Old 10-08-2007, 12:41 PM   #46
RC MARKET's Avatar
Originally Posted by P2 View Post
When will the servo mount system be available...I want one now
this month release !
RC MARKET is offline   Reply With Quote
Old 10-18-2007, 08:10 AM   #47
morosis's Avatar
Got mine the other day, anyone have a set-up for stock foam yet?
morosis is offline   Reply With Quote
Old 10-18-2007, 08:13 AM   #48
unless you got the optional 2.5mm chassis and 2.5mm rear lower pod plate i don't think you'll be able to get the setup that was run at the iic. probably best to start with the standard 2.0mm chassis and the basic settings that comes in the kit.
http://www.hbeurope.com/manuals/61600.pdf
Queef Toot is offline   Reply With Quote
Old 10-23-2007, 11:20 AM   #49
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Im looking to get one.....Has anyone built one up yet? How does it build up and have you run it yet?
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 10-23-2007, 12:47 PM   #50
RC MARKET's Avatar
Originally Posted by RC MARKET View Post
Thanks !
I'll try this .
HB coming have 3 option parts for Cyclone 12
this weekend arrive will have lower price !
Old 10-23-2007, 01:05 PM   #51
RussB's Avatar
Send a message via MSN to RussB
Originally Posted by racenut123 View Post
This is such a ridiculous statement. Between here and Rcracing.com,you have thrown up so much unwanted personal opinion,its getting old.For a kid who has been racing for less then a year,never has run 12th scale,barely competitive in the class you do run in,you sure have an opinion on everything you have no idea about.Billy needs to get you in check.
RussB is offline   Reply With Quote
Old 10-23-2007, 04:07 PM   #52
P2
P2's Avatar
Trader Rating: 15 (100%+)
I built one and raced it a few times, initial impression is very good.
The build is good w/the exception of the rear axle/hubs...mine had a wobble on the diff side. I just used an IRS rear axle/hubs and all is well. Hara and Moore use graphite axles too.
I didn't use the C12's front arms because they are not "lowered". I just used IRS arms w/ASE caster blocks and everything bolts up fine.
The car has a narrower front end than an L4, wheelbase is almost the same. The rear shock is one of the nicest features.....
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 10-23-2007, 06:28 PM   #53
EricW's Avatar
P2,
You're not racing your OD12 anymore? BTW what's the turnout at Hobbytown SA like lately?
EricW is offline   Reply With Quote
Old 10-30-2007, 09:52 AM   #54
Barry White's Avatar
Are the asso rear axle ride height adjusters compatible?
Barry White is offline   Reply With Quote
Old 10-30-2007, 02:54 PM   #55
corallyman's Avatar
Trader Rating: 99 (100%+)
Guys,
I just snagged a HB Cyclone 12 recently to play with for a bit. It came to me built very nicely but I was going to take it apart to find out what is compatible with other parts from other manufacturers.
Barry,
I will post later the answer to your question, if you guys have any others please post.
Steve
corallyman is offline   Reply With Quote
Old 10-30-2007, 04:09 PM   #56
P2
P2's Avatar
Yes...other parts from ASE that will work are the following:
plastic battery holders
all bearings and springs
rear axle/diff, I didn't like the stock assembly
T-bar
dampener disks
steering blocks, shortens wheel base by 1.5mm
Besides the bearings the car is all metric. The pivot balls will not work in ASE/CRC cups. You can miss/match the front end w/standard 1/12 front end parts.
Old 10-30-2007, 05:19 PM   #57
EricW's Avatar
P2,
What's with the pink dog in the second pic? Or would you rather not talk about it?
Old 10-30-2007, 07:25 PM   #58
P2
P2's Avatar
Originally Posted by EricW View Post
P2,
I have an alibi.....it's my daughters. Here is a pic of her when she won a Hot Bodies Nitro stadium truck at the IIC
Old 10-30-2007, 07:29 PM   #59
odpurple's Avatar
OH NO!
Not the Pink Doggie!!! He's out!!!
RUN!! AHHHHH!!
odpurple is offline   Reply With Quote
Old 10-30-2007, 07:45 PM   #60
P2
P2's Avatar
Here is a pic of Moore's car at the IIC. The only thing that doesn't look stock on the car are the ASE steering blocks w/lunsford axles and the graphite rear axle/hubs. Not sure if it was a 2mm or 2.5mm chassis, I forgot to check. Center spring is your standard Olive spring and the rear end of the shock is raised a mm or 2 because the rear pod sits lower than other cars. He's also using the 'tweak less" aluminum servo mount that bolts onto the chassis' center. Hara's car had the stock servo mounts.
lookin for some race bodies tc3 xray bodies newrcguy2008 R/C Items: Wanted to Buy 1 04-29-2008 08:01 PM
Custom Painted Losi XXX-CR and XX-4 Bodies by Ridgeway Bodies ridgewaybodies R/C Items: For Sale/Trade 18 03-29-2008 09:54 PM
2 unpainted B3 bodies from Hot Bodies JonBoy R/C Items: For Sale/Trade 2 03-14-2005 08:09 AM
the best bodies 2fast for you Nitro On-Road 1 07-26-2004 07:59 AM
Rare Pan Car Bodies 1/10 1/12, Yok Mini BOdies, Losi Bodies Etc dynamic_e R/C Items: For Sale/Trade 3 07-31-2003 09:39 PM
