Old 01-03-2008, 12:14 AM   #91
rosko's Avatar
rosko is offline   Reply With Quote
Old 01-03-2008, 06:58 AM   #92
P2
P2's Avatar
Trader Rating: 15 (100%+)
Originally Posted by rosko View Post
any set-up sheets available from vegas anywhere
I haven't seen any, but from memory this is what they ran different from the stock kit:
ASE steering blocks w/Lunsford Ti axles, pobably used ASE .020 springs.
Graphite rear axles - to replace stock 3 piece = HEAVY
Aftermarket rear hubs, IRS or CRC
Rear shock mount raised 1.5mm, ASE olive spring
Batteries forward
Moore used Center servo mount = HEAVY
Hara used stock servo mount
Both used small Kimbrough servo saver
Jaco tires - not sure of compunds.
See pics of their cars on earlier pages of this thread.
Good luck
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 01-04-2008, 03:50 AM   #93
rosko's Avatar
green slime or diff lub
Old 01-04-2008, 03:52 AM   #94
rosko's Avatar
dont know which is better the diff lube or the green slim
Old 01-04-2008, 03:54 AM   #95
Joehwee's Avatar
Can someone tell me when to use the pivot for the front of the T-Bar? Also what is the diff between running 1 fixed block and 1 pivot vs 2 pivots on the T-bar?
Thank in advance
Joehwee is offline   Reply With Quote
Old 01-04-2008, 11:47 PM   #96
rosko's Avatar
two pivots well you know thats good for carpet , thats what everybody runs as far as i know anyway. the pivot just in the rear im curious about myself, im thinking maybe good for outside but not really sure about that. i wonder which way would be better for brushless
Old 01-05-2008, 03:57 AM   #97
HB
hi
i have buld my cyclone 12
whit a lower suspension arm from IRS
and caster blocks from AE
but the cross brace from hotbodies is to short
and from AE is to long
can sombodie help me out???
thanx
HB is offline   Reply With Quote
Old 01-05-2008, 04:02 AM   #98
corallyman's Avatar
Trader Rating: 99 (100%+)
Possibly look into the one CRC has for their car. The CRC cross brace is aluminum and I believe width adjustable, but you can ask others to be sure as I have never owned one personally. I can tell you it mounts in the hole in the caster blocks not in the caster block slot.
Steve
corallyman is offline   Reply With Quote
Old 01-05-2008, 05:28 AM   #99
oze
Steve is right, you can adjust the length of the CRC cross brace with shims.
oze is offline   Reply With Quote
Old 01-05-2008, 07:04 AM   #100
HB
i see p2 have one in hes car
cross brace
Old 01-05-2008, 07:11 AM   #101
corallyman's Avatar
HB,
The pic in post #60 in this thread, is Andy Moore's car from the IIC, which P2 posted. Yes that looks like the cross brace you would want.
Steve
Thanks Oze.
Old 01-05-2008, 01:48 PM   #102
HB
i'm mean post #72
steve
maybe i will make one if i cant find one
Old 01-05-2008, 09:13 PM   #103
P2
P2's Avatar
The cross brace that I used on my car was from my OD12 asphault car. The front track is the same width as the C12 (narrow). The Yokomo asphault car has the same front end spacing as the C12. In the US you can get them here:
https://www.ssl-stormerhobbies.com/c...ns&pn=HOT61673
The front brace is very inexpensive.
Old 01-06-2008, 03:48 AM   #104
HB
thanx all u guys for the info
Old 01-06-2008, 04:16 AM   #105
HB
the cross brace is look like this
1 is from hotbodies and one is from AE
lookin for some race bodies tc3 xray bodies newrcguy2008 R/C Items: Wanted to Buy 1 04-29-2008 08:01 PM
Custom Painted Losi XXX-CR and XX-4 Bodies by Ridgeway Bodies ridgewaybodies R/C Items: For Sale/Trade 18 03-29-2008 09:54 PM
2 unpainted B3 bodies from Hot Bodies JonBoy R/C Items: For Sale/Trade 2 03-14-2005 08:09 AM
the best bodies 2fast for you Nitro On-Road 1 07-26-2004 07:59 AM
Rare Pan Car Bodies 1/10 1/12, Yok Mini BOdies, Losi Bodies Etc dynamic_e R/C Items: For Sale/Trade 3 07-31-2003 09:39 PM
