Old 04-27-2008, 09:14 AM   #1816
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by TeamButter View Post
If you are referring to the center pulleys, the Hot Bodies Cyclone pulleys will work. (18 tooth) Remember that it would change your internal drive from 2.185 to 1.944 and you will need to use longer belts both front and rear.
If you need some of the longer belts, I have some. PM me for more info.
Butter
butter, is tat meaning 16T from cyclone will fit into s400 ??? delrin pulley will less tear n wear to belt if compare with aluminium?? im interested on 3racing center pulley..
Give the best while u can !
kschu is offline   Reply With Quote
Old 04-27-2008, 10:20 AM   #1817
TeamButter's Avatar
Send a message via AIM to TeamButter
kschu-the 18 tooth center pulley is what I am referring to. I have not tried the 16 tooth delrin HB pulley.
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 04-27-2008, 11:00 AM   #1818
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I'm sure the 16 tooth pulleys would fit as well, should be the same mounts as the 18's.
Old 04-27-2008, 01:51 PM   #1819
tallyrc's Avatar
Originally Posted by Randy Caster View Post
The longer upper deck and new bulkheads that Serpent is testing should work much better on asphalt allowing the chassis to flex a lot more than it currently does..
oh i'm sure it will work better, i'm just scared of what it will cost.
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 04-27-2008, 03:11 PM   #1820
So far everything they have released has had extremely competitive pricing on it, so I'd expect the new parts to be the same...
Old 04-27-2008, 05:27 PM   #1821
kschu's Avatar
i'm planning to get this...dunno if it's can withstand d power of BL 3.5r.....
Serpent to 1/10th EP Touring Kit S400-cyclone-pulley.jpg
Old 04-27-2008, 05:52 PM   #1822
It should no problem, Tamiya cars mount their plastic gears just like that.
Old 04-27-2008, 06:55 PM   #1823
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Dont worry about that Jason. Serpent parts are considerably lower priced that their TC competitors.
yyhayyim is offline   Reply With Quote
Old 04-27-2008, 07:13 PM   #1824
tallyrc's Avatar
parts prices was a major factor in my selecting the serpent.. and was the entire reason i sold my x-car
Old 04-27-2008, 07:34 PM   #1825
kschu's Avatar
if cyclone pulley can fit, then tamiya pulley can fit as well ???
will d belt last longer is using delrin teeth pulley instead of aluminium pulley???
Old 04-27-2008, 07:46 PM   #1826
Not bad for a day in the office for Serpent
VIKTOR WILCK 20PTS
MARC RHEINARD 18 PTS
MASAMI HIOSAKA 15 PTS- gets 3rd because of high best run
HAYATO MATSUZAKI 15PTS
BILLY EASTON 15PTS
JILLES GROSKAMP 13 PTS
SURIKARN 11PTS
ATSUSHI HARA 8 PTS
MEEN VEJRAK 7 PTS
HUPO HONIGL 5 PTS
Worlds Warm Up Race
iceman76 is offline   Reply With Quote
Old 04-27-2008, 08:02 PM   #1827
yyhayyim's Avatar
The new S400 Aramid belts are probably the toughest long lasting in the market. You will get most life out of them with the stock S400 pulleys, or delrin 16T Pulleys from HB Cyclone/3Racing.
Once you change to the non-Serpent 18T pulleys and need to use longer Belts, then you must make sure the non-Serpent longer belts are as tough and long lasting as the S400 belts(which I doubt) so they can work well with the aluminum pulleys...although the delrin pulleys might be just slightly better for belt wear in the long run, but the delrin pulley will wear a bit faster than the belts. Its a trade off...although with the lighter delrin pulleys you might have a slight acceleration advantage or improvement due to less rotational mass
Old 04-27-2008, 08:08 PM   #1828
Make sure your car is ready for Wed show down also let the wife know u are going
Old 04-27-2008, 09:02 PM   #1829
yyhayyim's Avatar
The Python is ready
I just hope my ESC and motor can keep up
Looooooook out!!!! Get that anti-venom
Serpent to 1/10th EP Touring Kit S400-snake-bites-face.jpg
Old 04-27-2008, 10:22 PM   #1830
No, the Tamiya pulleys won't fit. I havent seen any wear on my updated belts at all with the aluminum pulleys, once you switch over you should have no problems.
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
