Old 04-14-2003, 08:25 PM   #1
Racer4Life's Avatar
Trader Rating: 18 (100%+)
TC3 steering swap for XXX-S
Has anyone done this? Could you please let me know what parts I need to complete this swap.
Tom
Racer4Life is offline   Reply With Quote
Old 04-15-2003, 02:29 AM   #2
Cole Trickle's Avatar
Why?
I cant figure if you want a TC3 steering on an XXX-S or the opposite, but both cars are designed in a holistisk way of thinking, so I cant imagine other, than you would spoil the composition.
As far as I know, the TC3 is designed with asymmetrical suspension with the purpose to counteract for the torque steer due to the shaft. That wont work on a belt drive car....
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 04-15-2003, 03:50 AM   #3
LouisB's Avatar
As far as I know it's impossible, the 2 set-ups are just so different.
LouisB is offline   Reply With Quote
Old 04-15-2003, 03:58 AM   #4
Im2lazy's Avatar
I thought most guys preffered to change the TC3 hubs into the xxxs steering as opposed to going from xxxs steering stuff to TC3 steering?
Changing tc3 steering knuckles and carriers for xxxs steering knuckles and carriers is done to provide more steering throw if I am not mistaken.
Im2lazy is offline   Reply With Quote
Old 04-15-2003, 04:03 AM   #5
LouisB's Avatar
Oh, stering knuckles and carriers
Yeah, what Im2lazy said is right.
Old 04-15-2003, 05:30 AM   #6
Default TC3 and XXX-S CVD axle
Hi,
Does that means that the TC3 and XXX-S CVD axle are similar ?
ongbenghui is offline   Reply With Quote
Old 04-15-2003, 07:30 AM   #7
Racer4Life's Avatar
Exclamation
Sorry Guys! I should have been more specific.
I had read in a articale that putting the XXX-S steering knuckles on the TC3 would give you more steering throw. (as Im2lazy clarified for me)
I wanted to know what parts I need to order to do the swap out. I don't have a parts breakdown for the XXX-S, so I was hoping that someone that has done it or seen it posted on another site could help me out. OR the other option is to let me know what items need to be swapped and I can just ask the hooby store for the parts.
Thanks Again
Tom
Old 04-15-2003, 07:36 AM   #8
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
Just buy the xxxs steering knuckles and throw them on! Direct fit with no modifications....
pimpedaccord is offline   Reply With Quote
Old 04-15-2003, 07:44 AM   #9
Yes, it's a direct fit. We swapped ours because the Losi knuckles hold up better, specifically the kingpin holes don't wear out as quickly. We also use Losi 6 degree hub carriers.
coolrcdad is offline   Reply With Quote
Old 04-15-2003, 09:17 AM   #10
Send a message via Yahoo to miniman
The TC3 CVD bones are about the thickness of one cvd-pin shorter than the xxx-s bones
Since the Losi cvd`s go quite far into the outdrives, I think they would fit. If durability went down, you could get the trinity outdrive savers.
miniman is offline   Reply With Quote
Old 04-15-2003, 10:27 AM   #11
It is a direct fit. I have the xxxs steering knuckles on my TC3.
RC311 is offline   Reply With Quote
Old 04-15-2003, 10:49 AM   #12
Registered User
Send a message via AIM to TommyGun43
I run the XXX-S steering knuckles because the stupid screw on
the bottom never loosens up like with the Associated
ones. If you use the hub carriers (they come with the steering knuckles...and the 6 degrees work great on carpet!) you will need to dremel the front of the carrier where it will hit the shock
with the new outer hole on the A-arms. Just giving you a heads
up on that.
TommyGun43 is offline   Reply With Quote
Old 04-15-2003, 07:18 PM   #13
Racer4Life's Avatar
Anyone got the part no#s so I can order them?
Tom
Old 04-15-2003, 08:59 PM   #14
Registered User
A-9752: 2 degree spindle set
A-9753: 4 degree spindle set
A-9754: 6 degree spindle set
They are about $11.00. All come with spindles and the hub
carriers also.
Old 04-16-2003, 05:33 AM   #15
Racer4Life's Avatar
Thanks to all who helped out on this!
TommyGun.. thanks for the numbers!
Tom
swap pharkingfast Australia Wanted to Buy 0 06-08-2008 07:21 AM
STEERING problems!! ie no steering creamsodauk Rookie Zone 5 06-30-2006 10:17 PM
SWAP!! Gav_XXXS Australia For Sale/Trade 5 06-07-2006 03:07 AM
for swap downunder23 R/C Items: For Sale/Trade 14 03-15-2006 06:46 PM
trx 2.5 swap rangered Electric Off-Road 1 04-25-2005 04:18 AM
