Old 04-28-2008, 11:39 PM   #1846
Randy Caster's Avatar
Trader Rating: 46 (100%+)
The lower capacity lipo's should have a faster discharge rate that will help you get some more top end out of the motor as well. The car is awesome how it is currently, get one now and use the new bulkheads/upper deck as a tuning option.
Someone else will have to answer the spares question though, because I have yet to have anything break.
And to answer the other question, LRP Sphere TC is probably your best bet, and easilly fits in the car.
Old 04-29-2008, 01:35 AM   #1847
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
any1 ever try diff brand knuckle in s400 ?? do any1 know if serpent will come with aluminium knuckle ??
Give the best while u can !
kschu is offline   Reply With Quote
Old 04-29-2008, 05:09 AM   #1848
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
are you talking about the knuckle itself or the C hub? We already have the C Hubs from Serpent, they are in stock, Do not see a lot of knuckles go out.
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 04-29-2008, 06:50 AM   #1849
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Typical Spares you would get for any other car...
Steering Blocks
C Hubs
Front Arms
Rear Arms
Belts
CVD's
That being said... I did not break anythign on the car for the first couple of months. ( and I hit things HARD )
Things you may consider when buying the car
Gear Diff + 3k, 5k ,7k Oils
Spool Outdrives
Additional Springs
Originally Posted by RCLocos View Post
Man, are you a Serpent driver? You write reports like them pros. Good read and very encouraging. They make me wanna get one. I'm kinda holding back till I hear more about the new bulkhead and top deck release though. I got some Trakpower 4900 Lipos and want to get them to fit with no pblms.
Although might just sell them off and get me some SMC 4000 and just get the S400. Car looks sweet and seems like its really smoking every body.
My girl's dad is a Serpent fan and drives Serpent 720. He gets discounts and could hook me up with a S400. What parts should I get for spares and what Speed control you all recommend for 13.5 and 10.5...cause I'm tired of my GTB already. Need something new.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 04-29-2008, 07:08 AM   #1850
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Thanks for the nice comments. Yes, I'm a Serpent driver: I drive an S400. But I'm not team driver or sponsored driver
Get the S400 now. Dont let a battery keep you from enjoying the car. If you are anything competetive, then this car is for you. Just get Orion 3600 or SMC4000 packs and you'll be on your way to experiencing what we've all come to enjoy from the S400: a sweet looking, super simple design, very durable, sharp handling, cheap parts, good support car.
I dare you to find a car better all around I've had them all and ran pretty much everything for the last couple yrs and the S400 is the best all around car I've had so far.
yyhayyim is offline   Reply With Quote
Old 04-29-2008, 10:45 AM   #1851
What's wrong with the stock knuckles?
Old 04-29-2008, 03:30 PM   #1852
yyhayyim's Avatar
S400 knuckles are tough...never had one of them break after running the S400 for nearly 3 months my first time around with the car.
Old 04-29-2008, 05:20 PM   #1853
kschu's Avatar
knuckle are fine but d screw hole will get loose easily...i oredi use it for 5 month....i owes open d knuckle to service d bearings....so i think tat cause d screw hole to loose...
Old 04-29-2008, 05:30 PM   #1854
I haven't had any problems like that, you may have overtightened the screw and stripped the threads a bit...
Old 04-29-2008, 07:49 PM   #1855
AdamD's Avatar
I would highly recommend the S400. It works with the kit setup. Great car right out of the box. I would order the gear diff with the kit. As far as parts Tim Potter's list looks good. You might want to get a set of hinge pins. The SMC 4000 would be a good choice in Lipo. I would also agree with Randy about the speedo, but you might wait a week or two for the new Tekin RS line. They have advance timing adjustment and they are smaller then the TC Spec. Just my .02 cents.
AJ DiPirro
T.O.P. Racing U.S.A. / Serpent America / EA Motorsports / Team Epic / Trinity
P3 Graphics / RC3 Grafix / Adco Paving Inc / Team Butter
AdamD is offline   Reply With Quote
Old 04-29-2008, 09:29 PM   #1856
kschu's Avatar
this is my hometown track.....
please visit our local EP blog.
http://rcep4u.jonehrc.com
Serpent to 1/10th EP Touring Kit S400-hms-track.jpg
Old 04-29-2008, 11:33 PM   #1857
Moderator
pc9840's Avatar
Send a message via ICQ to pc9840 Send a message via AIM to pc9840 Send a message via Yahoo to pc9840
What are you guys using for a diff seal for the gear diff. Mine is leaking a little so I need to replace it but I can't find them in stock anywhere.
[email protected] <><
"The minimum wouldn't be the minimum if the minimum wasn't good enough"
pc9840 is offline   Reply With Quote
Old 04-29-2008, 11:56 PM   #1858
I havent had any leaking problems with mine, but I suppose if I was having the problem I'd start off by getting a new O-Ring.
Old 04-29-2008, 11:59 PM   #1859
Moderator
pc9840's Avatar
Thats what I am going to do, was just wondering if anyone had already done the leg work to get the size of the o-ring. Looks like I will just take the old one with me down to the local hardware store.
Old 04-30-2008, 01:34 AM   #1860
shhhhhhhhhhhhhhhhhhh 415 front knuckles fit an look lovley de-anodised
richard baker is offline   Reply With Quote
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
