Old 05-15-2007, 06:35 PM   #1
Default Battery Q's
ok ive been thinking bout a couple things ive heard/read and wondered if the pro's do it and how.
if u read rcca u might have read an article bout a bump box and what it is is 10 cells in series which u hook up to your 6 cells race pack for 30 sec to boost the voltage for a hole shot of the start.
does any one do this? is it bad for your cells?
secondly when pros charge there packs for a run do the charge them out of the car in a heat sink (if it hot) or warmer. or do they charge them in the car so they dont waste time putting the pack in after its peaked?
also how close to a race should u aim for a pack to peak? i know ideally as close to but realisticly? 5 min before?? more less?
cheers guys just curious bout these little things
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 05-16-2007, 08:57 AM   #2
timmay70's Avatar
I haven't seen a bump box used for a while. Ideally, a single charge peaked right before you go out to race is the best. Keep in mind how long it takes to get through tech when calculating charge time. Re-peaking batteries is not ideal, but if a race drags out and your cells peaked, may be necessary. Re-peaking at a high rate will drive up the voltage. However, the first turn you severely hammer the pack (wall hit, or even hard on the throttle) that peak will be lost.
Most times, especially at club races, people will perfect peak, then drive the car around the track to trim in the car. This will take the top off a peak, although usually doesn't hurt the duration of the race perceptibly.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 05-16-2007, 10:42 PM   #3
how long after charging should i re peak my cells?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 05-17-2007, 06:00 PM   #4
any one?
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 05-17-2007, 06:16 PM   #5
wingman2's Avatar
I have seen people at Nationals using chargers that have a timer on them. You have to work out how long it will take to get the cells charged just in time for your heat, put that time into the charger and hopefully (if no hold ups during the heats before yours) your cells are fully charged and peak out just before your heat starts. The poeple I saw doing this were using a Nosram charger.
wingman2 is offline   Reply With Quote
Old 05-18-2007, 09:34 PM   #6
wallyedmonds's Avatar
in the old days some used a 12v battery to do this.
yes i know
but the 1100 and 1200 batterys could handle it and they liked it hot.
this was done in oval racing.
wallyedmonds is offline   Reply With Quote
tekin battery doctor 8.0 & fk05 battery brace xxblackheartxx2 Australia For Sale/Trade 0 04-02-2008 01:33 AM
Hakko 936, Spintec battery manager, Ko Ex-10, Spektrum Pro, tekin battery doctor Breeze R/C Items: For Sale/Trade 2 12-08-2007 09:47 PM
33 Promatch 3300 NIMH battery cells and Battery Case nitro468 R/C Items: For Sale/Trade 10 08-06-2007 05:21 PM
FS: New Lipo battery 8000mah 7.4v fits in most battery trays aussiebuddha Australia For Sale/Trade 0 11-22-2006 03:23 PM
10 6 cell battery packs, 3 stock motors and 2 sakio battery cases $52.00 ??? bigoTC3fan R/C Items: For Sale/Trade 1 09-22-2004 06:07 PM
