charger questions >
charger questions
charger questions
Old 05-20-2007, 02:08 PM
Branden Moody's Avatar
Default charger questions
I have a orion charger with a seperate 10 amp power supply I was wondering if I can hook up 2 chargers to it and if it would be safe
Branden Moody is offline
Old 05-20-2007, 03:28 PM
morris's Avatar
Trader Rating: 44 (100%+)
you can hook 2 chargers to your power supply.but beings that it is only 10 amps you would only safely be able to charge at 4 amps per pack.
batteries these days usually charge at 6 amps...
hope this helps
morris is offline
Old 05-20-2007, 03:33 PM
ok thanks
Old 05-20-2007, 06:49 PM
morris's Avatar
Originally Posted by Branden Moody
ok thanks
i also forgot to mention that you could charge at 5 amps per charger...but this will put 10 amps at the power supply......you could try it...im not sure how safe it would be...
you should be able to get like a 20-25 amp power supply at radio shack for under 100 bucks.....
matt
morris is offline
