Diff problem
Old 05-21-2007, 09:14 PM
echo's Avatar
Default Diff problem
Hi, guys. My TRF ball diff have a problem i hold diff joint (L,R) but i can still rotate (loose) the diff pulley i already change diff plate, diff pulley and try to tight the screw but is not work. what should i do? Thanks
echo is offline
Old 05-21-2007, 09:29 PM
subaru73's Avatar
Trader Rating: 42 (100%+)
Default Trf diff
make shure the spring is in the outdrive then the retainer and then the locknut.tighten the diff enouf that the diff pulley slips a little.hopes this helps.
subaru73 is offline
Old 05-21-2007, 09:49 PM
echo's Avatar
I change the spring, screw, trust bearing with my other TRF but is not work. How about diff joint it can be this?
echo is offline
Old 05-21-2007, 10:36 PM
Default Diff's
Unlikely that it is the outdrives, make sure you didn't put in 1/8" balls instead of 3mm balls. If this doesn't help could you please specify what your running, TA05, TB02, Mini, 415 etc.
_pilot_ is offline
