glitching help!
Old 05-22-2007, 08:35 PM
Default glitching help!
ok i run on a out door aphsalt track and run a sanwa m11 on 40meg with original crystals and 311 reciever, a sanwa wrx digital servo, novak gt7 esc, and a much more fan running of the battery leads. no pt. but when i go aroung the sweepers and tight turns where throttle and steering is being used i can hear the motor shutter as if there is voltage drop. it happen consitently and isnt going to send my car of course but i feel like im not getting 100% throttle when i apply it in these spots.
so is there a way to fix this? im running i silver can 540 motor. with 3 .01uf caps and a 1n5822 skhotty diode.
any one have simmilar problems?
cheers guys
aus jd 2703 is offline
Old 05-22-2007, 09:14 PM
acko's Avatar
1st thing 1st. how close are battery wires and motor wires to the reciever, aerial wire, speedy etc....
acko is offline
Old 05-22-2007, 09:17 PM
STARSCREAM's Avatar
I would start by replacing the least expensive thing on your car and work from there...
Different crystal or channel first...then re-wire your speedo and place it a little differently on the chassis...
if this doesnt solve it, try a different servo and move your transponder around...
good luck dude!
STARSCREAM is offline
Old 05-22-2007, 10:26 PM
Super Moderator
Marcos.J's Avatar
Trader Rating: 217 (100%+)
cheers guys
there is a very easy fix to your glitching problems:
SPEKTRUM
Marcos.J is offline
Old 05-22-2007, 10:31 PM
acko's Avatar
good luck dude!
start with the easy things first without spending any money. check wiring. parts fitters replace parts trying to solve problems, technicans solve problems then replace the 1 problem part if a part needs replacing at all. most of the gliching problems ive seen have to do with the way wires are run
acko is offline
Old 05-23-2007, 12:01 AM
ok so motor wire are away from servo wire as i have the servo wire tucked to the side of the esc and the power wires running over the top deck. so i dont think its a wire issue but im guessing.
would the servo being digital have anything to do with this?
Old 05-24-2007, 05:43 PM
ive moved the wiring and run capacitors on the radio neither helped and suggestions?
