I NEED HELP  CYCLONE PROBLEM >
Old 05-19-2007, 02:51 PM
Elboogie's Avatar
Default I NEED HELP CYCLONE PROBLEM
I am opening this thread because I have a problem with my Cyclone and I cannot figure this out. I have been racing for 6 years now and I am experienced but this one is driving me crazy so I am going to ask help from anyone that owns the Cyclone.
I own a Cyclone WCE and I was racing one night and I broke a steering arm and a cvd.
Since that time when I hit the throttle and turn my servo to the right, when it is at full speed it is ok, but when it starts to slow down with the wheel turned to the right, it makes a binding noise.
Now I have replaced the CVD, steering block, C hub and everything else I could think of except the front belt.
I can't figure this out and it is driving me crazy. I am very meticulous about my car and my cyclone has always been extremely quiet but this makes my car loud when I turn to the right.
The noie almost sounds like it is coming from the right side of the steering column and then sometimes it sounds like it is coming from the layshaft area.
I NEED HELP
I would really like to hear any suggestions from ayone who has ran into this isue or anyone that has experience in RC and building kits.
Thanks guys.
Elboogie is offline
Old 05-19-2007, 02:53 PM
KHoff7's Avatar
Are they the alumnium or steel front cvd's because I had aluminum ones and they bent right away but the steel ones stay straight
KHoff7 is offline
Old 05-19-2007, 03:26 PM
Elboogie's Avatar
they are the cvd's that came with the kit.
Elboogie is offline
Old 05-19-2007, 04:17 PM
protc3's Avatar
is this with the spool or the oneway?
protc3 is offline
Old 05-19-2007, 04:19 PM
The stock units on the WCE edition dosen't bend, i'm driving 3,5t brushless and I've never bent any of them, however huge slop delevoped and had to replace them because of that.
The problem you describe is most likely drive train chatter, nothing you can do about that other than giving the parts a chance to break in, it'll most likely to away with time.
And ask this in the Hotbodies Cyclone thread next time, a good chance more Cyclone knowing people will see your post
Edit: you did, but why ask the same question in two different places?
Jan Larsen is offline
Old 05-19-2007, 05:26 PM
VoneS3Kid's Avatar
Hey, i am not a cyclone expert as i drive Xray. But try checking the blade at the end of the universal. This plastic peice clips on to the pin at the end of the CVD. Mine broke, made my car chatter turning one way really bad, make sure you check both sides. Also, how high is your steering rate, if my rate is up very high it starts chattering into corners. I hope this helps.
VoneS3Kid is offline
Old 05-19-2007, 06:55 PM
Elboogie's Avatar
Vones3kid
I never thought to check the diff cup adaters. I am going to replace mine and maybe this will help.
I placed it here first and then I saw the cyclone thread and posted it there as well
Elboogie is offline
Old 05-19-2007, 08:47 PM
Hi ,
I had a similar thing happen to my car after a crash and damage to the right front of my cyclone. The car afterward would make like a rubbing sound when turning hard right. I did as u did and changed almost everything on the right front and the sound remained. I discovered after the crash that the inside wheel rim would rub against the front suspension arm and that is what was creating the rubbing sound. So i replaced the suspension arm, suspension shafts and the noise disappeared.
Have no idea if this is the cause of your problem, but it is something to check, if you haven't already.
jimbobmahua is offline
Old 05-22-2007, 12:47 PM
Elboogie's Avatar
Thanks for the info guys, I will try that.
Elboogie is offline
Old 05-24-2007, 12:15 PM
Elboogie's Avatar
I FOUND THE PROBLEM
The problem was with the aluminum outdrives. Or it had to do with the CVD blades that I had to put on.
Yesterday I ordered a new diff for the Cyclone and used the outdrives that it came with instead of the aluminum ones. After installing the new diff, I hit the throttle and turned the car to the right and heard nothing. So it had to do with the outdrives being a little bent (could not see it) or with the blades that you have to put on the end of the CVD.
thanks guys.
Elboogie is offline
