Old 05-03-2008, 02:07 PM   #1876
Trader Rating: 20 (100%+)
Does anyone want to trade a carpet chassis & upper deck for a good Lipo? Pics are on the for sale or trade forum.
TLR 22 3.0
TLR 22-4
Cooper Motorsports
R.Fenstermacher is offline   Reply With Quote
Old 05-04-2008, 10:11 PM   #1877
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
hi guys, any1 of u ever use Speed Passion Gt 1.1 esc???
thanks
Give the best while u can !
kschu is offline   Reply With Quote
Old 05-04-2008, 11:01 PM   #1878
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I ran a couple of them when they first came out, but didn't have the best luck with them. Thermal shutoffs and couldn't get them programmed to feel like an LRP. Stick with the ESC that you have, it's the best available.
Old 05-04-2008, 11:14 PM   #1879
kschu's Avatar
randy, d sphere 07 i have cannot run 6cell for 3.5r...it's oni can use 5cell...i have big disadvantages on d straight which i easily being overtake by 6cell car....
i see d tc sphere also nt much different than sphere 07. only it's can run 6 cell. the price for tc sphere is much more higher ....
so i thinking wan to try sp GT 1.1 ....
randy, you run sp Gt or sp GT 1.1 before??
do u know wat billy easton using for his s400 ??LRP or SP ?
Old 05-04-2008, 11:35 PM   #1880
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
the LRP TC is by far alot better than the 07 and can handle motors down to 3.5,(2.5 with 5 cells) the SP 1.1 is a great esc, i had no problems with thermal issues , just takes a little tome to find the perfect settings , the TC is very smooth you will be happy with it.
Old 05-05-2008, 12:12 AM   #1881
kschu's Avatar
since u said ok then i will take it ..i dun have enuf budget for LRP TC spec...
TC spec is usd250 while SP GT 1.1 is USD174...
Old 05-05-2008, 06:51 AM   #1882
yyhayyim's Avatar
Trader Rating: 26 (100%+)
The SP GT is very good ESC, I think you'll really like it.
yyhayyim is offline   Reply With Quote
Old 05-05-2008, 07:20 AM   #1883
Phoenix82's Avatar
Default s400
Hi guys, looking for a used s400 chassis. let me know.
Nick
Phoenix82 is offline   Reply With Quote
Old 05-05-2008, 08:11 AM   #1884
I believe I ran the 1.1, but not sure, it was updated from the origional ESC's.
I'm not sure what Billy runs, I think I saw an LRP in his car in some pics I saw a while ago, but not 100% sure about that.
If you are running mod, the extra $75 is worth it, it is a big difference. I also gained about 2 laps worth of runtime when I switched back to LRP which is insane.
Old 05-05-2008, 08:51 PM   #1885
rustlerboi1052's Avatar
Trader Rating: 19 (100%+)
I'm sure MANY other people have had and will have the thrust bearing problem in the stock diff, but the Duratrax Differential rebuild kit has close to 1.5mm thrust balls that work perfectly in replacement of the stock s400 thrust bearing. I just installed them and did a test run and it works great...
rustlerboi1052 is offline   Reply With Quote
Old 05-06-2008, 12:03 AM   #1886
kschu's Avatar
the new thrust ball bearing set from serpent can help u solve d problem....
Old 05-06-2008, 08:34 AM   #1887
yyhayyim's Avatar
Told you...that's all you need. And if you really want a very long lasting and super smooth diff, get the Serpent S400 Ceramic 3mm balls for your diff, and then get ceramic 1.5mm balls for the thrust bearing section and the diff will be super smooth and last a long time.
www.acerracing.com
They have them in stock for great price...nothing better for a long lasting super smooth diff
Old 05-06-2008, 08:37 AM   #1888
yyhayyim's Avatar
True, and JAAD has come out with a Ceramic Thrust bearing kit for the S400.
www.precisionrc.com
they have them in stock
Old 05-06-2008, 08:47 AM   #1889
www.precisionrc.com
Last week I ran my S400 with rear diff using the Serepnt ceramic balls and the JAAD S400 thrust bearing and its really good. Ran 8 packs with 3.5 and Lipo and the diff is super smooth. Car rotates better also
RCLocos is offline   Reply With Quote
Old 05-06-2008, 02:23 PM   #1890
yyhayyim was the one to suggest me to do that and it works flawlessly. I'll be getting the gear diff sooner or later anyways, just because its so consistant, but this will work until I get it.
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
