Mamba Max with Vortex from Team Orion >
Old 05-18-2007, 01:41 AM
Default Mamba Max with Vortex from Team Orion
Did you try this combo? If you did can you share your expirience?
tomislav is offline
Old 05-18-2007, 05:03 PM
I myself have not tried it, but i have thought about it. Dont forget the vortex is a sensored brushless mate. As said previously in the castle creations thread, there designing an update to allow the use of sensored motors with the mamba max, you can run a vortex with the mamba, its just that the vortex might not run at its optimum performance, because the ESC is sensorless. Hope that clears things up for ya!!
Drift Demon is offline
Old 05-18-2007, 09:02 PM
wallyedmonds's Avatar
i would not do it
i just run the mamba stuff
and if i go to a race that wont allow it i just go home or not go.
wallyedmonds is offline
Old 05-19-2007, 12:59 AM
RC MARKET's Avatar
tested !
no problem !
only Mamba Max change setup brake
RC MARKET is offline
Old 05-19-2007, 04:56 AM
Captain Harlock's Avatar
I believe a sensorless esc can easily run sensored brushless motors.
Captain Harlock is offline
Old 05-19-2007, 07:20 AM
RC MARKET's Avatar
Yes !
Old 05-20-2007, 06:52 AM
Trader Rating: 38 (100%+)
My understanding is that is not correct. There have been reported problems with the Mamba Max running the Novak motors and Tekin as well is have -slight- issues (or was) with running the Novak motors as well.
or8ital is offline
Old 05-20-2007, 07:45 AM
You might take a look at John Stranahan's Pantoura thread. He has done a lot of testing with Novak motors and Novak, LRP and MM speed controls. He has also completely redesigned the front and rear suspension of his 1/10 pan car. It is wicked fast and hangs with pretty much anything else that might be on the track when he is. Don
DLS II is offline
Old 05-20-2007, 08:08 AM
CRASH's Avatar
Trader Rating: 26 (100%+)
My understanding about the Vortex motors is that they can run as either sensored or sensorless. This was they are able to run with any manufactures speed controls.
Later,
CRASH is offline
Old 05-20-2007, 08:35 AM
Rick Hohwart's Avatar
Later,
Correct! We have had good feedback from drivers using the Mamba/Vortex set-up.
Rick Hohwart is offline
Old 05-20-2007, 08:37 AM
CRASH's Avatar
Thanks for the confirmation Rick.
Later,
CRASH is offline
Old 05-20-2007, 09:49 AM
adamge's Avatar
Now, if only Orion would come out with Stock and 19t equivalent brushless motors.
adamge is offline
