Foamy sized brushless airplane motor and 12a esc >
Old 05-24-2007, 06:09 PM
Default Foamy sized brushless airplane motor and 12a esc
This is a nice little motor. Very nice looking as well, anodized blue and chrome colored.
This 1300kv outrunner will get about 15oz thrust base weight of motor is 24 grams. I'm including the pictured prop saver as well as a firewall mount for the motor!
The ESC is 10a and is a towerpro. Nothing special, it works and has a BEC with 2 and 3s lipo as well as nihm cut offs. Good combo with the motor but I'm willing to sell each seperatly.
info on the spedo:
A great little 12A BESC, very light and very stable.
This is the newer generation, with a much smoother throttle curve.
The BESC weighs 9g, however if you change the wires and remove the heatshrink it can be around 6-7g
Rating: 12A Burst, 10A Constant
FET: 6
BEC: 1.5Amp
Timing: Auto
PWM: 8k
Lipo: 2~3
NiMH:4~12
$17 for the combo shipped. or $10 each shipped!
Even Jesus can't go brushless cheaper than that!
Attached Thumbnails Foamy sized brushless airplane motor and 12a esc-small-motor-001.jpg   Foamy sized brushless airplane motor and 12a esc-small-motor-002.jpg   Foamy sized brushless airplane motor and 12a esc-small-motor-003.jpg   Foamy sized brushless airplane motor and 12a esc-small-motor-004.jpg
GigaahX is offline
Old 05-24-2007, 10:06 PM
I don't understand why you'd post that here. It's an airplane motor, and probably doesn't have brakes so it couldn't be used for an onroad electric regardless.
quick5pnt0 is offline
