Old 04-24-2008, 02:55 PM   #1756
Centerline Racing's Avatar
Trader Rating: 33 (100%+)
Originally Posted by ammdrew View Post
Allan after that awsome stock sedan win last weekend, looks like the monkey is off your back ...... may need new shirts
After further review of the video footage and the JLap timing sheet, it would seem that the "Monkey" on my back needs to stay, even for a little while.
Conner got mixed up when the track rail jumped out and hit his car. Even after going in circles he was only about 2 seconds behind me at the checkers.
I've got the vids rendered, just need to get them on DVD and YouTube. Very exciting.
Centerline Racing is offline   Reply With Quote
Old 04-24-2008, 03:08 PM   #1757
colonrc's Avatar
Originally Posted by TimPotter View Post
Randy, anytime you want to come down and run on the track... I am sure you can crash with Butter, or for that matter, I have a spare room...
We have a Reedy Style race in July...
When in July is this race? I might be able to make it.
Serpent U.S.A , Maxy's Pro Racing Fuel , Murnan Modified Motors,Nexus Racing,Mike Desing,Member of GO-R/C
colonrc is offline   Reply With Quote
Old 04-24-2008, 04:19 PM   #1758
yyhayyim's Avatar
Trader Rating: 26 (100%+)
on the 19th, Saturday
yyhayyim is offline   Reply With Quote
Old 04-24-2008, 04:22 PM   #1759
yyhayyim's Avatar
BTW, Johan, you car looked awesome by the end of the night... I was trying something different too... Car was ok.... but still have few more things to try before giving up..
Thanks Tim. I forgot to let you try it. Next Wed you'll get first try and let me know what you think
Old 04-24-2008, 04:28 PM   #1760
yyhayyim's Avatar
Originally Posted by Victor A View Post
Serpent is developing some new parts for the S400. I've made some pictures, here's the link: http://rctouring.eu/serpent_s400_prototype.htm .
Greetings Victor
Thanks Victor. Great newz alright. Looks even better with the thinner longer top deck. Is it a 2mm top deck? Are the new rear bulkheads a bit higher to allow better fitment of of Lipos better?
When are the new parts being released?
Old 04-24-2008, 05:59 PM   #1761
yyhayyim's Avatar
Originally Posted by pc9840 View Post
Yes 500cst, my bad I was thinking what was in the kit and typed what I was running.
Hmmm...It doesnt seem like the S400 kit oil is 50cst...maybe its 600cst, since serpent doesnt seem to make a 500cst oil, according to their site:http://www.serpent.com/product/1679/
30W (350cst)
35W (600cst),
40W (1000cst)
45W (1400cst)
But the manual lists a 500cst oil in parts list section on back
Old 04-24-2008, 07:48 PM   #1762
tallyrc's Avatar
yohan that long top deck looks to eliminate the stub of bulkhead that keeps lipos from fiting all together without having to raise the deck... if you raise the back you'd have to raise the front and find a way to keep the bellcrank in there too.. must also require larger center pulleys as i don't think the belt would otherwise clear?
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 04-24-2008, 07:59 PM   #1763
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
IF the "updated" S400 can fit the Orion 4800 or the Checkpoint 5400 with Verndogs Lipo weights, I think I may replace my TC5 with one
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 04-24-2008, 08:09 PM   #1764
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
i think d new thinner upper deck is to make d car more flex which suitable in low traction track....
great to hear that they come out with LIPO bulkhead...
anyone r using LRP vector x11 BL motor ? wat is d different btwn LRP Vector and Orion Vortex ??
Give the best while u can !
kschu is offline   Reply With Quote
Old 04-24-2008, 08:12 PM   #1765
Hi Jason: the way it is now, the SMC4000 packs fit perfectly. No mods necessary. However, anything above 22mm will not fit, and its a problem since most 5000 Lipo packs are around 23.5mm tall.
On the new one, one way to raise the back and front is with shims. a 1mm or 1.5mm shim on all 4 corners, plus one on top of the bell crank. It should work OK. This is what was done with Xray T2'007 and E4.
But I think the newer design does take care of clearance issues, like you mentioned. It looks so much sleeker and elegant. Xray '008 have very similar top deck, as well as the new Kyosho '008 prototype.
Xtreme2008 is offline   Reply With Quote
Old 04-24-2008, 08:18 PM   #1766
Greetings Victor
Hi Victor: I noticed the S400 front drive is different: is that a new design spool up front?
Old 04-24-2008, 08:21 PM   #1767
The LRP motors have more torque out of the box but slightly less RPM than Novak and Orion Motors. BUt once you gear the LRPs right, they are exellent. The Orion motors you need to use more teeth on the pinion to get them up to speed. They run cooler as well due to the cooling holes on their can.
Either one is really good. After testing both systems, the LRP Sphere TC with Orion 3.5 or 4.5 Motors is really good combo.
Old 04-24-2008, 08:33 PM   #1768
yyhayyim's Avatar
Hmmm...I think that the new bulkheads and top deck design will defenitely get the Lipos to fit OK(Orion 4800 sizes). at worst case, just add 1-2mm shims and raise the top deck.
About the belts clearing: the HB 18T pulleys should take care of that if its really needed.
Hope to see ya next week with your S400...I heard you got one, too?
Old 04-24-2008, 08:33 PM   #1769
kschu's Avatar
hi extreme, 3.5r motor are more to high speed ? 4.5r is high speed and torque or i'm wrong ? why nobody r using 4.0r ???
Old 04-24-2008, 08:35 PM   #1770
yyhayyim's Avatar
I agree...but the LRP 4.5 is not as fast as Novak and Orion 4.5. The 3.5 from LRP is on par with Novak and Orion...but the Speed Passion GT and LRP Sphere with Novak or Orion motors with good Lipos will blow the doors off most other systems
Second Touring Car? Mi3 or Serpent S400 SocialRC12 Electric On-Road 16 08-11-2009 12:04 PM
Serpent S400 Electric Touring Car yyhayyim R/C Items: For Sale/Trade 13 11-07-2007 06:08 PM
Serpent S400 EP Touring Car CheeYong Malaysian R/C Racers 54 11-05-2007 05:57 AM
SERPENT S400 TOURING ELECTRIC CAR Team Kamikaze Electric On-Road 4 08-30-2007 06:38 PM
New Serpent S400 EP 1/10 Touring Car!!!!! Roniel_R Electric On-Road 3 05-26-2007 06:58 PM
