rear:
2.5-2.0 RR, and 0 RF
found a shop that has them but cant crack the "tamiya code" on them blocks....help!!!
yyhayyim is offline   Reply With Quote
Old 05-28-2008, 10:52 AM   #2068
If I'm not mistaken, either the X or A blocks would be equal to our 0 block. A, B, C, D, and E blocks all go up in .5 incraments. If A is equal to our 0 block, X would be equal to our -.5 block. XA, XB, XC, and XD all go down in .5 incraments. So E would be their widest block, and XD would be their narrowest, quite a bit narrower than our -.5 block.
Old 05-28-2008, 11:32 AM   #2069
yyhayyim's Avatar
Thanks Randy:
http://www.speedtechrc.com/store/ebp...?catmainid=267
they got them...but there seems to be different version of the suspension blocks. Some are TRF 415, and some Ta05/TRF 415 suspension blocks and have different numbering on them: some are XA, XB, XC, XD, etc, and some blocks are TRF 415 /Ta05 and say : 1X 1A, 1B, 1C, 1D.
http://www.speedtechrc.com/store/ebp...?catmainid=269
Old 05-28-2008, 12:08 PM   #2070
They all mount the same, the X line is just the narrow ones.
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
