Old 09-28-2007, 11:39 AM   #256
James35's Avatar
Terry,
Our loop is under the track. If I mount this PTX upside down, will the signal strength be weakened? In otherwords, is the signal transmitter designed to fire down?
James35 is offline   Reply With Quote
Old 09-28-2007, 11:58 AM   #257
Hi James, the signal is transmitted from the top and bottom of the transponder via an internal aerial loop which runs around the edge of the circuit board inside the case. It's the same for the original AMB PT, the i-PT and the PTX. It will work the same either way up, it's the same if the transponder is mounted the right way up or upside down.
The signal is much weaker from the sides and ends of the transponder so it's definately not a good idea to mount it any way other than horizontally. The signal is also weakened by carbon fibre (ie chassis etc) so for the strongest signal the transponder should have a clear unobstructed opening to the loop around the whole case.
Terry_S is offline   Reply With Quote
Old 09-28-2007, 01:05 PM   #258
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
when will these be available ??
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 09-28-2007, 01:37 PM   #259
Nathan Parker's Avatar
now
Nathan Parker is offline   Reply With Quote
Old 09-28-2007, 03:07 PM   #260
Bobby Z's Avatar
Hi Terry
I sent you a PM to answer some questions but I have a suggestion to make that might be very helfpul.
After reading this entire thread there is one drawback that I see coming up over and over again. Shipping the original AMB PT to you in the UK so you can 'read' or upload the signal from the PT. Would it be worthwhile to set someone up in the U.S. with the required equipment to read or scan the signal? After that is done, can the signal be saved to a file and then sent to you by some secure means? I.E. FTP site. I notice that once someone sends you their PT and you 'read' the signal or number that you have it stored away. This leads me to believe saving the signal to a file of some kind is possible.
This would allow U.S. customers the option of shipping their PT to someone in the U.S. for scanning, with a much quicker turnaround, and may allow more drivers the option of buying the PTX with the cloned # option.
If this is all possible, I volunteer and I'm sure we could work out a very amicable arrangement to cover the time requied to fulfill this duty.
Bobby Z is offline   Reply With Quote
Old 09-28-2007, 03:36 PM   #261
vabroom's Avatar
Question: What service or class of mail are you guys using from the US?
vabroom is offline   Reply With Quote
Old 09-29-2007, 01:07 PM   #262
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
Default Terry ygpm
Terry, you have a PM
thank you
_|Team Academy GV2 Pro_|_Team Academy SBV2 Pro|_--->Losi xxxbK2 (FOR SALE)
_|Factory Tracks Midwest Series_|_www.factorytracks.com|_
_|Team Upgrade-RCid_|_www.upgrade-rc.com|_
_|MRC/Team Academy_|_www.modelrec.com|_
rdub202 is offline   Reply With Quote
Old 10-03-2007, 04:03 PM   #263
do they still make a transponder that works with amb 20 . the one that you can change from 1 thru 10 ? please
BIGSAM is offline   Reply With Quote
Old 10-03-2007, 04:09 PM   #264
yes
Old 10-03-2007, 09:54 PM   #265
thanks nathan. i see that terrys place sells them but they seem to be out of stock dose any body know when their going to be ready to buy ? thanks sammy
Old 10-05-2007, 03:12 PM   #266
James35's Avatar
Terry, can we order a spare bottom PTX plate? Being able to switch between tabs and no tabs would be great!
Old 10-05-2007, 03:12 PM   #267
Originally Posted by Bobby Z View Post
Hi Terry
Hi Bobby, YGPM. Please PM with your CV re the above, it is a possibility.
Old 10-05-2007, 03:17 PM   #268
Hi vabroom, we receive most shipments from the US via USPS with tracking and loss/damage insurance included.
Hi rdub202, YGPM!
Hi BIGSAM, YGPM.. the answer is yes we still make the T1-10 transponder for the AMB20 system. Product details on our main web page @ www.team-mrt.com (scroll down the page).
Old 10-06-2007, 03:12 AM   #269
Hi James, yes spare base plates are available as well as screw sets and leads. It's easy to switch between tabs and no tabs, just unscrew the base and change it.
Old 10-06-2007, 03:30 AM   #270
Hi Nathan, thanks for your help replying to the transponder questions!
AMB Personal Transponder biker R/C Items: For Sale/Trade 1 10-02-2007 10:18 PM
WTB: Turbo 35 BL or Stealth, and AMB personal Transponder Beamer#2 R/C Items: Wanted to Buy 0 08-02-2005 09:55 AM
AMB personal transponder racerx75034 R/C Items: For Sale/Trade 5 01-18-2005 10:52 PM
AMB personal transponder jrighter R/C Items: For Sale/Trade 4 01-18-2005 12:06 PM
AMB Personal Transponder TRAJ R/C Items: For Sale/Trade 0 12-18-2004 08:29 AM
