Old 05-06-2008, 07:47 PM   #1891
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
i'm using jaad thrust bearing and Jaad ceramic bearing..it's work great for me! even d diff plate oso can last longer...i'm using Xenon diff grease which last longer than any silicon grease i ever use....
any1 ever try using teflon diff greasE??
Give the best while u can !
kschu is offline   Reply With Quote
Old 05-10-2008, 05:46 PM   #1892
kschu's Avatar
hallo ? how come so silent this thread??
Old 05-10-2008, 08:28 PM   #1893
Trader Rating: 20 (100%+)
I know this was probebly already asked but, do any of the core lipo batteries fit with little or no dremmeling.
TLR 22 3.0
TLR 22-4
Cooper Motorsports
R.Fenstermacher is offline   Reply With Quote
Old 05-10-2008, 08:55 PM   #1894
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Only the CORE3250 will fit
yyhayyim is offline   Reply With Quote
Old 05-10-2008, 09:01 PM   #1895
Is it good for 13.5 and 6.5?
Is it a good battery?
TLR 22 3.0
TLR 22-4
Cooper Motorsports
Old 05-10-2008, 09:13 PM   #1896
yyhayyim's Avatar
CORE packs are exellent for 13.5 and 10.5...high quality packs and great support from Schumacher USA.
With 6.5 Mod, it will also be very good, however, with an S400, someone running an SMC4000 pack will be a bit faster...the SMC gives more punch in MOD than anyother pack in the market now. The only other pack that can hang with the SMC packs is Trackpower4900 25C packs, or CORE5000 packs. However, the Trackpower 4900 or CORE500 packs will not fit under the bulkheads, so you have to just site them on the chassis agains the bulkhead and they'll stick out fo the chassis about 7mm...you get nearly perfect balance though, and all you gotta do is add the weight.
Old 05-10-2008, 09:24 PM   #1897
sonic31's Avatar
serpiente nombe won
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 05-10-2008, 09:39 PM   #1898
yyhayyim's Avatar
Originally Posted by sonic31 View Post
serpiente nombe won
potaje racing...dale galleta
Old 05-11-2008, 08:15 AM   #1899
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Had a pretty big "Reedy Race" warmup class at the local track yesterday, lots of factory drivers showed up to run, Josh Numan, Ryan Cavalieri, Dave Jun, Steve Weiss, a pretty stacked field for a club race.
This was the first time on the Sorex premounts for a lot of us, but my car was pretty good from the first run on. For anyone going to the reedy race that hasn't run the tires yet, just expect your car to push on the 2'nd run on these tires, it's a pretty big difference between the 1'st and 2'nd run.
Anyway I changed a few small things on my setup and the car really came in. Managed to TQ and win the race after a bumper to bumper battle with Steve Weiss for the first 4 or so mins of the race, it was a lot of fun!
I was just very happy with how quickly I was able to adapt the car to the new tires.
My changes from my posted setup are:
-Moved the front arms all the way forward
-Moved the ackerman to the outside holes on the bellcrank
-Moved the front swaybar mounts to the inside hole on the arm
-Mounted the body 4mm more forward
Old 05-11-2008, 01:42 PM   #1900
corallyman's Avatar
Trader Rating: 99 (100%+)
Default Setup Changes
Hey Randy,
That's great to hear that the car worked well for you and that you got a nice setup to run and work with. I'm sure you'll do great at the Reedy Race.
Could you explain what was the car doing that made you want to change it from the original setup that you had? What did each change do to the car?
Thanks,
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 05-11-2008, 03:28 PM   #1901
Basically the sorex tires just dont steer as aggressively as the RP's, so the changes I made were all to get the steering a bit more aggressive on corner entry.
Old 05-11-2008, 05:50 PM   #1902
TLR 22 3.0
TLR 22-4
Cooper Motorsports
Old 05-11-2008, 08:53 PM   #1903
kschu's Avatar
hi guys, wat gun r u guys using now ???
im looking for new gun now...currently in my mind now is
1. 3PK Fasst
2. Helios 2.4ghz Spektrum
3. Spectrum DX3R
please gv some advise n opinion.....thanks
i saw the new Carbon insert Arm y'day..it's look very cool...wat is d advantages of using it ? if i use d carbon insert arm for FRONT, n use standard arm on REAR, do i gain more steering ???
Old 05-11-2008, 08:55 PM   #1904
kschu's Avatar
randy, wan ask u something,
*Moved the front arms all the way forward
- this will make d wheel base longer n more stable on high speed track rite?
*Moved the front swaybar mounts to the inside hole on the arm
- wat d purpose of this 1 ???
thanks
Old 05-12-2008, 12:02 AM   #1905
Moving the front arms forward will make the car more aggressive entering the corner. Moving the swaybar mounts to the inside just makes the swaybar feel softer.
As for radios, look around and you'll notice that most of the top drivers still use crystals. I haven't tried spectrum before, but honestly don't want to until I see the spectrum/dsm related issues go away.
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
