Old 01-07-2008, 09:29 PM   #106
rosko's Avatar
what size t-bar is everyone using? i tried the 63 and it was pretty bad going to try a 75. run on med high ozite
rosko is offline   Reply With Quote
Old 01-20-2008, 04:44 PM   #107
rosko's Avatar
the hotbodies crossbrace that i baught was to long
Old 01-23-2008, 03:04 PM   #108
HB
i'm using the irs arms
the crossbrace from HB will be to short
HB is offline   Reply With Quote
Old 01-24-2008, 01:32 AM   #109
HB, have you finished your car? are you going to run it this Saturday?
B-day is offline   Reply With Quote
Old 01-24-2008, 02:12 PM   #110
HB
i'm not finished
waiting for some stuffs
are u going to drive tc?????
Old 01-24-2008, 05:26 PM   #111
no more TC. Maybe a little bit 1/12. PK will open this Saturday. What part do you need? The Cyclone 12 cross brace? Except this one, I might have something you need, cos I have so many Asso 1/12 part.
Old 01-24-2008, 07:06 PM   #112
P2
P2's Avatar
Trader Rating: 15 (100%+)
Sometimes the lower arms are not perpendicular to the chassis. The brace should cure this (HB brace should work). If you loosen the lower arm screws and attach the upper brace, retighten the lower screws....it might work. Give it a try, your other options are to make your own or the adjustable CRC brace.
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 01-27-2008, 10:34 AM   #113
HB
here is my car
Hot Bodies Cyclone12-dsc00028.jpg   Hot Bodies Cyclone12-dsc00029.jpg   Hot Bodies Cyclone12-dsc00030.jpg   Hot Bodies Cyclone12-dsc00031.jpg   Hot Bodies Cyclone12-dsc00032.jpg
Old 01-27-2008, 11:30 AM   #114
looks good!
Old 01-27-2008, 11:31 AM   #115
RC MARKET's Avatar
Originally Posted by B-day View Post
looks good!
RC MARKET is offline   Reply With Quote
Old 01-27-2008, 12:34 PM   #116
oze
here is my car
Do you have to receiver battery packs? What is it under the grey plastic wrap?
oze is offline   Reply With Quote
Old 01-27-2008, 02:53 PM   #117
HB
the receiver batterys are for my servo it will make the servo a littlebit faster
u donīt need it if u donīt want it
and under the plastic is a Much more Schottky 55A
Old 03-06-2008, 04:18 PM   #118
Robertw321's Avatar
R/C Tech Charter Subscriber
How does the new style center shock react to shock oils? If I used 30 wt. in my VCS shocks would I use 30 wt. in the HB shock?
TIA
Bob Williams
Robertw321 is offline   Reply With Quote
Old 03-06-2008, 04:58 PM   #119
Joost K.'s Avatar
You really want to change the front axles for a titanium set from CRC. The original HB axles break real easy. I owned a HB C12 and the first pack I ran the front axles broke. If you do so, you will also need a set of steering blocks from AE/CRC or the delrin pieces from CRC.
Also if you want to use the JACO Prism rear wheels, a different rear axle is recommended. I used a RC12L4 axle which is from IRS but you can also use any other graphite adjustable rear axle. This will really be an improvement because JACO prism wheels are almost the most used wheels in the Netherlands and these wheels have a -3mm. off-set.
Broken front axles...
@HB: Als je verder nog tips en dergelijke nodig hebt stuur je me maar een PM ;-)
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Trinity | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 03-09-2008, 10:48 AM   #120
Bubblehead's Avatar
Has anyone tried using Niftech's (Ultra Slick High Grade Teflon Washers) on their dampening disk? And what is the best thing to use on the disk?
Bubblehead is offline   Reply With Quote
lookin for some race bodies tc3 xray bodies newrcguy2008 R/C Items: Wanted to Buy 1 04-29-2008 08:01 PM
Custom Painted Losi XXX-CR and XX-4 Bodies by Ridgeway Bodies ridgewaybodies R/C Items: For Sale/Trade 18 03-29-2008 09:54 PM
2 unpainted B3 bodies from Hot Bodies JonBoy R/C Items: For Sale/Trade 2 03-14-2005 08:09 AM
the best bodies 2fast for you Nitro On-Road 1 07-26-2004 07:59 AM
Rare Pan Car Bodies 1/10 1/12, Yok Mini BOdies, Losi Bodies Etc dynamic_e R/C Items: For Sale/Trade 3 07-31-2003 09:39 PM
