Old 05-23-2007, 01:29 PM   #1
Default Manta Ray Ball Diff for Minis
Can someone please explain to me how to lock the diff using a Manta Ray Ball Diff for a Tamiya MO3 Mini.... I have heard of people using Shoe Ghoe..... Just curious how to lock it.....
csalfly is offline   Reply With Quote
Old 05-23-2007, 01:56 PM   #2
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
I wouldn't recommend usng the ball diff to make a spool. The stock gear diff is much tougher and can hold up better. And it's really easy to lock up with shims.
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 05-23-2007, 02:35 PM   #3
Trader Rating: 18 (100%+)
When I locked the diff the car wouldn't handle worth a darn. Putting the Tamiya Anti Wear grease in it made it stiffer yet kept the car drivable.
YMMV
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 05-23-2007, 04:11 PM   #4
I might add the only place I would use a spool is on carpet...asphalt, use the diff and build it per instructions.
Old 05-23-2007, 04:27 PM   #5
YMMV
It's you're driving Mr. D
Sydewynder is offline   Reply With Quote
Old 05-23-2007, 04:32 PM   #6
Like the others said don't lock a ball diff. If you want a spool do it on a gear diff. Ask in the mini cooper thread. You'll get more info there. Most just shim the gear diff tight to limit wheel spin.
Old 05-23-2007, 05:36 PM   #7
You know better! It's Mrs. D that drives the Mini!
Old 05-23-2007, 06:38 PM   #8
Don't go blaming your better half.
Old 10-02-2007, 12:00 AM   #9
SirSwiftAlot's Avatar
Location: SOCAL the fastest mini cooper guys in the nation
I disagree a little.
That is true shim the hell out of the gear diff but what you put in it is the secret.
The only way to go is with the TAO3 Ball diff but again there are secrets to that one too, Trust me I've been through 6 of them untill I found out the secret.
Why do people park in a driveway but then drive in a parkway?
SirSwiftAlot is offline   Reply With Quote
Old 10-02-2007, 12:05 AM   #10
razzor's Avatar
Please share the secret with us !!!
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 10-02-2007, 12:44 AM   #11
There are no secrets. Ball diff, gear diff, tight, loose , "spool", all have advantages and disadvantages. You just have to figure out what works best for you at your track. Now, tires and inserts and sivercan tuning, there's where the secrets are. Good luck on finding those.
Granpa is offline   Reply With Quote
Old 10-02-2007, 06:34 AM   #12
rccardr's Avatar
Agreed. I travel with four different diffs for my Mini.
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 10-02-2007, 07:53 AM   #13
trjracing's Avatar
You can also use heavy duty wheel bearing grease from the auto parts store, just pack it in your stock diff and it will make a difference, I packed it in on my stock diff and what a difference it made. It minimized torque roll and it helped my handling alot. I've been doing this to my tamiya diffs, monster truck diffs, for just over 3 years now and it works great the only minor set back is the diff is a little more heavy because of the grease. It was a cheap fix since I had it laying around in the basement, I figured I try it and it works great. It doesn't hurt to try. Good Luck...
GOD IS GOOD, LIFE IS GOOD... I AM THE BAD BREED... B.B.R. BADBREEDRACING... Rest In Peace Marshall G. Winston America's Hobby Center, You will be missed...
trjracing is offline   Reply With Quote
Old 10-02-2007, 08:11 AM   #14
Default Diff
Gear diff with tamiya antiwear... transfers power to the ground better... and faster the diff works, the more stiff it becomes... analogy, stirring a thick cake slowly, then stir faster,,, it becomes much harder to stir...
gear diff becomes like spool in corners during the lifting of inner tire... not sure if i make sense
rccartips is offline   Reply With Quote
Gear Diff VS Ball DIff NOVICE4EVER Singapore R/C Racers 23 08-29-2012 10:03 PM
losi xxxt ball diff change to a 1/10 desert truck diff newbie2 Electric Off-Road 49 12-13-2010 08:49 PM
NTC3 Complete ATD Diff, diff nut, pivot ball socket caps Judge Joe Brown R/C Items: For Sale/Trade 2 05-09-2008 10:18 PM
Mini M03 & M04 Ball Differential (Manta Ray) rccardr R/C Items: For Sale/Trade 2 09-24-2005 01:03 PM
FS: T1FK'04, '04 Multi-diff, ball diff bbentley40 R/C Items: For Sale/Trade 4 05-17-2005 08:22 PM
